Bubsy 2 (Gameboy) I found the glitch!
I've recently found the glitch on Bubsy 2 for Gameboy. I basically found the glitch, which you can have infinite life bar!
But that wasn't easy to find, because when I made this glitch by an accident, I didn't know what I did. So I had to try it again and again and again, until I found the way to do it.
So here's how you do it:
Step 1:
Go to Bubsy 2 for Gameboy (duh) and choose grand tour.
Step 2:
When you're here, choose the plane level.
Step 3:
Finish this level. The next step is a bit hard.
Step 4:
When you touch the finish line, go down fast as you can.
If you do it, this will happen:
Then go down some more, and it will automatically go threw the tunnel.
Now the next is like this: when you see this rock, go towards the rock, and this is gonna happen:
- either you get in and get stuck (which you have to be stuck in it)
- or you'll bounce away (if that happens, it won't work)
If you get stuck, great! Now you just release bombs quickly by pressing the B button. Then you should hear this sound:
A sound of game over, but cut shortly
When you finish it, Bubsy will flash, like this:
If that happens, congratulations! You've made the glitch!
Now go ahead and choose the level.
As you can see there should be a head of Bubsy as a life bar, but when you do the glitch, it's empty.
But it won't be empty, when you touch the enemy.
This will happen:
If you hit more, the sprite will change. And now you have unlimited life bar. But that doesn't mean it's over.
There are 3 conditions you have to know:
1. Don't fall damage
2. Don't waste time
3. Don't touch more than 2 checkpoints
If you fail them, it will automatically fix itself and then you loose the power.
So there you have it. I hope that this trick interested you. I sure like this glitch.
If you wanna try it, go ahead and tell me if it works.
Credit is all to me!
- 1
- 1
