Multisprite guidance
|*BILLY$CLINT*|
Okay I am working on the following code that comes with bB trying to get a player and then 5 sprites that the player has to battle. But at the present point in time I can only get two sprites to display, the player and the bad guys. I was reading the manual and it mentioned something about the multisprite kernel but I am not sure how to use it or where to access it from. Is there any one that can let me in on the secret.
Currently I am using windows XP service pack 2 and I am running the Crimson Editor 3.70 and bB 1.0. I tried the bleeding edge build but it did not work, i keep getting compile errors so I switched back to the normal version and the following code will compile no problem.
I am very new at this and am trying hard to get this so please forgive me if this request for help sounds primitive. Also if you do lend a hand please make comments so that I can see and understand what you did. I want to learn what is going on.
set smartbranching on
10 player1x = 40 : player1y = 40: player0x = 50 : player0y = 50
20 COLUPF = 90:missile0height=4:missile0y=255
25 score=10000
30 COLUP0 = 120
35 COLUP1 = 14
40 scorecolor = 10:NUSIZ0=16
45 player0:
%01000010
%11111111
%11111111
%01111110
%00111100
%00011000
%00011000
%00011000
end
46 player1:
%00111100
%00011000
%00011000
%00011000
%11100111
%10100101
%10011001
%00100100
end
47 a = a + 1 : if a < 2 then 55 rem55
49 a = 0
50 if player1y < player0y then player1y = player1y + 1
51 if player1y > player0y then player1y = player1y - 1
52 if player1x < player0x then player1x = player1x + 1
53 if player1x > player0x then player1x = player1x - 1
54 player1x = player1x : player1y = player1y
55 if missile0y>240 then 58
57 missile0y=missile0y-2:goto 59
58 if joy0fire then missile0y=player0y-2:missile0x=player0x+4
59 drawscreen
60 if collision(missile0,player1) then score=score+1:player1x=rand/2:player1y=0:missile0y=255
65 if collision(player0,player1) then score=score-1
70 if joy0up then player0y = player0y - 1
80 if joy0down then player0y = player0y + 1
100 if joy0left then player0x = player0x - 1
120 if joy0right then player0x = player0x + 1
140 goto 30
Thanks
|*BILLY$CLINT*|
Edited by |*BILLY$CLINT*|
After looking at your code the way that you did everything makes alot of sense and I can kind of figure it out. But since I dont want to rip it off I have been trying to make my code similar to it but I have run into a wall now all I get is the following error and it will not compile.
---------- Capture Output ----------
> "C:\Atari2600\bB\2600bas.bat" C:\Atari2600\bB\samples\NERDSTest
(80) Error: Unknown collision type: (missile0,player2)
Compilation failed.
> Terminated with exit code 0.
Here is the code. It has a few comments/ question in it that i have made as I went along with things that I dont understand.
rem |*BILLY$CLINT*| code use from Crimson Editor for the base of my game
rem 04.14.07
rem okay first what are the number for I cant figure that out for example
rem "20 COLUPF = 90:missile0height=4:missile0y=255" why does this line start with 20?
1 set smartbranching on
2 set kernel multisprite
COLUBK=64 : rem background color
COLUP0=46 : rem not know
10 player1x = 40 : player1y = 40: player0x = 50 : player0y = 50: player2x = 45 : player2y =
25 score=10000  : rem score amount
30 COLUP0 = 120 : rem player color
35 COLUP1 = 14	: rem badguy color
40 scorecolor = 10:NUSIZ0=128 : rem this is the score color but not sure what NUSIZ0 is?
 player0:	 : rem this is the player
%01000010
%11111111
%11111111
%01111110
%00111100
%00011000
%00011000
%00011000
end
 player1:		: rem this is the bad guy
%00111100
%00011000
%00011000
%00011000
%11100111
%10100101
%10011001
%00100100
end
player2:	   :  rem this is suppose to be another bad guy
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
end
49 a = 0
50 if player1y < player0y then player1y = player1y + 1 : rem I think this is the A.I for the Bad guys
54 player1x = player1x : player1y = player1y :rem not sure what this is
58 if joy0fire then missile0y=player0y-2:missile0x=player0x+4 :rem I think this fires and draws the missles
59 drawscreen
61 if collision(missile0,player2) then score=score+1:player2x=rand/2:player2y=0:missile0y=255  :rem this is the player and the Bad Guy collision
66 if collision(player0,player2) then score=score-1
70 if joy0up then player0y = player0y - 1   : rem this is the joy pad momement
140 goto 30
Compilation failed.
Here is the code. It has a few comments/ question in it that i have made as I went along with things that I dont understand. Also, if I remember right, you can't set missile height in the multisprite kernel, you'll have to remove that statement.
rem 04.14.07
%01000010
%11111111
%11111111
%01111110
%00111100
%00011000
%00011000
%00011000
end
%00111100
%00011000
%00011000
%00011000
%11100111
%10100101
%10011001
%00100100
end
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
%00000000
end
49 a = 0
59 drawscreen
140 goto 30
I do see one obvious problem in the code, In line 10 you need to put a numeric value at the end, you have an "= <blank> ".
Steve
Edited by Atarius Maximus
I keep seeing more things, sorry for the multiple posts. You'll also have to add this line immediately before the set kernel multisprite line:
includesfile multisprite_bankswitch.inc : rem
The :rem at the end may not be necessary anymore, it was with the bleeding edge builds.
Steve
Ah, I found one more thing. Sorry, I read through your post so quickly the first time I missed an obvious thing. There is a problem with this code:
You can only specify player0 and player1 in any collision detection statement. Player sprites 2 through 5 are virtual copies of player 1, so the only way to detect a collision with them is to compare the X and Y coordinates of those sprites with the item you're trying to detect a collision with. I had forgotten about that and had to change the code in my Turbo demo that I'm working on -- the player car and oncoming traffic sprites HAD to use player0 and player1 to simplify colliision detection. I've been playing around with the multisprite kernel for a pretty long time, I'll be happy to answer more questions for you if you run into more problems.
Steve
