Gorf Posted May 16, 2007 Share Posted May 16, 2007 Is the following possible some how in batari, even perhaps with the 'asm' statement? Keep in mind this is a multi-sprite kernel, using 32 rom bankswitching includesfile multisprite_superchip.inc includesfile multisprite_bankswitch.inc set kernel multisprite set romsize 32kSC ... ... other code ... gosub setdata bank 2 pos0 player0: %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx end return pos1 player0: %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx end return pos2 player0: %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx end return pos3 player0: %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx %xxxxxxxxx end return bank 3 data spriteframes pos0,pos1,pos2,pos3 end setdata goto spriteframes[x] bank2 I know this is not right as the compiler complains but is there a way to do this? Like a vector table but with bank-jumping ability(right term???) thanks Quote Link to comment Share on other sites More sharing options...
+batari Posted May 16, 2007 Share Posted May 16, 2007 (edited) This is one solution. setdata is in another bank so you need to specify where it is, and you can use on...goto for determining cross-bank vectors, as follows: ... gosub setdata bank3 ... bank 3 setdata on x goto p0 p1 p2 p3 p0 goto pos0 bank2 p1 goto pos1 bank2 p2 goto pos2 bank2 p3 goto pos3 bank2 BTW, is there a reason why setdata needs to be in bank 3? It would run faster if you could place it in the bank that calls it. Edited May 16, 2007 by batari Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 16, 2007 Share Posted May 16, 2007 includesfile multisprite_superchip.inc includesfile multisprite_bankswitch.inc I would use "on x goto pos0 pos1 pos2" etc., as batari suggested. Note that you don't need to use both of the "includesfile" statements shown above, just one of them-- depending on whether or not you want to use the Superchip. That is, use of the Superchip implies that you're also using bankswitching-- and I made the "multisprite_superchip.inc" file from "multisprite_bankswitch.inc," so it has everything in it that you need for bankswitching. So use "includesfile multisprite_bankswitch.inc" if you want to do bankswitching with the multisprite kernel but don't want to use the Superchip, and use "includesfile multisprite_superchip.inc" (by itself) if you want to do bankswitching with the multisprite kernel and also want to use the Superchip. Michael Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 16, 2007 Author Share Posted May 16, 2007 This is one solution. setdata is in another bank so you need to specify where it is, and you can use on...goto for determining cross-bank vectors, as follows: ... gosub setdata bank3 ... bank 3 setdata on x goto p0 p1 p2 p3 p0 goto pos0 bank2 p1 goto pos1 bank2 p2 goto pos2 bank2 p3 goto pos3 bank2 BTW, is there a reason why setdata needs to be in bank 3? It would run faster if you could place it in the bank that calls it. yes...its in another bank as there will be a ton more frames like this. if the above more effcient(space wise/speed wise) than if x = 0 goto p0 if x = 1 goto p1 if x = 2 goto p2 if x = 3 goto p3 ? thanks as always Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 16, 2007 Author Share Posted May 16, 2007 includesfile multisprite_superchip.inc includesfile multisprite_bankswitch.inc I would use "on x goto pos0 pos1 pos2" etc., as batari suggested. Note that you don't need to use both of the "includesfile" statements shown above, just one of them-- depending on whether or not you want to use the Superchip. That is, use of the Superchip implies that you're also using bankswitching-- and I made the "multisprite_superchip.inc" file from "multisprite_bankswitch.inc," so it has everything in it that you need for bankswitching. So use "includesfile multisprite_bankswitch.inc" if you want to do bankswitching with the multisprite kernel but don't want to use the Superchip, and use "includesfile multisprite_superchip.inc" (by itself) if you want to do bankswitching with the multisprite kernel and also want to use the Superchip. Michael Ah ha! Did not realize that...sweet! I'll remove the non Sc one then. Thanks Mike. Quote Link to comment Share on other sites More sharing options...
+batari Posted May 16, 2007 Share Posted May 16, 2007 if the above more effcient(space wise/speed wise) than if x = 0 goto p0 if x = 1 goto p1 if x = 2 goto p2 if x = 3 goto p3 ? thanks as always On...goto is shorter if you have 3 or more targets. On...goto takes around 20 cycles no matter how many targets you have, so speed isn't much of a concern. Quote Link to comment Share on other sites More sharing options...
Gorf Posted May 16, 2007 Author Share Posted May 16, 2007 if the above more effcient(space wise/speed wise) than if x = 0 goto p0 if x = 1 goto p1 if x = 2 goto p2 if x = 3 goto p3 ? thanks as always On...goto is shorter if you have 3 or more targets. On...goto takes around 20 cycles no matter how many targets you have, so speed isn't much of a concern. On goto it is then! Thanks Batari. Quote Link to comment Share on other sites More sharing options...
