7800fan
  • Posts
    5,611
    12
Posts posted by 7800fan
  1. My local Goodwill are the same. They think an opened box of WoW WoD expansion pack is worth $9.99 when the code is used only once and probably no good anyway. Crapload of PS2 sports game for $9.99. Bejeweled for $9.99 when I can still get it new from Walmart for half that.
    That is a steal!
    He could get 4-5 times his money back just selling the battery cover haha...And still have the game!
    Was it for sure the Coleco Version? As there's also the Excalibur version (I have one of those) and those aren't worth nearly so much...
    It does say Coleco on the mini arcade.
  2. eBay Auction -- Item Number: 2632885521781?ff3=2&pub=5574883395&toolid=10001&campid=5336500554&customid=&item=263288552178&mpt=[CACHEBUSTER]
    Seller had a few 2600 games including a hard to find gray box variant. The seller cancelled the listing (including the $500 bid someone placed!!) and relisted:
    eBay Auction -- Item Number: 1126238729871?ff3=2&pub=5574883395&toolid=10001&campid=5336500554&customid=&item=112623872987&mpt=[CACHEBUSTER]
    You can tell they are the same box. The price tag are the same, damage to the flaps are the same The seller had it relisted for $350.
    Nope. The gray box variant is probably worth one zero less than what the seller thinks it's worth and I have no idea what is up with that kooky bidder who bid $500 for the lot.
  3. There's been a lot of Chinese sellers with 0 FB, odd names that looks like they used random number generator, and listed items at very low price. I've seen $20 Sony Vita with games, $25 new in box 5200 console, etc. The listing usually gets killed by eBay but if someone got suckered into buying the fake stuff, they aren't automatically refunded. If they don't open dispute due to invalid auction, after 21 days the seller gets the money where they can transfer or empty it out and eBay has no way to recover them.
    Buyers are still protected after that, up until 1 month past estimated delivery date but eBay are losing money paying back buyers when the seller screws the system.
    What I think needs to be done: if the listing is cancelled over suspicion it's fake, all buyers are to be automatically refunded and the seller gets nothing waiting to clean out.
  4. http://www.atarimuseum.com/videogames/consoles/jaguar/Panther/index.htm
    Panther was planned but quickly scrapped in favor of 64 bits Jaguar. But if someone can come up with 3D design for Panther, how about using that with McWill's mod (no LCD, just VGA out) and making it into console with external controller? P2 port would be a regular Comlynx port since Lynx didn't have built in 2 players control outside of Comlynx.
  5. No idea about HDMI or RGB so I'll let other answer that.
    Also, is the ATARI 5200 video upgrade kits 100% compatible with the ATARI 2600 add on adapter? I know some upgrade kits for the ColecoVision/ADAM system do not work with the Coelco ATARI 2600 adapter.
    Only older 4 port console needs mod to be compatible with the 2600 adapter. 4 port that has an asterisk * in the serial number is 2600 compatible. All 2 ports are 2600 compatible.
    However the 2600 video will not work with common AV and S-Video mod since the video signal isn't passed through. I don't know if any of the mod works correctly or not but I have a 7800 system so I can play 2600 games without having to deal with funky video issue from adapters.
  6. Modern analog joysticks like those used in AVR and replacement part for PS and XBox systems are typically 10k and won't work as replacement for Atari 5200 without replacing the pots. As the thumsticks are small, it's hard to find a suitable 500k potentiometers that will fit and can work.
    So what about using digital pots? Like https://www.digikey.com/product-detail/en/analog-devices-inc/AD5241BRZ1M/AD5241BRZ1M-ND/617299?? I didn't find 500k version but this is 1 megaohm, just use half of the range. It has 256 steps which would come to 128 steps when you use 0 to 500k range and that would translate to maybe 3 horizontal pixels on screen per step.
    Analog thumstick (say an old PS2 or XBox controller or a custom DIY) wired to a microcontroller like AVR that reads analog value and control digital pot to have pseduo-analog output. Since digital pot uses I2C connection, you could stack total of 4 to control both analog sticks on one controller for certain games like Robotron.
  7. Or get McWill LCD mod. But first check and double check for missed leaked cap residue and damaged vias.
    McWill LCD mod replaces the stock LCD complete with a modern LCD but they are over $100 and does require a bit of wiring to complete the mod.
  8. Doesn't matter if LCD is smashed or missing and/or if motherboard is badly fubar'd I just need the Vita for a project I wanted to do and I'd need one whose shell is in decent shape and with buttons and control pad usable (analog sticks doesn't need to work either) No games, no power supplies, no batteries, nothing else.
    Prefer USA but will consider oversea.
  9. Doesn't Windows 98 still depend on DOS to boot? Disable auto booting of Windows (usually in autoexec.bat delete win) and you should boot to DOS mode. Or better yet, make 2 separate autoexec.bat file. One for booting into Windows, one with DOS mouse driver (if needed), sound card settings, etc and when you need to switch mode, rename the autoexec.bat to autoexec.win and rename autoexec.dos to autoexec.bat.
    I had to do this long ago to play Ultima 7 games. It does not like emm386 at all so I had to make a version that only used the default 640k RAM.
  10. The caps used in game carts (SMS and Genesis as well, just about all carts post-crash) are for DC filtering and not subject to heat or high frequency so they probably won't fail like caps inside the console. If the cap leaked, something probably spilled into the cart or it was handled badly.
  11. I would check the power supply first. It may be failing and losing output after it gets warm. Then replace caps and the voltage regulator. If that still doesn't work, I'd check the video encoder chip. If you have something like can of compressed air, turn it upside down and aim at the video chip for a quick squirt and quick freeze. Does the video come back? Resolder that chip or replace it.
