Albert Posted September 1, 2008 Share Posted September 1, 2008 Thanks to Omegamatrix's help, I've updated several bad or missing NTSC ROMs in the database. I've also added two missing Zeller's entries (Scuba Diver and Sea Hawk), although I don't have cartridge scans for them. Also updated many of the Zeller's screenshots, which were incorrect (many of the Zeller's binaries were modified to remove the original company's name, for instance). Here's a list of the entries I updated: Sir Lancelot Bad Dump Congo Bongo Bad Dump Great Escape Wrong King Kong Wrong (PAL version) Espial Wrong (PAL version) Miner 2049er Vol. II Wrong (PAL version) ZELLERS: Busy Police Wrong Challenge Wrong Circus Wrong Earth Attack Wrong Farmer Dan Wrong Freeway Wrong Inca Gold Wrong, and wrong screenshots too Laser Volley Wrong Ocean City Defender Wrong Scuba Diver No Dump, and needs to be moved into the Zellers section Sea Hawk No Dump, and needs to be moved into the Zellers section Space Adventure Wrong Time Warp Wrong Turmoil Wrong I'm sure there are plenty of other entries that are incorrect or missing in some aspect. I'd like to fix any issues with the NTSC side of the database--this includes entries missing outright and incorrect or missing ROMs. Please use the Tracker to add new issues, as this makes it easy to keep track of changes: http://www.atariage.com/forums/index.php?a...p;showproject=6 Thanks! ..Al Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 1, 2008 Author Share Posted September 1, 2008 Glad to help, Al. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted September 20, 2008 Share Posted September 20, 2008 I have three different versions of Atari Space Invaders (PAL) and I managed to dump them running the software posted by batari in this thread on my VCS. The 3 variations differs for speed and color palette: 1) text label version: The rom is the same named "Space Invaders (Unknown) (PAL)" in rom's collection. This version is slower than the other two. 2) picture label 1 This is the "darker" version (see this thread). Player 1 and the mothership use really dark colors and are difficult to see on the TV screen. This is faster than the previous version. The cart has a "41 2 R" code stamped on the end label which should indicate the production date (41th week of 1982). 3) picture label 2 This version shows brigther colors while keeping the speed of the darker version. "12 3 R" code on end label. This is the PAL space invaders rom on rom's collection. These variations all use the same B&W palette (selected using the TV TYPE switch), therefore they will look the same on a Secam console. space_invaders_PAL.zip Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 20, 2008 Author Share Posted September 20, 2008 Very good! I'll see if I can find where the differences lay, but if Nukey or anyone else beats me to it that is fine too. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 20, 2008 Share Posted September 20, 2008 It appears to be fairly obvious (without disassembly) what the story is. The initial PAL release (file 1) didn't have timing adjusted for 50hz, and there were issues with the colors as well. The revision (file 2) corrects the timing, but the colors were too dark. File 3 replaces it. Clonespy reflects this hypothesis. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 20, 2008 Author Share Posted September 20, 2008 (edited) I've integrated version 2 & version 3 so far. Version three has a branch after the BIT instruction at $FB44 which looks more right to me then version's two lack of branch. The extra two bytes are balanced by taking two bytes out of the string of $00 before $FC page. Then the only difference is a small table which I'm presuming is colors (haven't checked. SpIn_PAL_v2_v3.zip Edited September 20, 2008 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 20, 2008 Share Posted September 20, 2008 The table is the colors chosen. They are in this order: Shield, UFO, Player 1, Player 2, Invaders, Missiles, Sky color, Ground color. The branching instruction swaps joystick control (so co-op game selections that involve alternately switching control from one stick to another will not work correctly with ver.2). All other versions share the original unaltered code for this routine. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 20, 2008 Author Share Posted September 20, 2008 Version 1 to version 2 sees a lot of changes in the code. I can't do anymore tonight and probably won't over the next week (not enough time with school). Nukey to be clear you are saying version 2 is disfunctional, and version 3 is good? Version three shares the unaltered code with all the other versions except 2? