(16 bit division), Fast divide by 10
I took a stab at making a 16 bit division routine tonight. I took the approach of dividing the high and low bytes separately, since I have already written a bunch of 8 bit division routines. I then corrected the result with a couple of small look up tables.
This is the 16 bit routine I came up with. At 111 cycles max, and 96 bytes total it's not too bad.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; UNSIGNED DIVIDE BY 10 (16 BIT) ; 111 cycles (max), 96 bytes ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; TensRemaining: .byte 0,25,51,76,102,128,153,179,204,230 ModRemaing: .byte 0,6,2,8,4,0,6,2,8,4 .overflowFound: cmp #4 ;2 @74 We have overflowed, but we can apply a shortcut. lda #25 ;2 @76 Divide by 10 will be at least 25, and the bne .finishLowTen ;3 @79 carry is set when higher for the next addition. ; always branch .startBigDivide: lda counterHigh ;3 @3 sta temp ;3 @6 lsr ;2 @8 adc #13 ;2 @10 adc temp ;3 @13 ror ;2 @15 lsr ;2 @17 lsr ;2 @19 adc temp ;3 @22 ror ;2 @24 adc temp ;3 @27 ror ;2 @29 lsr ;2 @31 and #$7C ;2 @33 AND'ing here... sta temp ;3 @36 and saving result as highTen (times 4) lsr ;2 @38 lsr ;2 @40 sta highTen ;3 @43 adc temp ;3 @46 highTen (times 5) asl ;2 @48 highTen (times 10) sbc counterHigh ;3 @51 eor #$FF ;2 @53 tay ;2 @55 mod 10 result! lda TensRemaining,Y ;4 @59 Fill the low byte with the tens it should sta lowTen ;3 @62 have at this point from the high byte divide. lda counterLow ;3 @65 adc ModRemaing,Y ;4 @69 bcs .overflowFound ;2³ @71/72 sta temp ;3 @74 lsr ;2 @76 adc #13 ;2 @78 adc temp ;3 @81 ror ;2 @83 lsr ;2 @85 lsr ;2 @87 adc temp ;3 @90 ror ;2 @92 adc temp ;3 @95 ror ;2 @97 lsr ;2 @99 lsr ;2 @101 lsr ;2 @103 clc ;2 @105 .finishLowTen: adc lowTen ;3 @108 sta lowTen ;3 @111
There is a verification program and source code below. It rom has a black screen for a few seconds before displaying PASS.
Here is a second version of the divide by ten. It takes 126 cycles, but uses only 79 bytes. So you can choose whatever routine is best. Code for it is below.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; UNSIGNED DIVIDE BY 10 (16 BIT) ; 126 cycles (max), 79 bytes ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; TensRemaining: .byte 0,25,51,76,102,128,153,179,204,230 ModRemaing: .byte 0,6,2,8,4,0,6,2,8,4 .startBigDivide: ldy #-2 ;2 @2 skips a branch the first time through lda counterHigh ;3 @5 .do8bitDiv: sta temp ;3 @8 lsr ;2 @10 adc #13 ;2 @12 adc temp ;3 @15 ror ;2 @17 lsr ;2 @19 lsr ;2 @21 adc temp ;3 @24 ror ;2 @26 adc temp ;3 @29 ror ;2 @31 lsr ;2 @33 and #$7C ;2 @35 AND'ing here... sta temp ;3 @38 and saving result as highTen (times 4) lsr ;2 @40 lsr ;2 @42 iny ;2 @44 bpl .finishLowTen ;2³ @46/47...120 sta highTen ;3 @49 adc temp ;3 @52 highTen (times 5) asl ;2 @54 highTen (times 10) sbc counterHigh ;3 @57 eor #$FF ;2 @59 tay ;2 @61 mod 10 result! lda TensRemaining,Y ;4 @65 Fill the low byte with the tens it should sta lowTen ;3 @68 have at this point from the high byte divide. lda counterLow ;3 @71 adc ModRemaing,Y ;4 @75 bcc .do8bitDiv ;2³ @77/78 .overflowFound: cmp #4 ;2 @79 We have overflowed, but we can apply a shortcut. lda #25 ;2 @81 Divide by 10 will be at least 25, and the ; carry is set when higher for the next addition.. finishLowTen: adc lowTen ;3 @123 sta lowTen ;3 @126 routine ends at either 87 or 126 cycles
1 Comment
