Lumpy01 Posted May 8, 2007 Share Posted May 8, 2007 Has anybody ever try using the 5200 video mod board found at 8bitdomain.com in an 8-bit Atari computer, preferably and 800XL? Since the hardware is virtually identical, couldn't this work? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 8, 2007 Share Posted May 8, 2007 Why? The Atari 8-bit computers already have it built in, you don't need an extra board, just the right cable. Mitch Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 8, 2007 Share Posted May 8, 2007 I don't see why it shouldn't work, although clearance might be an issue. Maybe it would give better quality video since it's getting a direct feed from GTIA. But, it is replicating something that is already there - and adding chroma to XLs monitor ports that don't have it is usually a simple job. Quote Link to comment Share on other sites More sharing options...
Urchlay Posted May 8, 2007 Share Posted May 8, 2007 It might be worth doing this to a 1200XL. The video quality of an unmodified 1200XL is abysmal, and doesn't get much better if you add a chroma wire. The Clearpic or Supervideo mods are just about mandatory... maybe the 8bitdomain 5200 mod would give even better quality? Or maybe it'd be easier to install, for us solder-challenged individuals? Quote Link to comment Share on other sites More sharing options...
8bitdomain Posted May 8, 2007 Share Posted May 8, 2007 Has anybody ever try using the 5200 video mod board found at 8bitdomain.com in an 8-bit Atari computer, preferably and 800XL? Since the hardware is virtually identical, couldn't this work? Yes, electrically it will work in ANY system that uses the GTIA. Mechanically I am not sure if there is clearance in all systems. Mike Quote Link to comment Share on other sites More sharing options...
classics Posted May 8, 2007 Share Posted May 8, 2007 I've built a similar gtia plug in module and it worked as well in my 1200xl as it did in the 5200 I built it in originally. Steve Quote Link to comment Share on other sites More sharing options...
