    13
    39
    9,117
A picture that's worth more than a 1000 words.
splendidnut
But can be summed up in less than 100:
Using Stella to debug a rudimentary sprite sorting algorithm (in C compiled to assembly then run thru DASM to run in Stella)
WHICH is being used to help with developing a better multi-sprite engine for ChaoticGrill
WITH the added layer of complexity being it is using a C compiler which is still in-development (Neolithic C)
AND debugging issues with that (the C compiler) at the same time.
Oh, the joys of debugging.
Just thought I would take a moment to share this madness with the masses.
Enjoy,
And yes, that is the Congo Bongo code from the previous blog entry loaded in the background in Notepad++.
3 Comments
Lol.  Yeah, that would help.  I was thinking about fixing that, but then I saw the bug and the missing code in the sort algorithm, so now I've got it working.
As to why: The symbol file being loaded is from my compiler instead of DASM.  It has a vast amount of information that I use as a reference, but it is currently incompatible with Stella:
Symbol Table:
     Symbol Name        Kind  Flags  Pntr   Loc   BS  #El  Size  Value
 playerSpr              const  4001 false  @f1d0  01  13  0013
 playerColors           const  4001 false  @f1e2  01  13  0013
 enemySpr               const  4001 false  @f1f4  01  02  0002
 spriteX                  var  4001 false  @0082  01  08  0008
 spriteY                  var  4001 false  @008a  01  08  0008
 spriteOrder              var  4001 false  @0092  01  08  0008
 initOrderArray          func  0000 false  @f1f5  01  00  0017
  Locals:
     idx                  var  0401 false  @009b  01  01  0001       0
 sortSpritesViaInsert    func  0000 false  @f20c  01  00  006e
  Locals:
     curSprY              var  0401 false  @009b  01  01  0001
     sprOrdIdx            var  0401 false  @009c  01  01  0001
     foundSpot            var  0403 false  @009d  01  01  0001
     sortedSprNum         var  0401 false  @009e  01  01  0001
     workingSprNum        var  0401 false  @009f  01  01  0001
     curSpr               var  0401 false  @00a0  01  01  0001       0
 drawKernel              func  0000 false  @f27a  01  00  0052
  Locals:
     sprY                 var  0401 false  @009b  01  01  0001       0
     playerY              var  0401 false  @009c  01  01  0001      1e
     row                  var  0401 false  @009d  01  01  0001      57
 main                    func  0000 false  @f2cc  01  00  0000
  Locals:
     mainTimer            var  0401 false  @009a  01  01  0001       0
At some point, I'll probably looking into fixing the compatibility issue and/or adding support to Stella for this format (once I've got the format nailed down).
Fixed the symbol loading issue in Stella.  Easy fix: I just had to move the Loc (memory location) column to be the 2nd column and remove the '@' sign.
