Gorf Posted August 5, 2007 Share Posted August 5, 2007 That's really wierd, honestly. I have a PAL A1200, and all I had to do was just turn the V-Hold dial slightly to get the picture to stabilize through the RGB output. that is what I was thinking. Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted August 5, 2007 Share Posted August 5, 2007 Yeah, the only deal is that you have to do that, and also play with the V-Size knob as well. Quote Link to comment Share on other sites More sharing options...
Gorf Posted August 5, 2007 Share Posted August 5, 2007 Yeah, the only deal is that you have to do that, and also play with the V-Size knob as well. Yeah...a few adjustments may be all he needs. Quote Link to comment Share on other sites More sharing options...
sd32 Posted August 5, 2007 Share Posted August 5, 2007 Are there any diferences between CD32 Zool 2 and the Jagaur version?. Im thinking about getting the Jag game, but if its the same, ill pass. Quote Link to comment Share on other sites More sharing options...
Gorf Posted August 5, 2007 Share Posted August 5, 2007 Are there any diferences between CD32 Zool 2 and the Jagaur version?. Im thinking about getting the Jag game, but if its the same, ill pass. Not a fan of the game but its probably similar. Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted August 6, 2007 Share Posted August 6, 2007 Are there any diferences between CD32 Zool 2 and the Jagaur version?. Im thinking about getting the Jag game, but if its the same, ill pass. I don't have the CD32 version, but I'm pretty sure it has some FMV and CD audio tracks that aren't in the Jaguar version. Being on CD, there are probably some load times in there too. I don't see any reason the gameplay would be any different though. --Zero Quote Link to comment Share on other sites More sharing options...
Gorf Posted August 6, 2007 Share Posted August 6, 2007 Are there any diferences between CD32 Zool 2 and the Jagaur version?. Im thinking about getting the Jag game, but if its the same, ill pass. I don't have the CD32 version, but I'm pretty sure it has some FMV and CD audio tracks that aren't in the Jaguar version. Being on CD, there are probably some load times in there too. I don't see any reason the gameplay would be any different though. --Zero Im sure it was just a port like most of the games seemed to be, unfortunately. Quote Link to comment Share on other sites More sharing options...
Feralstorm Posted August 6, 2007 Share Posted August 6, 2007 (edited) CD32 Zool2's got some FMV and a CD Soundtrack, as said. Jaguar version has more color depth (graphics appear redone with more shading in the Jag version). Gameplay is pretty much identical best I can tell. Edited August 6, 2007 by Feralstorm Quote Link to comment Share on other sites More sharing options...
sd32 Posted August 6, 2007 Share Posted August 6, 2007 Judging from screenshots, it seems like the Jag game has some prerendered objects on some levels, like a sphynx head and some soda cans, that i havent seen on the CD32. I think will still get the Jag game just because its on Jaguar, hehe. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 15, 2007 Share Posted August 15, 2007 Well, i am trying to go from the PAL output of the Amiga to an NTSC monitor? I have asked around on some CD32 forums, they have told me to get a Pal Commodore monitor, wich are very expensive to ship from Europe to Mexico, or to buy a Pal to NTSC converter, i bought 2 converters and they were crap. Is your CD32 a NTSC system or a PAL system? Do you know about using an Amiga Mouse into port 2 to bring up the hidden boot menu that allows you pick NTSC or PAL? Quote Link to comment Share on other sites More sharing options...
Gorf Posted August 15, 2007 Share Posted August 15, 2007 Well, i am trying to go from the PAL output of the Amiga to an NTSC monitor? I have asked around on some CD32 forums, they have told me to get a Pal Commodore monitor, wich are very expensive to ship from Europe to Mexico, or to buy a Pal to NTSC converter, i bought 2 converters and they were crap. Is your CD32 a NTSC system or a PAL system? Do you know about using an Amiga Mouse into port 2 to bring up the hidden boot menu that allows you pick NTSC or PAL? Now that sounds like the best solution yet. Good to know someone knows these things. Is there other items of interest on that menu? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted August 15, 2007 Share Posted August 15, 2007 Now that sounds like the best solution yet. Good to know someone knows these things. Is there other items of interest on that menu? Yeah, but they're only interesting for an Amiga, not the CD32 - from the wiki entry Like all later Amiga computers, the CD32 has a hidden boot menu that can be accessed by plugging an Amiga mouse into port 2 and holding both buttons down while turning the system on. Most of the options in this menu aren't useful on a CD32, but from this menu you can choose to boot in either NTSC or PAL mode. This is important, as there are some games that will refuse to work if the system is in the wrong mode, also since most games don't advertise what video mode they were developed for. It should also be pointed out that despite the naming, the menu really only allows a choice of 60Hz or 50Hz video output; a PAL system booted in NTSC mode will still output a video signal using PAL color encoding, which will usually result in a black and white picture when connected to an NTSC television. Quote Link to comment Share on other sites More sharing options...
