carmel_andrews Posted June 11, 2007 Share Posted June 11, 2007 (edited) Recently updated my collection of homesoft disks (emulator format) however there is a problem with some of the programs Looking at the disks using make Atr and atr util, as well as thru dos's like mydos etc, i noticed that the majority of the programs are single part/single load binary files (atari dos executables) So, using make atr, and mydos, i renamed all the .com files to xex and used make atr to extract the files to a new directory the following programs are the ones i have problems with All that scott adams adventures (dont load properly) I.E keeps on rebooting (they do work on the menu disk though) Universal Hero (tried it on all permuations of xl/xe modes, no success), menu disk does work Space beagle- hyper drive (tried it with all o/s's, basic on and off and all xl/xe ram config's upto 320k), the one on the homesoft disk is dodgy anyway All the above files are single part/single load atari executables, so essentially they should still work, menu or no menu Edited June 11, 2007 by carmel_andrews Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 12, 2007 Share Posted June 12, 2007 Well, Homesoft created his own menu for his menu-disks. I also noticed that some programs will only work correct with his menu and not at all with other menus... Some programs are also dependant of the format or better density used - the Homesoft disks are always double density / 180kbytes (meaning 256 bytes per sector). I do have some programs in my collection that will only work with 128 bytes per sector - maybe there are some programs on the Homesoft disks, that will only work with 256 bytes per sector... and with the Homesoft menu... -Andreas Koch. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 12, 2007 Share Posted June 12, 2007 I've toyed with some Homesoft disks, I've even gone as far as putting files on a 707 sector to see what they would do some run just fine with out Homesoft menu but most of need that menu. Quote Link to comment Share on other sites More sharing options...
