mimo Posted April 25, 2007 Share Posted April 25, 2007 trying to convert some images using a Wondows XP laptop. dummies step by step guide if possible,I have read the text, but I am pretty useless with dos prompts etc thanks once again Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 25, 2007 Share Posted April 25, 2007 From the file in the Zip: How it works? Let us assume I have a file "seawolf2.xex". I write: xex2cas seawolf2.xex seawolf2.cas And now in my directory I have seawolf as a cas file. Next of course use cas2wav and write the file to tape. Unlike the CAS2WAV, you have to run this program from a Command Prompt. Quote Link to comment Share on other sites More sharing options...
mimo Posted April 25, 2007 Author Share Posted April 25, 2007 From the file in the Zip: How it works? Let us assume I have a file "seawolf2.xex". I write: xex2cas seawolf2.xex seawolf2.cas And now in my directory I have seawolf as a cas file. Next of course use cas2wav and write the file to tape. Unlike the CAS2WAV, you have to run this program from a Command Prompt. fair enough, but I am totally thick! does the .xex have to be in a particular location? Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted April 25, 2007 Share Posted April 25, 2007 To use that syntax, the .xex would have to be in the same directory as xex2cas. Otherwise you'd have to specify the full path rather than just the filename. Quote Link to comment Share on other sites More sharing options...
mimo Posted April 25, 2007 Author Share Posted April 25, 2007 another thing learned! Quote Link to comment Share on other sites More sharing options...
