Gorf Posted May 14, 2007 Share Posted May 14, 2007 I wonder, just how fine can the pixels of the playfield be horizontally? I dont mean only in batari basic but a hand written kernel if needed. Right now we get 16 reflected pixel, or 32 pixels across asymetrically. Can the 2600 achive higher resolution than this? batari or asm ? Thanks Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted May 14, 2007 Share Posted May 14, 2007 Playfield pixels are and always will be the same width - 4 color-clocks. 20 bits control what is displayed...spread out to 3 registers (only the upper nybble is used for PF0). An additional register dictates whether these should be repeated or reflected for the right side of the screen, and a coding technique can be used to do neither (for asymmetrical display). So the maximum horizontal resolution for playfield gfx is/always will be 40 pixels in assembly. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 14, 2007 Author Share Posted May 14, 2007 Playfield pixels are and always will be the same width - 4 color-clocks. 20 bits control what is displayed...spread out to 3 registers (only the upper nybble is used for PF0). An additional register dictates whether these should be repeated or reflected for the right side of the screen, and a coding technique can be used to do neither (for asymmetrical display).So the maximum horizontal resolution for playfield gfx is/always will be 40 pixels in assembly. Thanks! Quote Link to comment Share on other sites More sharing options...