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 20, 2008 Share Posted September 20, 2008 Regarding this aspect, yes. Of the three PAL versions you posted, ver.1 shares the most identical code & data with the NTSC version. The missing branch in ver.2 is the only difference between all of them for the input routine. Clonespy results (si0=NTSC): Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 20, 2008 Share Posted September 20, 2008 BTW the game option affected is the two-player partnership game with alternating firing and control of the cannon (game selections 81-96, mentioned on page 11 of the manual). The way it's supposed to work is that the left player has total control of the cannon for odd shots (starting with the first one), the right player has total control for even shots. In ver.2, the branch to use the left stick is missing...so the right player always moves the cannon (the players still alternate shots, tho). Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted September 20, 2008 Share Posted September 20, 2008 Ok, Second version added to my collection now and first and third version renamed. Many thanks! Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted September 20, 2008 Share Posted September 20, 2008 (edited) BTW: All three different PAL versions can be seen in non-US Space Invaders commercials on this page: http://atarimania.com/detail_soft.php?VERS...8353&MENU=2 - Video 14 (version 2) - Video 16 (version 3) - Video 27 (version 1) Never noticed this before. Edited September 20, 2008 by Rom Hunter Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 20, 2008 Author Share Posted September 20, 2008 (edited) Regarding this aspect, yes. Of the three PAL versions you posted, ver.1 shares the most identical code & data with the NTSC version. The missing branch in ver.2 is the only difference between all of them for the input routine. Clonespy results (si0=NTSC): It all makes sense then and corresponds with the date stamps that Alex_79 posted. Version1 (original) - belongs to the text label, first conversion by Atari - seems rushed as the speed is not corrected Version2 (alternate 1) - picture label, date stamped 41 2 R (41st week of 1982) - corrected speed, changed some colors - took out swapping controllers branch and caused a glitch Version3 (alternate 2) - picture label date stamped 12 3 R (12th week of 1983) - corrected glitch from version 2 - changed some colors again I'm not going to disassemble the first version now as the pattern of change seems obvious. I'm really glad Alex posted those scans and date stamps. Really helps to know what rom belongs to what cart. Edited September 20, 2008 by Omegamatrix Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 21, 2008 Share Posted September 21, 2008 I'm not going to disassemble the first version now as the pattern of change seems obvious.Actually, there's something interesting in the first PAL version. Just above the shield display, 3 NOP instructions were added as placeholders at $F109. I wonder if a JSR was planned on being inserted there to handle something that the original game didn't (like partially-erased shields)? Anyway, quite a number of routines have been moved around between ver.1 and 2...so trying to link them into your 2+3 disassembly would be messy. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted September 21, 2008 Author Share Posted September 21, 2008 Anyway, quite a number of routines have been moved around between ver.1 and 2...so trying to link them into your 2+3 disassembly would be messy. You're right. I gave up as it was becoming too incoherent. It should be easier to integrate the NTSC and PAL version 1, but I don't have time and it looks like you've done a comparision already. I'm not even sure how to make an assembly with lots of shifting of routines. Maybe something like SEG.U SOME_ROUTINE? ; the address at this point is $F0FF SEG.U SOME_ROUTINE IF PAL ORG $FC00 ELSE ORG $F100 ; NTSC version ENDIF .byte data here .byte data here .byte data here SEG code I'm not sure if that would work. Would DASM automatically fill the the space from $F0FF to $FBFF with bytes of $FF for the PAL version (and make the rom larger then 4k)? Would you have to something with ORG and RORG? Partially erased shields would have been cool. Are there any flashing shields when they take too much damage? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted September 22, 2008 Share Posted September 22, 2008 Overthinking the problem. It's far easier to define macros for identical routines that shift in memory between versions...then just call them between lines of code that is more consistant. It's still messy, but far more readable. Are there any flashing shields when they take too much damage?I dunno what you mean by this. There's no version of SI that checks on the current condition of a shield. It's just mapped in RAM, and deteriorates as the ball sprite (missile) collides. The arcade game includes collisions with the invaders themselves. Erasing the shields is just a theory that has no supporting evidence (other than placeholder NOPs where the aspect could be added). It could be relatively easy to pull off tho...because the loop that displays them can begin at any offset (the Y index register is hard-coded to begin at zero). The only problem in the existing kernal is that there would be a few scanlines' difference between the bottom of the invaders and the displayed portion of the shields...so it wouldn't look much like they are erasing them as in the arcade game. Quote Link to comment Share on other sites More sharing options...
