A8 MMS Voice File Data Explanation
k-Pack
 Share
Using MIDI MUSIC SYSTEM software to build music compositions seems to fit my skill set.  I'm not proficient at reading music but I can translate it.  My latest arrangement was a Celtic folk song for flute and drums.  Music was entered into MMS and a simple drum pattern was added.  It sounded terrible. Turns out that a synthesized flute doesn't need to breath and sounds very mechanical without those breaks.
Selected notes were shortened and rests were inserted to maintain timing and give the illusion that a breathing person was playing the flute. Sounded much better but it was tedious work.
Then I started to think I might have saved a Voice file and used a program to make the changes. Then import the voice back into MMS.
Then it dawned on me that I was going to have to figure out the file structure of a voice file and what the data means.
At this time I want to share what I think I know about how to create a voice file to import into MMS. Then someday someone (or myself) might write a useful program to create those files.
File header and data structure:
First thing that was done was to take a look at what a voice data file contained.  A few notes were entered in a voice and then the voice was saved.  This short program was written to list the content to the screen.  Simply change the filename to match the one you wish to view.  Use the cntl-1 key to stop and start scrolling.
10 TRAP 100:COUNT=0
20 OPEN #1,4,0,"D:TEMP.V01"
30 GET #1,A:? A;"  ";
33 GET #1,A:? A
37 FOR X=1 TO 3
40 GET #1,A
45 COUNT=COUNT+1
50 ? (A),
56 NEXT X
60 ? :GOTO 37
100 ? "COUNT=";:? COUNT
This short voice file listing demonstrates the format of the voice file.  You may want to build your own voice files and check the results.
24,0
250,0,0
10,48,0
85,48,0
75,48,0
87,48,0
250,0,0
165,48,0
245,51,255
COUNT= 24
It became apparent that the first two bytes will be the number of  instructions in the file. LSB - MSB format.  Then the instructions are listed.  At the end of the a count of the instruction sets is displayed. This should match the 16 bit number at the beginning of the file.
An instruction  consists of  three numbers.  The first designates the specific instruction and the next 2 are for any required data. I am assuming that if the data byte is not required by the instruction then MMS does not clear them to zero. That's the only explanation I have for some of numbers I have seen.
The first instruction will always be a measure marker(250).  Every voice has a measure marker at the beginning.   Check it out.
Rests and Notes
Rest  Rn -      0,LSB,MSB              n=0 -  65535 cycles
In MMS the duration of the rest is its clock value.  In MMS you would most likely assign  a clock value as W,H,Q,E,S, T, or Z.  Their clock values are listed on page 22 of the manual. The "." and " .. " are used to adjust the number of cycles required for the additional durations.  There is also the option of setting the duration by entering the clock value as ^n.
Keep in mind that meter will determine the clock value in a measure and to keep all the voices synced the total clock value must remain the same for all measures in a composition. (But you don't have to.)
Note instructions are between 1 (C1) and 108(G9).  If a tie is used bit 7 will be set making the value above 128.
  To calculate:
 MMS note number = (MIDI note number - 23) + (128 * IF tie)
The duration is set by the next two numbers much the same as for rests.
The Table
The rest of the instructions are to manipulate the MMS music settings or MIDI instrument.  For more information check the manual. If I missed any I'll add the information if I ever find a need to use them. If the Second or Third number's has not been determined then ND has been placed in the table.  In fact, it may not have a purpose.
Function
MMS Input
Byte 1
Byte 2
Byte 3
Rest
Rn
0
LSB
MSB
Note
(C1-G9)n
MIDI# 24-127
MIDI#-23
(+128 if tie)
LSB
MSB
Tempo
Tn
240
35-290
ND
Sound
Sn
241
0-127
ND
Program
(CC)
Pn,x
242
Controller
number
Setting
0-127
Repeat
REPn
243
0 = forever
1-255
ND
End Repeat
ENDR
244
ND
ND
Jump to
Voice
JMPn
245
1-99
ND
RETURN
RTN
246
ND
ND
Change Channel
Velocity
/CHn
VELn
247
247
Channel-1
0-127
255
0
Transpose UP
TRUn
248
0-127
ND
Transpose
Down
TRDn
248
Start +256 - n
LSB *
ND
Transpose
Zero
TRZ
249
ND
ND
Measure Marker
M
250
ND
ND
Tempo up
TUn
251
0-127
ND
Tempo down
TDn
251
Start +256 -n
LSB *
ND
Pitch Wheel High
PWHn
253
 ND
ND
Pitch Wheel Low
PWLn
253
ND
ND
Pitch Wheel Zero
PWZ
253
0
ND
*= I Think
ND = not determined
Table edited 11/9/21
I hope this is a good start to understanding voice files.  There are going to be some revisions to this table if I find a need to write a program that will import and export MIDI MUSIC SYSTEM Voice files.  That may happen If I find that the M: device driver for the MIDIMax will work with Diamond GOS.  I'll incorporate the changes when they are brought to my attention.
 Share
1 Comment
Table updated. Did some more work and found that the Velocity command was missing. As it turns out the change MIDI channel(/CHn) and Velocity(VELn) share the same command number 247.  The commands use a different number in BYTE 3.  The velocity will end in a 0 while the change channel will contain 255.
