Playing Gameboy Advance & Virtual Boy games
A month or two ago I watched a YouTube video which showed off Red Viper - a Virtual Boy emulator for the 3DS which uses the 3D screen so you get the same 3D experience you would with an actual Virtual Boy (complete with monochrome graphics, although you can change the color). I thought that was cool, especially since my son has a couple of 3DS XLs kicking around. But I didn't do anything because I've typically shied away from jailbreaking.
However, after some research I discovered that even the most up to date 3DSs can be jailbroken relatively easily, so I went ahead and did it. (The only speed bump is I used a 2GB card for my first try, which isn't quite large enough.) I then loaded up Red Viper and have been playing Virtual Boy Wario Land - it's very cool.
I also learned it's possible to play Gameboy Advance games basically natively on the 3DS. So I've loaded that up along with 643 ROMs from the DataFrog SF2000 I got last year. Right now I'm playing Mario & Luigi SuperStar Saga.
- 1
4 Comments
