    13
    39
    8,991
2600 Display Kernels
splendidnut
Welcome to the wonderful world of 2600 display kernel writing.
Here's a quick overview of some of the display kernels I've written:
Chaotic Grill
Chaotic Grill uses a 5-line display kernel... similar to the M-Network version.  It uses DPC+ to gain access to RAM
and Data Fetchers with Fast Fetch capability.  It uses half of the 4kb DPC+ display RAM as a graphics buffer for
the displaying the burger pieces.
The main 5-line kernel is broken into two parts:
    - Lines 1-4 = Draw Burger pieces
        - Draw 2 multi-colored single-line resolution sprites (GRP0, GRP1, COLUP0, COLUP1)
            - Draw 32 pix wide (PF1/PF2) asymmetric playfield that is multi-colored (4 COLUPF updates)
        - Check for split point
                OR
        - Draw Pepper (enable/disable: ENAM0 / move: HMM0 + HMOVE)
                OR
        - Draw Pepper (enable/disable: ENAM0), and reset COLUPF for level drawing, WSYNC
        (upto 15 TIA updates -- which requires DPC+ Fast Fetch to accomplish)
    - Line  5   = Draw Level platforms and ladders
        - Draw 2 multi-colored single-line resolution sprites (player objects)
        - Draw 36 pix wide (PF0/PF1/PF2) asymmetric playfield, single color
        - Clear-out Pepper drawing -> disable ENAM0
        - Spare time (8 cycles)
In addition to that, there's 18 variants of the above to handle repositioning P0 and P1 (one or the other, not
both).  There are that many variants because the respositioning has to be interleaved with drawing the burger
pieces.
Congo Bongo POC
Congo Bongo uses multiple 2-line kernels:
    - Draw 32pix wide (PF1/PF2) asymmetric playfield (single-line resolution) and set color for each line (COLUPF)
    - Draw 2 multi-colored double-line resolution sprites (player objects)
    - Draw a coconut using the missile (just enough time to enable/disable: ENAM0 and resize: NUSIZ0)
    - Ability to exit the kernel at a specified split-point and move on to the next kernel
    The drawing method for sprites uses "illegal"/undocumented 6502 CPU instructions:
      DCP (decrement and compare)
      LAX (load A and X)
Drawing Bongo's head uses it's own 2-line kernel.
Paint The City
Paint The City's Display Kernel is a bit complicated.  It uses a LOT of RAM and the code has been heavily unrolled to
handle interleaving road graphics preparation logic while drawing the sprites + buildings.
The simple breakdown is the display kernel uses 2 different types of 1-line kernels:
* Draw Buildings kernel:
    - Draw 40pix wide repeated playfield (20pix repeated playfield)
    - Draw 2 single color single-line resolution sprites (player objects)
    - Road graphics preparation (read level and painted road from RAM and use it to prepare 18 bytes of playfield
data)
* Draw Road kernel:
    - Draw 40pix wide asymmetric playfield (40pix .. so 6 TIA updates per line)
Since the kernels are split into 8 and 16 line rows, the sprite graphics are basically padded out with enough zeros
to fill that amount of space.  Each row has it's own sprite pointer for loading data into GRP1.
  • Like 5
1 Comment
Someday I'll be a man and create a display kernel.  Always wondered if you could solve the flickering issue by interleaving sprites between scanlines.  Probably look horrible unless using very bright colors and very fine resolution via bus stuffing.  I guess.
