Kyle22 Posted September 5, 2019 Share Posted September 5, 2019 (edited) What happens when this OS is used with Synchromesh or Super-Sync? IIRC, it is 68Kbps and 72Kbps. It uses the same protocol. High bit set on Command frame indicates that Data frame goes high speed. UltraSpeed sends both command and data frame at the negotiated speed. USDoubler and XF/Indus are different. Does this OS support Indus and its clones? Edited September 5, 2019 by Kyle22 clarity Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 5, 2019 Share Posted September 5, 2019 6 hours ago, Marius said: Is there anyone here who might want to test that on their setup? As a comparison, I just formatted a fresh DSDD disk with a stock XF551 running in it's native highspeed mode / 38400bps / POKEY divisor 16 ($10 in hex) with SpartaDOS X: Writing: 2265 B/sec Reading: 2281 B/sec So if you're getting 3K/sec, you're definitely faster than a stock unit, and your disk appears to have been formatted with an appropriately faster interleave. (We should stop using 'skew' as that technically refers to track-to-track layout offset) 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 5, 2019 Share Posted September 5, 2019 Yeah that's 38.4. Indus & clones do MUCH faster. 68K baud without track buffering, and 72K baud with. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 5, 2019 Share Posted September 5, 2019 For comparison... Speedy 1050 DDSS, at divisor 9, aka 56Kbps: 3560 B/sec write 3311 B/sec read Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 5, 2019 Share Posted September 5, 2019 ICD US Doubler 1050, Tandon Mech, original stepping rate, DDSS, "UltraSpeed" interleave, Divisor 10 ($0A in hex) aka 52.6Kbps 2948 B/sec write 2979 B/sec read Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 13, 2020 Share Posted March 13, 2020 bumping due to the discovery of XF's w/o a separate ROM: 2 Quote Link to comment Share on other sites More sharing options...
manterola Posted March 13, 2020 Share Posted March 13, 2020 Just a crazy idea to extract the FW from the Intel 8050 chip : maybe there is a way to extract the firmware they way that @warerat extracted it from the 850 (using an Atari program). I also found these two interesting links (they don't cover the 8050 specifically but it might help since it cover the same family of uP) http://bitsavers.trailing-edge.com/components/intel/8048/9800270D_MCS-48_Family_Users_Manual_Jul78.pdf https://www.eevblog.com/forum/microcontrollers/simple-programmer-for-vintage-intel-mcs-48-microcontroller/ This last one shows that Willem programmer might be compatible: http://www.mpu51.com/eprom/eprom3.htm Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted March 13, 2020 Share Posted March 13, 2020 5 hours ago, manterola said: Just a crazy idea to extract the FW from the Intel 8050 chip : maybe there is a way to extract the firmware they way that @warerat extracted it from the 850 (using an Atari program). I also found these two interesting links (they don't cover the 8050 specifically but it might help since it cover the same family of uP) I was reviewing the Alitrra Hardware Reference Manual and I see it currently only describes the XF551 with an 8040 CPU and external ROM. As per your discovery, maybe @phaeron would be interested to include a note about a variant using an 8050 with internal ROM. @hunmanik's Atari 8-bit FAQ also currently notes models with an 8050, but not about it using it's internal ROM. Unfortunately, I see nothing in the XF551's command table that could be used to read the ROM programmatically by software means... Quote Link to comment Share on other sites More sharing options...
MrMartian Posted March 13, 2020 Share Posted March 13, 2020 12 minutes ago, Nezgar said: Unfortunately, I see nothing in the XF551's command table that could be used to read the ROM programmatically by software means... No, and having disassembled the ROM, there is nothing in there. Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted March 14, 2020 Share Posted March 14, 2020 Just glancing at the Intel docs, the 8040 doesn't have a ROM area, but the 8050 does. My next question would be, are there 8050 XF551s with an external ROM? Quote Link to comment Share on other sites More sharing options...
