avocado Posted June 14, 2007 Share Posted June 14, 2007 Could someone post the specs for the power adapters for the Atari 800 and the 810 Disk Drive? I recently acquired these via ebay, and they were badly damaged in shipping. If I don't end up sending them back, I will attempt to restore them. First step, though, I need to power them up, and I can't tell which adapter goes to which unit! The plugs are identical. Any help would be awesome. Thanks! Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 14, 2007 Share Posted June 14, 2007 AFAIK, those bricks are interchangable. I've got 1 @ 11.5v DC and 2 @ 9v AC stated as the output (800 + 2 1050 drives), and it doesn't matter which I use for either. Quote Link to comment Share on other sites More sharing options...
avocado Posted June 14, 2007 Author Share Posted June 14, 2007 cool. both of the ones I have are 9 VAC, but one is 31 VA and one is 15.3 VA output. I'll give it a shot right now. Quote Link to comment Share on other sites More sharing options...
mimo Posted June 14, 2007 Share Posted June 14, 2007 use the higher output for the 810, the 800 will run on 1 amp no probs, but the 810 needs more power *in a Tim Allen Tool Time sort of voice* Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted June 14, 2007 Share Posted June 14, 2007 For all your questions... http://www.cs.uu.nl/wais/html/na-dir/atari-8-bit/faq.html Quote Link to comment Share on other sites More sharing options...
avocado Posted June 14, 2007 Author Share Posted June 14, 2007 Thanks for that link! Quote Link to comment Share on other sites More sharing options...
LYNXGUY Posted June 14, 2007 Share Posted June 14, 2007 avocado, did you get the Atari 800 and 810 floppy drive working yet ?? Quote Link to comment Share on other sites More sharing options...
avocado Posted July 14, 2007 Author Share Posted July 14, 2007 Not quite yet, unfortunately. (this sat in the attic for a while since my last post) See my thread about replacement peripheral port..My 800 had a bent pin, and when i started bending it back into position, it snapped off. I'm trying to track down a replacement port, so I can finally fire up the drive. Hopefully the DOS disk is in the small pile of floppies that came with the computer... Quote Link to comment Share on other sites More sharing options...