Hornpipe2 Posted October 8, 2008 Share Posted October 8, 2008 Poking around at some 4k alternate versions. * There are two versions of Apollo's Lost Luggage. The [a] version is Lost Luggage with Intro - this is the Blue Label as described on AtariMania. http://www.atarimania.com/detail_soft.php?...VERSION_ID=8133 The standard Lost Luggage is the Original - fewer points, fire button restart, no intro. I guess this came first. I don't know much about Apollo label variations. * Mr. Postman - O Cartiero (1983) (CCE) (C-801) [a] - has extra lines in front of your score, as though the height counter was one too large. Mr. Postman - O Cartiero (1983) (CCE) (C-801) does not have this problem and looks right * No Escape [a] - has some problems when trying to fire towards the right, and often the left as well. What was the source for this broken image? No Escape works fine. * Spinning Fireball - has copyright notice Spinning Fireball [a] - copyright notice has been removed. And there is another change too, but I can't tell what it does. Can anyone help me figure out what the differences are in the original vs alternate releases of... Bridge Championship Soccer Crackpots Enduro Gas Hog [this one has different colors!] Halloween International Soccer Racquetball River Raid Super Breakout Yar's Revenge Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted October 10, 2008 Author Share Posted October 10, 2008 The original bridge has a bad branch by mistake (It jumps in between an instruction and the operand). The alternate corrects this mistake and has a different value at $FEFF. I haven't investigated this yet. Presumably the alternate is the fixed version as jumping between the instruction and operand could cause the game to crash. I remember Homer dumped the new Gas Hog a while back. It has the correct colors and a stable scan line count. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 10, 2008 Share Posted October 10, 2008 (edited) * No Escape [a] - has some problems when trying to fire towards the right, and often the left as well. What was the source for this broken image?No Escape works fine. If nobody has a cartridge program that matches [a], it's a bad dump. Otherwise, it would be the earliest 2600 program that contains an illegal instruction. No Escape @ $1800: STX WSYNC No Escape [a] @ $1800: NOP VSYNC (a 3 cycle NOP). Interestingly...this "error" fixes the added scanline when Pegasus appears at the end of the game (bumping to 263 scanlines). The effect in [a] just delays coloring the ground area (look on the left...the first line will be off-color). The shooting problem happens later. A branching instruction opcode is changed to a store. The argument ($04), however, does NOT differ...adding weight to the "bad dump" theory. No Escape @ $1C00: BCS $1C06 No Escape [a] @ $1C00: STX NUSIZ0 The only other byte that differs is part of an animation frame, and has no effect on the function of the game. No Escape @ $1001: .byte %00100100 No Escape [a] @ $1001: .byte %00100000 You'll see this missing pixel on the first enemy. One leg will have a gap before the foot. Edited October 10, 2008 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted October 10, 2008 Share Posted October 10, 2008 I think it's fair to say that it's a bad dump. I've never heard or read anything about these "glitches" in the official released version. But perhaps Omega can check out any differences between the Picture label and the Canadian text label? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 10, 2008 Share Posted October 10, 2008 (edited) Championship Soccer, Crackpots and Enduro: The only difference is the very last byte in the rom (the MSB of the interrupt vector). Since interrupts are not used in these games, this makes no difference. Could be bad dumps in any case. Edited October 10, 2008 by Nukey Shay Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 10, 2008 Share Posted October 10, 2008 Halloween: There's a single pixel difference in the player's blank area. Address $3C0E is blank in [!], and $08 in [a]. Try walking upward to see it. Verdict: bad dump Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 10, 2008 Share Posted October 10, 2008 International Soccer: I dunno which version you are referring to. International Soccer (1982) (Mattel) (PAL) [p1][!].bin? The alternate NTSC version is already confirmed to be a bad dump. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted October 10, 2008 Share Posted October 10, 2008 Racquetball: 5 values are changed. ($72F2) cmp #$0F ;2 $07 in alternate L772A: .byte $14; | X X | $772A $10 in alternate .byte $10; | X | $772B $0F in alternate L772C: .byte $03; | XX| $772C $07 in alternate .byte $07; | XXX| $772D $08 in alternate [a] might have been an earlier version, because serves have a tendancy to go straight up. [!] provides better angles. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted October 10, 2008 Share Posted October 10, 2008 Interesting. I'm going to remove these ROMs from my V4 collection, except for Racquetball. Many thanks, Nukey! Quote Link to comment Share on other sites More sharing options...
