RSS Bot Posted September 20, 2007 Share Posted September 20, 2007 Delicon successfully implemented CPLD autoswitching in combination with a simple "staller" program I wrote that copies itself into zero-page and runs a simple rainbow kernel for a fixed number of seconds. The CPLD appears to take only about 7 seconds to program, but we're giving it some extra buffer before it jumps out just in case. So the way it works is there are three CPLD core files. The most common schemes are available in all of them. The ARM autodetects the banking scheme of the game you want to load and sees if the core file in the CPLD can handle it. If it can, it loads it immediately. If it can't, it reprograms the CPLD while the staller program is running and then indirectly jumps to init the cart. Here is my wonderful code. If someone thinks they can squeeze a fancier kernel into 128 bytes, please give it a shot. Remember, while the kernel runs it can't access any cart addresses at all. processor 6502 include vcs.h include macro.h ;=============================================================================== ; Z P - V A R I A B L E S ;=============================================================================== SECONDS_TO_PAUSE = 11 ;ScreenTop_ram = $00B0 SEG.U variables ORG $80 reserved ds 8 bk ds 1 bk2 ds 1 bk3 ds 1 bk4 ds 1 jiffies ds 1 seconds ds 1 ram_start .byte ;=============================================================================== ; R O M - C O D E ;=============================================================================== SEG Bank0 ORG $f000 Start CLEAN_START LDX #ram_routine_end-ram_routine copy_ram LDA ram_routine-1,X STA ram_start-1,X DEX BNE copy_ram LDA SECONDS_TO_PAUSE; seconds to pause STA seconds LDA #60 STA jiffies ; JMP ram_start ; copy this to RAM ram_routine ScreenTop lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #43 sta TIM64T lda #0 sta VSYNC WaitForVblankEnd lda INTIM bne WaitForVblankEnd sta WSYNC sta VBLANK sta WSYNC LDA bk STA bk2 LDA bk4 STA bk3 LDY #100 ScanLoop LDA bk2 STA COLUBK DEC bk2 STA WSYNC DEY BNE ScanLoop LDA bk STA bk2 LDY #100 ScanLoop2 LDA bk3 STA COLUBK DEC bk3 STA WSYNC DEY BNE ScanLoop2 LDA #2 STA WSYNC STA VBLANK LDA #0 STA COLUBK OverScan ;***************************** OVERSCAN CALCULATIONS LDY #21 KillLines STA WSYNC DEY BNE KillLines INC bk DEC bk4 DEC jiffies BNE ScreenTop ;LDA bk LDA #60 STA jiffies DEC seconds BNE ScreenTop ;if you want to see it end in an emulator, uncomment this ;Done ; LDA #$B8 ; STA COLUBK ; JMP Done JMP ($FFFC) ram_routine_end org $FFFC .word Start .word Start The current technical problem we're having is the cart is drawing too much power to work with the microSD card for the current voltage regulator. We actually have to go a little over spec in the hopes that short bursts will be safe enough for the system. Delicon replaced the regulator on his system and it fixed his brownout problems. I have to do the same on my end once I get the proper part. We do have a power jack on Chimera but we are desperately trying to avoid making a wall-wart a mandatory accessory. It should ideally only be required for power-hungry peripheral boards like the PS2 adapter (which has its own ARM on it). Right now the CPLD files and the zero-page staller are being loaded from microSD. When we're done they will be embedded into the actual ARM firmware so the only microSD access will be when loading the game files themselves. Power requirements when loading from the surface-mount flash chip are much lower than microSD. The original intention was to not support removable media as a cost-cutting measure. That way you wouldn't be forced to purchase a separate microSD card to get up and running. It would just be instant plug and play. But with a microSD socket on the standalone Chimera, and microSD cards rapidly coming down in price, it seemed like the extra flash chip might become redundant. The flash chip is also not required for "embedded" Supercharger or Chimera games that can fit in the leftover space of the 512K ARM flash. Right now we don't know how much space there will be but I'm hoping at least 128K. So it's more for use with future Chimera-native games that the cart will auto-boot into. I just don't know whether it has to be there in all cases. Anyway, the hardware has proven itself capable of being a functional multicart. To be a truly viable one, though, it needs an onscreen menu. That's the next big hurdle. When I get the regulator replaced I'll get a video posted so you'll be able to see it switch between games for real. http://www.atariage.com/forums/index.php?a...;showentry=3883 Link to comment Share on other sites More sharing options...
