step 10 - "Random Numbers"
And yes, those are air quotes
Inside the Atari (and computers in general), there's no such thing as a Random Number. We can, however, simulate random numbers by using a Linear Feedback Shift Register. The LFSR we're going to use was posted by batari, it's a rather slick bit of code in that it can be either an 8-bit or 16-bit LFSR.
Random:
lda Rand8
lsr
ifconst Rand16
rol Rand16 ; this command is only used if Rand16 has been defined
endif
bcc noeor
eor #$B4
noeor:
sta Rand8
ifconst Rand16
eor Rand16 ; this command is only used if Rand16 has been defined
endif
rts
LFSR's create what appear to be a random sequence of numbers, but they're not. A properly constructed 8-bit LFSR will start repeating values after 255 values have been obtained. All you need to do in order to use the above routine as an 8-bit LFSR is allocate a variable called Rand8:
; used by Random for an 8 bit random number
Rand8: ds 1 ; stored in $AB
A 16-bit LFSR will repeat after 65535 values have been obtained - that's a lot better than 255; however, it requires you to allocate another variable. With the Atari's limited 128 bytes of RAM, games often didn't have RAM to spare so they'd just use an 8-bit LFSR. Collect is a rather simple game though, so we have RAM to spare and will allocate the second variable Rand16.
; optionally define space for Rand16 for 16 bit random number
Rand16: ds 1 ; stored in $AC
The random number generator does have potential problem to be aware of - if you're using an 8-bit LFSR and Rand8 has the value of 0 then the LFSR will always return 0. Likewise for the 16-bit LFSR if both Rand8 and Rand16 are 0 it will always return 0. So we need to initialize the LFSR as CLEAN_START set all the RAM variables to 0.
InitSystem:
CLEAN_START
; seed the random number generator
lda INTIM ; unknown value
sta Rand8 ; use as seed
eor #$FF ; both seed values cannot be 0, so flip the bits
sta Rand16 ; just in case INTIM was 0
One thing that helps when using an LFSR is to keep reading values at a regular rate, even if you don't need the value. What this does is impose an element outside of the Atari's control - namely the time it takes the human to do things: hit the RESET switch to start a game, collect the next box, etc. I've added this to VerticalBlank
VerticalBlank:
jsr Random
Now that we have a function for random numbers we need to use them. First up is new routine that will randomly position any object. To use this function we just need to call it with X register holding a value that denotes which object to position. The values are the same ones used for the PosObject function, namely 0=player0, 1=player1, 2=missile0, 3=missile1 and 4=ball.
RandomLocation:
jsr Random ; get a random value between 0-255
and #127 ; limit range to 0-127
sta Temp ; save it
and #15 ; limit range to 0-15
clc ; must clear carry for add
adc Temp ; add in random # from 0-127 for range of 0-142
adc #5 ; add 5 for range of 5-147
sta ObjectX,x ; save the random X position
sta Temp ; save it
adc #26 ; add 26 for range of 26-168
sta ObjectY,x ; save the random Y position
rts
I've renamed InitPos to NewGame and modified it to call RandomLocation. It runs through a loop setting all the box objects. Starting X value will be 1 or 2 based on the number of players in the selected game variation.
NewGame:
; Randomly position the boxes for the new game. Set X to 1 for a 1 player
; game or 2 for a 2 player game so that the appropriate objects will be
; randomly placed in the Arena.
lda Variation
and #1 ; value of 0=1 player game, 1=2 player game
tax ; transfer to X
inx ; start with 1 for a 1 player game, or 2 for a 2 player game
IPloop:
jsr RandomLocation ; randomly position object specified by X
inx ; increase X for next object
cpx #5 ; check if we hit 5
bne IPloop ; branch back if we haven't
rts
I also modified OverScan so that during a 1-player variation a collision between player0 and player1 will be detected. If so, it calls another new function, CollectBox.
OverScan:
bit Players ; test how many players are in this game variation
bmi RightPlayer ; test Right Player collisions if its a 2 player game
bit CXPPMM ; else see if left player collected box drawn by player1
bpl OSwait ; player0 did not collide wth player1
ldx #1 ; which box was collected
jsr CollectBox ; update score and reposition box
jmp OSwait ; 1 player game, so skip Right Player test...
CollectBox will increase the player's score and call RandomLocation again to move it to a new position. When CollectBox is called, Y must hold which player (0 for left, 1 for right) and X must hold the object that was collected.
CollectBox:
SED ; SEt Decimal flag
clc ; CLear Carry bit
lda #1 ; 1 point per box
adc Score,y ; add to player's current score
sta Score,y ; and save it
CLD ; CLear Decimal flag
jsr RandomLocation ; move box to new location
rts
CollectBox means that the game is now playable for 1-player games! I managed to score 26 on game variation 1, how well can you do?
One thing you might notice in that screenshot is that the right player's score is not visible. Since we're done using the score for diagnostics, I've made a few changes to the digit graphics:
The first change is the left 0 image was blanked out - this provides leading zero suppression
The second change is the A image is now blanked out - NewGame uses this to blank out the right player's score in 1 player games.
NewGame:
; reset scores
ldx #0
stx Score
bit Players ; check # of players
bpl BlankRightScore
stx Score+1
rts
BlankRightScore:
lda #$AA ; AA defines a "space" character
sta Score+1
rts
Lastly the graphics for B thru F have been removed to save ROM space.
ROM
Source
9 Comments
