Kaj de Vos Posted April 28, 2021 Share Posted April 28, 2021 (edited) I am developing a new language that I have been introducing here: After the Atari 8-bit, I am now targeting it at the 2600. I just posted the first demo here: Here is the source code: unsafe!!! constant reference volatile byte! [ ; TIA VSYNC= ~0000 VBLANK WSYNC COLUBK= ~0009 PF0= ~000D PF1 PF2 GRP0= ~001B GRP1 ENAM0 ENAM1 ENABL ] vertical-sync-bit= %0000'0010 VBLANK: ; Set beam to on to use the entire vertical-blank overscan area ENABL: ; Ball off ENAM1: ENAM0: ; Missiles off GRP1: GRP0: ; Players off PF2: PF1: PF0: 0 ; Playfield off; we only use the background byte! [jiffies colour] forever [ VSYNC: WSYNC: vertical-sync-bit ; Wait for end of scanline, then start vertical sync ; Vertical sync pulse. ; This lasts 3 scanlines, where some small work can be done to set up the next screen. colour: jiffies ; Begin colour gradient, shifted by jiffy counter ; Wait three scanlines, then end vertical sync, continue vertical blank VSYNC: WSYNC: WSYNC: WSYNC: 0 ; Vertical blank area, followed by the visible display area, ; followed by another vertical-blank overscan area. ; PAL and SECAM officially have 45 + 228 + 36 scanlines here, NTSC has 37 + 192 + 30. ; We generate 283 scanlines (plus the 3 for vertical sync), for a display frequency of 55Hz, ; inbetween PAL/SECAM and NTSC. It will work on all, if you have a tolerant television set. ; The first scanline is used for the setup overhead of the LOOP, ; so it gets the last colour wrapped over from the last scanline of the previous screen. ; Being the first line of the vertical blank overscan area, it is normally not visible. loop 282 [COLUBK: WSYNC: overflow increment colour] ; Increment background colour for every scanline overflow increment jiffies ] Here are some artifacts of the compilation. The assembler listing: https://language.meta.frl/examples/platforms/Atari/2600/rainbow.list A VICE labels file, for debuggers: https://language.meta.frl/examples/platforms/Atari/2600/rainbow.labels The memory sections map: https://language.meta.frl/examples/platforms/Atari/2600/rainbow.map It's my second 2600 program; please be gentle. ? The language will be cross-platform on as many systems as possible. 2600 programs are developed by cross-compiling. In many cases, it is also needed to pre-compute data for a 2600 program. You will be able to write such tools in the same language, on your PC or Mac or other favourite system. Edited December 10, 2021 by Kaj de Vos Added screenshot 6 Quote Link to comment Share on other sites More sharing options...
Kaj de Vos Posted May 3, 2021 Author Share Posted May 3, 2021 Rainbow assembly The language has an integrated assembler, so we could also write Rainbow like this: https://language.meta.frl/examples/platforms/Atari/2600/rainbow-assembly.rom https://language.meta.frl/examples/platforms/Atari/2600/rainbow-assembly.list https://language.meta.frl/examples/platforms/Atari/2600/rainbow-assembly.labels https://language.meta.frl/examples/platforms/Atari/2600/rainbow-assembly.map unsafe!!! [ constant reference volatile byte! [ ; TIA VSYNC= ~0000 VBLANK WSYNC COLUBK= ~0009 PF0= ~000D PF1 PF2 GRP0= ~001B GRP1 ENAM0 ENAM1 ENABL ] vertical-sync-bit= %0000'0010 LDA 0 STA PF0 ; Turn playfield off; we only use the background STA PF1 STA PF2 STA GRP0 ; Players off STA GRP1 STA ENAM0 ; Missiles off STA ENAM1 STA ENABL ; Ball off STA VBLANK ; Set beam to on to use the entire vertical-blank overscan area byte! jiffies forever: STA WSYNC ; Wait for end of scanline LDA vertical-sync-bit ; Start vertical sync STA VSYNC ; Vertical sync pulse. ; This lasts 3 scanlines, where some small work can be done to set up the next screen. LDX jiffies ; Begin colour gradient, shifted by jiffy counter ; Wait three scanlines STA WSYNC STA WSYNC STA WSYNC ; End vertical sync, continue vertical blank LDA 0 STA VSYNC ; Vertical blank area, followed by the visible display area, ; followed by another vertical-blank overscan area. ; PAL and SECAM officially have 45 + 228 + 36 scanlines here, NTSC has 37 + 192 + 30. ; We generate 283 scanlines (plus the 3 for vertical sync), for a display frequency of 55Hz, ; inbetween PAL/SECAM and NTSC. It will work on all, if you have a tolerant television set. TAY ; A is still 0 loop-256: INX ; Increment colour for every scanline STA WSYNC STX COLUBK ; Colour background DEY BNE loop-256 LDY 26 loop-26: INX STA WSYNC STX COLUBK DEY BNE loop-26 INC jiffies ; Count display frames JMP forever ] More efficient code can be written this way, but it's clearly more elaborate than the high-level language. 1 Quote Link to comment Share on other sites More sharing options...
Kaj de Vos Posted August 20, 2021 Author Share Posted August 20, 2021 To keep this the main thread, here is the announcement I just made in the parent forum: Quote Link to comment Share on other sites More sharing options...
