walter_J64bit Posted May 31, 2007 Share Posted May 31, 2007 Are there any 1010 mods out there? Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 1, 2007 Share Posted June 1, 2007 There's the one (from Poland?) which gives it turbo loading speed - fairly sure it's for the 1010. Don't have link though. Also, if you really wanted to, you could quite easily build an APE interface into a 1010. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 1, 2007 Author Share Posted June 1, 2007 There's the one (from Poland?) which gives it turbo loading speed - fairly sure it's for the 1010. Don't have link though. Also, if you really wanted to, you could quite easily build an APE interface into a 1010. That make would make an awesome mod! Quote Link to comment Share on other sites More sharing options...
Gunstar Posted June 1, 2007 Share Posted June 1, 2007 (edited) There's the one (from Poland?) which gives it turbo loading speed - fairly sure it's for the 1010. Don't have link though. Also, if you really wanted to, you could quite easily build an APE interface into a 1010. That make would make an awesome mod! You can build an SIO2PC/A.P.E interface into ANYTHING that has an SIO port(s). I have my SIO2PC&10502PC mods built into a 1050, well, it's actually in a seperate case of it's own, but permanently attached to the 1050 via a cable, the whole was drilled into the side where the cable enters and then the cable is directly soldered to one of the SIO ports of the 1050. Though now that I think about it, I may go ahead and just install the board directly into the 1050 and mount the two com ports on the back or side...maybe that will be my next project...depends if I decide i'm too lazy to bother or not, after all, if it ain't broke, why fix it? Edited June 1, 2007 by Gunstar Quote Link to comment Share on other sites More sharing options...