sd32 Posted August 15, 2007 Share Posted August 15, 2007 Thanks for the advice SpiceWare, i already knew about the hidden menu, but according to some CD32 forums, most Pal games dont work if you turn the console to NTSC mode, and the NTSC games library is really small. Still, have to get an Amiga mouse to try it myself. Quote Link to comment Share on other sites More sharing options...
sd32 Posted August 15, 2007 Share Posted August 15, 2007 Thanks for the advice SpiceWare, i already knew about the hidden menu, but according to some CD32 forums, most Pal games dont work if you turn the console to NTSC mode, and the NTSC games library is really small. Still, have to get an Amiga mouse to try it myself. By the way, my console is PAL. Quote Link to comment Share on other sites More sharing options...
Feralstorm Posted August 16, 2007 Share Posted August 16, 2007 (edited) Sadly, the bootmenu only helps so much. As others have said, some games won't work correctly (or at all) if you switch modes on them, and a few others will override the scan rate back to PAL/50 on their own anyway. Edited August 16, 2007 by Feralstorm Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted August 16, 2007 Share Posted August 16, 2007 Now that sounds like the best solution yet. Good to know someone knows these things. Is there other items of interest on that menu? Yeah, but they're only interesting for an Amiga, not the CD32 - from the wiki entry Nice to see that the stuff I post on Wikipedia actually does get read from time to time The menu also allows you to change boot device (though the list is empty, not even the built-in CD-ROM shows up in it), disable CPU caches, choose between ECS and AGA (not sure what effect this might have, it would likely just cause some games to crash), and view installed expansion boards (another empty list). This stuff might be useful if you have an SX-1 or SX32 installed, but even then it's not stuff you'd need to use very often. Even on my Amiga 3000, I don't think I've ever used this boot menu except out of curiosity. Sadly, the bootmenu only helps so much. As others have said, some games won't work correctly (or at all) if you switch modes on them, and a few others will override the scan rate back to PAL/50 on their own anyway. Actually, in my experience, a lot of games will work properly in NTSC. With many games, you'll just lose an inch or so of the bottom of the screen (Fire & Ice and Beneath a Steel Sky are still fully playable). There are a few game that will also show graphical glitches when you try to play them in NTSC (Super Skidmarks and Disposable Hero both do this, making them somewhat unplayable). There are a few games which will just mysteriously crash without any indication of why (Alfred Chicken, for example, will crash just before the level starts), but from what I've seen in my collection, they're a minority. My eyes are pretty bad, so I have a tough time telling whether I'm looking at a PAL screen or an NTSC screen, but I sure that Seek & Destroy automatically set the screen to 50Hz even though I was in NTSC mode. There are probably some other games that do this that I haven't noticed yet. --Zero Quote Link to comment Share on other sites More sharing options...
Gorf Posted August 16, 2007 Share Posted August 16, 2007 (edited) Nice to see that the stuff I post on Wikipedia actually does get read from time to time It's even nicer to know that someone with a clue actually does post stuff on Wiki from time to time. I've really been tempted to go and edit the Jaguar lies myself. Edited August 16, 2007 by Gorf Quote Link to comment Share on other sites More sharing options...
oky2000 Posted January 10, 2023 Share Posted January 10, 2023 On 8/6/2007 at 12:20 AM, sd32 said: Are there any diferences between CD32 Zool 2 and the Jagaur version?. Im thinking about getting the Jag game, but if its the same, ill pass. This is a far more interesting question than you would think. Zool 2 on the CD32 has some bargain bucket music made on some cheap FM synths BUT the floppy disk version has some far superior MOD tunes. On the Jaguar you get the superior tunes. One the Jaguar you get sfx and the superior MOD music of the Amiga disk version so it's the best of both worlds. Unlike Cannon Fodder recruitment screen where the music has different and inferior Windows 95 .midi type instruments and half the tune is missing, Zool 2 on Jaguar is the exact same tunes as on the Amiga MOD tunes thankfully. This is not an isolated incident on CD32 vs Amiga 1200 game, Super Stardust has some 99pence/99cents store CD type dance music on the CD32/PC-CD release but on the PC/Amiga floppy disk version again you get far superior tunes (unless you have no taste in synthesizers and have a hobby collecting wedding band demo CDs). CD32 is the worst console of all time, at least with the CDTV you could load up Shadow of the Beast 1, Lionheart, Sword of Sodan, Turrican III and many other 16bit console quality games from disk, the CD32 is stuck with the naff bargain bucket developments on CD-ROM only. It also has a 50% crippled 7mhz 020 due to some idiot not realising the AGA chipset was never designed to be used with zero Fast RAM (CPU exclusive RAM) ooops. 1 Quote Link to comment Share on other sites More sharing options...