Mathy Posted March 14, 2020 Share Posted March 14, 2020 Hello kheller2 Probably. I've been hearing for years that Atari used 8050's that had bad internal ROMs in their XF551s because those were cheaper. They used external ROMs with those bad 8050's apparently. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
phaeron Posted March 14, 2020 Share Posted March 14, 2020 3 hours ago, Nezgar said: I was reviewing the Alitrra Hardware Reference Manual and I see it currently only describes the XF551 with an 8040 CPU and external ROM. As per your discovery, maybe @phaeron would be interested to include a note about a variant using an 8050 with internal ROM. Unfortunately, I see nothing in the XF551's command table that could be used to read the ROM programmatically by software means... 8050 still uses the 8040 architecture, so it's not that pertinent at the level of the hardware manual describes, like FDC minor numbers. What it does do, unfortunately, is make the firmware harder to dump. The 8040 architecture having separate instruction and data spaces doesn't help in this regard, either, as it means that data fetches can't be redirected to program space or execution redirected to data buffers even if we did have a way to abuse the firmware. The 8050 datasheets do imply that the ROM can be read back for verification with a suitable programmer and don't mention a security fuse, so it's potentially still possible without decapping the chip. 3 Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted March 14, 2020 Share Posted March 14, 2020 I have several versions of the XF os. One marked as 7.7 It is the pal fixed up version of the original one. Another one marked as ABCD ??!!?? It is the same as 7.7 except for these lines added @ 9E0 9AF ANL P1,#0EFH has been replaced with JMP X09E0 X09E0: IN A,P1 ; 09e0 - 09 . ANL A,#8 ; 09e1 - 53 08 S. JZ X09F0 ; 09e3 - c6 f0 Fp wrong.?????????????????????? ANL P2,#0CFH ; 09e5 - 9a cf .O ORL P2,#10H ; 09e7 - 8a 10 .. ANL P1,#0E7H ; 09e9 - 99 e7 .g JMP X09B1 ; 09eb - 24 b1 $1 ; ORL P2,#30H ; 09ed - 8a 30 .0 ORL P1,#8 ; 09ef - 89 08 .. ANL P1,#0EFH ; 09f1 - 99 ef .o JMP X09B1 ; 09f3 - 24 b1 $1 The instruction at 9e3 doesn't make any sense. I also have the CSS single drive os. It requires the dongle as it is the copy protection. However, looking through the code , you can soon spot what bytes to NOP out to bypass that. 1 Quote Link to comment Share on other sites More sharing options...
StefanD Posted March 14, 2020 Share Posted March 14, 2020 See my earlier post in this thread for an explanation of this code fragment: https://atariage.com/forums/topic/108472-xf551-oses/?do=findComment&comment=2059318 Quote Link to comment Share on other sites More sharing options...
manterola Posted March 14, 2020 Share Posted March 14, 2020 (edited) 23 hours ago, Nezgar said: Unfortunately, I see nothing in the XF551's command table that could be used to read the ROM programmatically by software means... So I'll need to build something like this to read data from the chip.. this is for the Willem programmer.. http://www.mpu51.com/eprom/pdf/AD-MCS48_41_SCH.zip Edited March 14, 2020 by manterola Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted March 14, 2020 Share Posted March 14, 2020 11 hours ago, sup8pdct said: I also have the CSS single drive os. It requires the dongle as it is the copy protection. However, looking through the code , you can soon spot what bytes to NOP out to bypass that. That would be great to have a cracked/patched version that would work without anything more than a ROM replacement! Is this "The XF Update" as described here? : http://www.nleaudio.com/css/products/XFupdate.htm If so, I would like to test out the "true Ultra Speed data transfer (actually, slightly faster than the 1050 Ultra Speed)" Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted March 15, 2020 Share Posted March 15, 2020 8 hours ago, Nezgar said: That would be great to have a cracked/patched version that would work without anything more than a ROM replacement! Is this "The XF Update" as described here? : http://www.nleaudio.com/css/products/XFupdate.htm If so, I would like to test out the "true Ultra Speed data transfer (actually, slightly faster than the 1050 Ultra Speed)" Yes. Same one. It has been fixed to work on PAL. The original he made didn't. Cannot remember but i think V 1.3 is the one that works everywhere. $13f and $140. change to 0 $1A5 and $1A6. change to 0 $1a9 and $1AA change to 0 Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Share Posted January 29, 2022 Does anyone have a manual or documentation for the hyperxf 3.5”? Quote Link to comment Share on other sites More sharing options...
+selgus Posted January 29, 2022 Share Posted January 29, 2022 17 minutes ago, Gitbizy said: Does anyone have a manual or documentation for the hyperxf 3.5”? You mean this? http://blog.3b2.sk/igi/post/Hyper2b-XF-10-MANUAL.aspx Quote Link to comment Share on other sites More sharing options...
Gitbizy Posted January 29, 2022 Share Posted January 29, 2022 53 minutes ago, selgus said: You mean this? http://blog.3b2.sk/igi/post/Hyper2b-XF-10-MANUAL.aspx And a big thank you @selgus Quote Link to comment Share on other sites More sharing options...
