Gorf Posted April 20, 2007 Share Posted April 20, 2007 (edited) I did not see much in the way of error codes in the batari manual(of course I may have missed it or looked in the wrong spot.) but I came across this trying to compile a multisprite version of gorf vertically M:\Atari2600\bB>2600bas gorfv.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler (C)1988-2003 bytes of ROM space left --> cycle74_HMCLR f07b M:\ATARI2~1\bB> I guess Im stufing to many cycles in the loop? Edited April 20, 2007 by Gorf Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted April 20, 2007 Share Posted April 20, 2007 I did not see much in the way of error codes in the batari manual(of course I may have missed it or looked in the wrong spot.) but I came across this trying to compile a multisprite version of gorf vertically M:\Atari2600\bB>2600bas gorfv.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler (C)1988-2003 bytes of ROM space left --> cycle74_HMCLR f07b M:\ATARI2~1\bB> I guess Im stufing to many cycles in the loop? sometimes thats not error because the game still works(unless when you ran it it crashed) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted April 21, 2007 Share Posted April 21, 2007 I did not see much in the way of error codes in the batari manual(of course I may have missed it or looked in the wrong spot.) but I came acroos this trying to comile something M:\Atari2600\bB>2600bas gorfv.bas 2600 Basic compilation complete. DASM V2.20.07, Macro Assembler (C)1988-2003 bytes of ROM space left --> cycle74_HMCLR f07b M:\ATARI2~1\bB> I guess Im stufing to many cycles in the loop? Chances are, that's not an error, but simply a warning message. If your program is the correct size (2K, 4K, 8K, 16K, or 32K, whichever size you specified), and if it runs okay, then that isn't an error. DASM is a multi-pass assembler, and during the first pass it will assign addresses to all the program labels. But the batari Basic kernel and includes routines can contain a lot of compiler directives that tell DASM to use different sections of assembly code depending on things like which kernel options have been specified. And for other possible reasons as well, sometimes DASM can start out thinking that a particular label will correspond to a particular address-- but by the time DASM has made as many passes as it needs to in order to resolve all the label references and plug them into the code, it may turn out that some of the labels correspond to different addresses than originally expected. So what you're seeing is a message telling you that the label "cycle74_HMCLR" turned out to have a different address than expected. The batari Basic compile batch actually suppresses all these types of messages, except for the first one encountered-- so if you were to modify the compile batch to remove that suppression, you'd see a *lot* more messages of this type. Michael Quote Link to comment Share on other sites More sharing options...
Gorf Posted April 21, 2007 Author Share Posted April 21, 2007 Is that a bug in batari or DASM or just bad coding on my part? Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 14, 2007 Author Share Posted May 14, 2007 Im really anal about such messages. I seem to get tham from time to time, even though like you all said the code still works. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 14, 2007 Share Posted May 14, 2007 Im really anal about such messages. I seem to get tham from time to time, even though like you all said the code still works. I don't think there's anything you can do about them. It isn't a bB bug-- if anything, I'd say it's an issue with DASM. And the funny thing is, you can compile the program and get the message, then add a little bit more code to your program and the message is gone, then add more code and it's back again, etc. Michael Quote Link to comment Share on other sites More sharing options...
+batari Posted May 14, 2007 Share Posted May 14, 2007 Im really anal about such messages. I seem to get tham from time to time, even though like you all said the code still works. I don't think there's anything you can do about them. It isn't a bB bug-- if anything, I'd say it's an issue with DASM. And the funny thing is, you can compile the program and get the message, then add a little bit more code to your program and the message is gone, then add more code and it's back again, etc. Michael For the next release of bB, I am including a customized version of DASM. Aside from other things, this version will automatically suppresses most of the bogus error messages and minor annoyances. This was necessary because with some really large bB source files, DASM started to choke on them and not assemble at all. The problem was that DASM would sometimes abort when it thought that a branch was out of range. If DASM had just given it another pass, the branch would have resolved within range. I fixed this problem by making DASM try a few more passes before giving up on branches. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 14, 2007 Author Share Posted May 14, 2007 For the next release of bB, I am including a customized version of DASM. Aside from other things, As long as it still works and is not a problem I can live with it. I'd much rather see you spend the time on something like defines.....I'd be right there helping with this stuff if I were not such a novice on this machine. ...on that note, if you guys think I may be able to help you with batari's improvements, by all means ask. I dont know if it is possible or not with the 'dim' statement but if not, can you add #defines so I can use defines for a bit in a variable? like #define GAMEOVER = a{x} if GAMEOVER then goto gameover Now that would be shuga sweet! Quote Link to comment Share on other sites More sharing options...
