    39
    57
    124,731
Vertical Ball Pt II
DanBoris
The ball vertical motion is controlled by a slip counter just like the horizontal.
The counter is clocked by the /HSYNC signal so it will increment once per line. Since /VBLANK goes to the ENT input of B3 it will stop the count during VBLANK. When the two stages of the counter reach 255 the load signal will be triggered by B2. The upper stage of the counter is loaded with 0, and the lower portion is loaded with the output of the vertical control circuit. The values from the vertical control result in the following numbers of counts:
7 – 248
8 – 247
9 – 246
10 – 245
11 – 244
12 – 243
13 – 242
There are 245 visible lines on the screen (excluding the VBLANK region), so a value of 10 from the vertical control will result in no vertical motion, a value less then 10 will move the ball down on the screen, and a value greater then 10 will move the ball up on the screen.
When the counter reaches a value of 252 the output of E2 will go low and stay low until the counter resets 4 counts later, making the ball 4 pixels high.
7 Comments
Great stuff :) I'd always wondered how games worked w/out a CPU.
Thanks! I was also quite curious about how they worked which is what led me to start writing this blog!
It's amazing how much stuff can be replaced by microprocessors. A 6507 and RRIOT chip (RAM, ROM, I/O, and timer) could probably replace most of the circuitry in Pong even without using any custom logic.
If I were trying do design a 6507-based PONG, I'd probably have a hardware counter chain to generate horizontal sync, a slip-counter to generate the ball (horizontal only), a latch to enable/disable the ball, a '165 to generate the paddles, net, and scores (along with a few gates to activate it). And a 556 to read the paddles I guess, along with a '741 to handle input.
Still, it's impressive what people were able to design using just discrete circuitry. I think Pong is interesting because it took a very different design approach from Ralph Baer's machines--one which served well for a few years before microprocessors took over.
It's even more impressive to look at some of the later discreet logic games. I recently refurbished a Sega Monaco GP machine which was one of the last discreet logic games. It's amazing to think that game doesn't have a microprocessor. Actually in the case of that game I have wondered why they chose to go without a processor. It was released in 1980 and I can't image that it would have saved them any money going pure logic instead of a processor.
Dan
Wow - I would never had expected that to be discrete.
The circuit boards look pretty complex, I suspect it would have taken a while to design. Perhaps when they started the CPUs where still too expensive, but when the CPUs became less expense they were far enough along that it didn't make sense to scrap it.
Perhaps. I could certainly understand doing the game logic as discrete. But the scoring/ranking circuitry? That alone used over fifty chips, and could have been done very easily with a microprocessor.
Probably a 650x, a couple RAMs (1Kx4 should be fine), a ROM, a few of 373's (one for every ten display digits), a 10-output Johnson counter, a few driving transistors, a 555 and a few discretes, and probably about five more 74xx chips.
Really a very straightforward design. Alternatively, one could use a non-multiplexed display with one 373 per digit.
