Indus Ramcharger Help
JR>
Indus CP/M bios is fixed to 256 byte sectors, single sided.
However you can write your own program to read larger sectors if you wish but only single sided. you can get really ambitious and rewrite the indus cp/m bios if you wish to handle different size sectors.
Cannot comment about the 1571. if it uses a FDC and is close to industry std layout, it may be possible.
  • 11 months later...
edit: found it. Disregard.
Hi. Just got @tf_hh's Indus Ram Chargers installed in two Indus drives (thank you!!)  I'm trying to locate the 40 column Indus RAM Charger 40/80 Col. Terminal (www.retrobits.net/atari/indus.shtml) but the retrobits.net web server is not responding.  I'm following the instructions at http://trub.atari8.info/index.php?ref=indus_cpm_en
I've searched and so far been unable to locate it elsewhere.  Please help.
Edited by Sugarland
Looking at the drive front it is on the very right edge of the circuit board, outside the metal frame.
I think the orientation of the SRAM Charger is correct but better check tfhh‘s docs. This is not a working Indus (but thanks for the reminder to finally get it working again ;)).
I think you might be tired or distracted and did not read my question fully. ?  I'm trying to locate the 40 column Indus RAM Charger 40/80 Col. Terminal please.