+batari Posted May 14, 2007 Share Posted May 14, 2007 For the next release of bB, I am including a customized version of DASM. Aside from other things, As long as it still works and is not a problem I can live with it. I'd much rather see you spend the time on something like defines.....I'd be right there helping with this stuff if I were not such a novice on this machine. ...on that note, if you guys think I may be able to help you with batari's improvements, by all means ask. I dont know if it is possible or not with the 'dim' statement but if not, can you add #defines so I can use defines for a bit in a variable? like #define GAMEOVER = a{x} if GAMEOVER then goto gameover Now that would be shuga sweet! That's a good idea, as things can get a little vague with all the bit twiddling. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 15, 2007 Author Share Posted May 15, 2007 For the next release of bB, I am including a customized version of DASM. Aside from other things, As long as it still works and is not a problem I can live with it. I'd much rather see you spend the time on something like defines.....I'd be right there helping with this stuff if I were not such a novice on this machine. ...on that note, if you guys think I may be able to help you with batari's improvements, by all means ask. I dont know if it is possible or not with the 'dim' statement but if not, can you add #defines so I can use defines for a bit in a variable? like #define GAMEOVER = a{x} if GAMEOVER then goto gameover Now that would be shuga sweet! That's a good idea, as things can get a little vague with all the bit twiddling. Well I guess you can do something like, 'dim' a name like say...'gamestats' but 'gamestats{x}' is not as readable as 'gamestats{GAMEOVER}' would be. Again, if I was not so busy with contract work right now, I'd be all over helping you guys with this. I would LOVE to make a version a batari for the Jaguar. Now that we can run code from main RAM off the RISC's in the Jaguar, it would be a more practical way to do things. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 15, 2007 Share Posted May 15, 2007 I dont know if it is possible or not with the 'dim' statement but if not, can you add #defines so I can use defines for a bit in a variable? like #define GAMEOVER = a{x} if GAMEOVER then goto gameover Now that would be shuga sweet! That's a good idea, as things can get a little vague with all the bit twiddling. Well I guess you can do something like, 'dim' a name like say...'gamestats' but 'gamestats{x}' is not as readable as 'gamestats{GAMEOVER}' would be. You should be able to do "gamestats{GAMEOVER}" right now, as follows: dim gamestats = a const GAMEOVER=0 rem *** or whichever bit you're using to mean GAMEOVER rem *** a bunch of code, then... if gamestats{GAMEOVER} then goto restart_game Michael Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 15, 2007 Share Posted May 15, 2007 You should be able to do "gamestats{GAMEOVER}" right now, as follows: dim gamestats = a const GAMEOVER=0 rem *** or whichever bit you're using to mean GAMEOVER rem *** a bunch of code, then... if gamestats{GAMEOVER} then goto restart_game Michael Never mind, the batari Basic compiler views that as trying to use a variable with bit access, and won't let you do it. I thought it would realize that "GAMEOVER" is a *constant*, and use "0." Michael Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 15, 2007 Author Share Posted May 15, 2007 You should be able to do "gamestats{GAMEOVER}" right now, as follows: dim gamestats = a const GAMEOVER=0 rem *** or whichever bit you're using to mean GAMEOVER rem *** a bunch of code, then... if gamestats{GAMEOVER} then goto restart_game Michael Never mind, the batari Basic compiler views that as trying to use a variable with bit access, and won't let you do it. I thought it would realize that "GAMEOVER" is a *constant*, and use "0." Michael It would really rock to have defines for anything. this stuff is loads of fun, nonetheless. Quote Link to comment Share on other sites More sharing options...
+batari Posted May 15, 2007 Share Posted May 15, 2007 It would really rock to have defines for anything. this stuff is loads of fun, nonetheless. I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 16, 2007 Author Share Posted May 16, 2007 It would really rock to have defines for anything. this stuff is loads of fun, nonetheless. I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. That would be fantastic! It can only make stuff much more readable. Quote Link to comment Share on other sites More sharing options...
CurtisP Posted May 16, 2007 Share Posted May 16, 2007 I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. I think the syntx in this cse should be def foo = bar Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 16, 2007 Author Share Posted May 16, 2007 I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. I think the syntx in this cse should be def foo = bar I would dig the #define like in C but I could live with 'def' as well. Quote Link to comment Share on other sites More sharing options...
