I can not get data statements to work.
Robert M
I am having problems using data statements. They compile without errors, but no code is generated. For example if I write the following code:
	data XphaseEventTable
0,23,46,69,92,115,138,161,184,207
end
Only the label for the data statement appears in the asm file. Here is the generated code I am seeing:
.L0189;  data XphaseEventTable
JMP .skipL0189
XphaseEventTable
.skipL0189
Am I missing something on the syntax of data statements, or is this a bug?
Cheers!
I copied your code in the post above into a empty text file and compiled it. It compiled correctly. See below:
.L00 ; data XphaseEventTable
JMP .skipL00
XphaseEventTable
.byte 0,23,46,69,92,115,138,161,184,207
Note: didn't bother to set the formatting.
I would try doing that and see what happens. If it still doesn't work, something may be corrupt in your installation. You could try a clean install to a different folder and see what happens.
EDIT: It could also be a bug in the MSK (if you are using it). Didn't have time to check what happened if I compiled the above in it.
Edited by s0c7
Aha!
When I cut and paste my own code, it compiles correctly!
It looks like the data statement must be indented with only space characters. If you use a tab character to indent, the data statement compilation fails. I am not sure if this is a bug. Tabs are generally considered to be valid whitespace, but the bBasic manual does not specify what characters are treated as whitespace.
Cheers!
Aha!
Cheers!
Thanks for finding that bug - I tracked it down and fixed it. Was due to a bad way of checking for a string-terminating NULL, CR or LF (I checked ASCII value <14, which also includes TAB.)
sdata has the same bug (and the same fix.)
Great! Thanks for the fast response time.
