carlsson Posted April 17, 2020 Share Posted April 17, 2020 On 9/8/2015 at 12:40 AM, CatPix said: The odd, 16.7V measurement on the Intelli II might be due to the fact that they measured it with no load. Heavy copper transformers output more voltage with no load. For example, a standard Atari 2600 power supply can be measured up to 13V with no load. The voltage drop to 8/9/10V when the console is powered on and draw current. Necro posting due to the topic was brought up on the AtariAge Facebook group and I linked to this thread. I thought about another theory: What if Mattel printed the peak value instead of the RMS value? 12V AC RMS * sqrt(2) = 16.97V peak. It could explain why a 9V AC or 9V DC power supply is good enough since it is only a few volts below 12. Someone who owns a Intellivision II with original power supply should measure it to see if the multimeter reads out 16.7V AC or a lower figure without load. 1 Quote Link to comment Share on other sites More sharing options...
Agamenon Posted June 11, 2020 Share Posted June 11, 2020 Hello everyone, I have an intellivision II without power source, I will try to adapt a 9V to see if it turns on Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted October 26, 2020 Share Posted October 26, 2020 (edited) Quadruple necrobump! How's that? I just got a Inty II that I'm refurbishing to resell, changed the pico fuse and now the power supply is flaky. I need to replace tip of the power supply (on the cord) since it's internally broken and I have to mess with it to get it to work. Anyone know what size the plug is? I want to order a new one and solder it on the cord but need the right size. Any help is greatly appreciated. Thanks Edited October 26, 2020 by vintagegamecrazy Quote Link to comment Share on other sites More sharing options...
nick3092 Posted October 27, 2020 Share Posted October 27, 2020 15 hours ago, vintagegamecrazy said: Quadruple necrobump! How's that? I just got a Inty II that I'm refurbishing to resell, changed the pico fuse and now the power supply is flaky. I need to replace tip of the power supply (on the cord) since it's internally broken and I have to mess with it to get it to work. Anyone know what size the plug is? I want to order a new one and solder it on the cord but need the right size. Any help is greatly appreciated. Thanks Plug with pigtail: https://console5.com/store/dc-pigtail-plug-cord-for-atari-5200-intv-ii-tg16-cd-dock-twin-famicom-dc.html Plug only: https://console5.com/store/turbografx-16-cdrom-dock-power-connector.html Quote Link to comment Share on other sites More sharing options...
vintagegamecrazy Posted October 28, 2020 Share Posted October 28, 2020 Quadruple necrobump! How's that? I just got a Inty II that I'm refurbishing to resell, changed the pico fuse and not the power supply is flaky. I need to replace tip of the power supply (on the cord) since it's internally broken and I have to mess with it to work. Anyone know what size the plug is? I want to order a new one and solder it on the cord but need the right size. Any help is greatly appreciated. Thanks Great! Thanks for the tip. I'm going to order one right away! Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted October 28, 2020 Share Posted October 28, 2020 Since the 5200 supply will fit just fine that would mean the plug end has to be 2.5x5.5mm in size female. Quote Link to comment Share on other sites More sharing options...
Ghosthouse Posted October 16 Share Posted October 16 Will a genesis model 2 power supply work with intellivision 2? Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted October 18 Share Posted October 18 On 10/16/2023 at 3:41 PM, Ghosthouse said: Will a genesis model 2 power supply work with intellivision 2? No because it won't fit, the tip size is too small for the INTV II's AC jack. Quote Link to comment Share on other sites More sharing options...
