    9,825
Batari Hardware collision 30fps flicker
Piggles
 Share
I had a problem for a while figuring out what to do about making my flickering sprites collide properly. Using odd frame, even frame, I found that only sprites on the same frame could collide. So I varied my flickering with one sprite alternating frames, and the other doing two frames in a row. Attached is the code and a binary. You drive sprites A and B. C and D will wrap around the vertical edges. If you touch C or D, one of your sprites will die and turn into a skull, the other will keep moving. The reset switch resets the program. Flickered sprites look horrible, but at least now I have two p0s and p1s that'll crash into each other.
altflick.bas
altflick.bas.bin
 Share
1 Comment
It just occurred to me that this may be elementary to the experienced Bb programmer. And certainly for the 6507 programmer who by his nature will be sure his sprites make use of hardware collision. However, I suppose if I struggled with it, then perhaps someone else did too. Or at least a new coder can benefit from my mistakes and not have to stumble with silliness and focus on actual gameplay.
What to do with it now? I suppose I ought to write a game....
...and finish it this time...