+batari Posted May 16, 2007 Share Posted May 16, 2007 I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. I think the syntx in this cse should be def foo = bar I would dig the #define like in C but I could live with 'def' as well. I'm gonna go with def foo=bar, as it's consistent with other bB syntax. Actually, I added the feature last night. It operates as just a simple replacement, and I've already started using it for redefining bits (def BOSSLEVEL=level{7} was the first test, and it worked!) This brought up another idea. In C, #define can also take arguments, e.g. #define foo(a)=(bar+a)/2. It's kind of like a macro but limited to a single line. So I'd say to keep define for simple replacements and also add a macro command that can use arguments and multiple lines, e.g.: macro foo(bar, baz) if bar=baz then baz=baz+1 if bar<baz then baz=bar end This will be a little harder and likely won't get done in a single evening... Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 17, 2007 Author Share Posted May 17, 2007 I think that defines could be done in the general case and not just for bits. I could modify bB's preprocessor to remember the defines and swap in the replacement text before the compiler sees them. I think the syntx in this cse should be def foo = bar I would dig the #define like in C but I could live with 'def' as well. I'm gonna go with def foo=bar, as it's consistent with other bB syntax. Actually, I added the feature last night. It operates as just a simple replacement, and I've already started using it for redefining bits (def BOSSLEVEL=level{7} was the first test, and it worked!) This brought up another idea. In C, #define can also take arguments, e.g. #define foo(a)=(bar+a)/2. It's kind of like a macro but limited to a single line. So I'd say to keep define for simple replacements and also add a macro command that can use arguments and multiple lines, e.g.: macro foo(bar, baz) if bar=baz then baz=baz+1 if bar<baz then baz=bar end This will be a little harder and likely won't get done in a single evening... Im quite fine with 'def'...it is probably more closer to basic syntax anyway. BTW, Also, 'on goto' is absoluty perfect and well beyond anything I expected efficiency wise. I saved at least a bank and a half. How hard would it be to implement 'on gosub'? Quote Link to comment Share on other sites More sharing options...
+batari Posted May 17, 2007 Share Posted May 17, 2007 Im quite fine with 'def'...it is probably more closer to basic syntax anyway. BTW, Also, 'on goto' is absoluty perfect and well beyond anything I expected efficiency wise. I saved at least a bank and a half. How hard would it be to implement 'on gosub'? Shouldn't be too hard. I just haven't got around to adding it. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 17, 2007 Share Posted May 17, 2007 How hard would it be to implement 'on gosub'? I was going to say that it probably wouldn't be a good idea, but then I saw how "on...goto" is being implemented, and I think it should be easy to do, as follows (in assembly): .L00 ; on n gosub line1 line2 line3 line4 LDX n LDA #>(.L01-1) PHA LDA #<(.L01-1) PHA LDA .L00jumptablehi,x PHA LDA .L00jumptablelo,x PHA RTS .L00jumptablehi BYTE >(.line1-1) BYTE >(.line2-1) BYTE >(.line3-1) BYTE >(.line4-1) .L00jumptablelo BYTE <(.line1-1) BYTE <(.line2-1) BYTE <(.line3-1) BYTE <(.line4-1) .L01 ; rem * continue here after returning NOP; etc. etc. .line1 NOP; etc. etc. RTS .line2 NOP; etc. etc. RTS .line3 NOP; etc. etc. RTS .line4 NOP; etc. etc. RTS Michael Quote Link to comment Share on other sites More sharing options...
+batari Posted May 17, 2007 Share Posted May 17, 2007 How hard would it be to implement 'on gosub'? I was going to say that it probably wouldn't be a good idea, but then I saw how "on...goto" is being implemented, and I think it should be easy to do, as follows (in assembly): Hmm... it's easier than I thought. I'll just expand the on...goto handling to add a few extra lines of code if gosub is used. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 17, 2007 Author Share Posted May 17, 2007 How hard would it be to implement 'on gosub'? I was going to say that it probably wouldn't be a good idea, but then I saw how "on...goto" is being implemented, and I think it should be easy to do, as follows (in assembly): Hmm... it's easier than I thought. I'll just expand the on...goto handling to add a few extra lines of code if gosub is used. Yeah, having an on gosub would eliminate the need to gosub after the on goto. Quote Link to comment Share on other sites More sharing options...
