Out of Memory
After adding the functions to write saved game and highscores, which have to sit in main memory, I'm officially out of memory. ![]()
I will have to disable the OS and use the memory under the OS to complete porting the game. The good news is that I believe there will be enough memory and that it is possible to port the (almost; minus recall monster memories) complete Moria to the Atari with VBXE and Maxflash cart.
Attached is the last version that works without using memory under the OS. Some things that have been added since the last playable demo: saving of highscores and game save (Ctrl-X). If using Altirra, remember to save the cartridge (Save Firmware in the File menu) to save the cartridge memory after your session. Also, some monsters can multiply (gets a little slow with a lot of monsters on the screen). You can gain spells now (can't cast them yet though!)
A few of the bugs have been found and quashed, but some still remain.
