mul6 in assembler?
Multiplying by a constant is just a series of shifts and adds.
To multiply by 6, you add *2 and *4. So it's shift, save, shift, add.
ASLA (A=A*2)
STA temp (save A*2)
ASLA (A=A*4)
ADC temp (A*4+A*2=A*6, and assuming that the carry was clear from the previous ASLA)
Multiply by ten is *2 + *8.
ASLA
STA temp
ASLA
ASLA
ADC temp
Of course it gets a bit trickier when your result is greater than 255. On the Z80, 16-bit constant multiplies are easy when you use a bunch of ADD HL,HL and ADD HL,DE instructions, but on the 6502 it's a lot of extra work to do 16-bit shifts and adds, and you will probably need 4 bytes of temp.
Edited by Bruce Tomlin
Shift left to get 2*, keep result
Shift left again to get 4*, add to result
How big will the initial number be? If it's a single byte, then maybe table lookup would be economical.
Or maybe, another way of looking at it:
TAY ; save original number
AND #$3F
TAX
LDA MUL6TABL,X
STA RESULT
LDA #0
CPX #43 ; 6*43 is an overflow, so we set the high byte to 1
BCC NOTBIG
LDA #1
NOTBIG STA RESULT+1
TYA ; get number back
AND #$C0
ROL A
ROL A
ROL A
TAX
LDA MUL6TABH,X
ADC RESULT+1
STA RESULT+1
RTS
MUL6TABL .byte 0,6,12,18 ... ; etc... table has 64 entries, each one = (N*6) AND 255
MUL6TABH .byte 0,1,3,3 ; 4 entries
I think that should work. Could be optimised a bit.
Cost - about 100 or so bytes.
Time - might just be quicker to do the shift method
Edited by Rybags
AND #$3F
TAX
LDA MUL6TABL,X
STA RESULT
AND #$C0
ROL A
ROL A
ROL A
TAY
LDA MUL6TABH,Y
CPX #43
ADC #0
STA RESULT+1
RTS
optimized a bit - CPX sets the carry to what we want for the add anyway, so saved some time.
