ivop's Blog
    16
    31
    48,274
Atari Eagle parts library
ivop
 Share
I finally compiled all the different Eagle parts I had drawn over the last year into a single Eagle library and adjusted them to be more or less uniform in look. While I was at it, I also added all missing chips and connectors. Currently, it contains the following parts:
74LS08
74LS14
74LS51
74LS74
74LS138
74LS158
74LS375
4050
4051
4164
6502C/Sally
6520A/PIA
27128/OS PROM
ANTIC
BASIC ROM
Cartridge
Cartridge Socket
EP8212
GTIA
Joystick Port
Keyboard Socket
LM358
MMU
Monitor Jack
Parallel Bus Interface
Parallel Bus Interface Device
POKEY
Power Jack
RF Modulator
SIO Jack
Basically, it's everything you find on an 800XL motherboard.
Update 2014-04-29: added conversion to Eagle 6.5.0 (XML file format).
atari.lbr.gz eagle-6.5.0-atari.lbr.gz
  • Like 4
 Share
12 Comments
HI Ivo, is there any reason why the Vcc and Vss pins are missing on all the chips ?
Yeah, figured that out quit a while ago....
Would be cool if you could add FREDDIE Ivo ;)
They should be there. Probably hidden or automatic pins. Haven't used Eagle in ages as I have long since moved to using KiCad.
Hello Ivop - if you still have this and it's not too much trouble, I'd like to get a copy of it if you don't mind.  It seems like it may have been attached to the post at one time, but I don't see it anymore.  Thanks - John
Since the upgrade of the forum software, all attachments to my blog posts are gone. Have opened an issue on the tracker, so hopefully this will be resolved shortly. If not, I'll look at my backups to find it. Seems my eagle files are not on in my current life homedir anymore :)
Thanks for checking - I was able to create the couple of parts I was working with, so no need to go through backups!
