Mad-Assembler (MADS)
I just tried to expand a STRUCT using the outline viewer, and it doesn't work
Verified, same for .enum. Will check tomorrow. Simply have not used .struct by now.
what can we expect? "texture", "sinus" etc?
All I can say is that has nothing to do with vectors and runs on 64k at full frame rate. The next will be a "traditional" demo which contains two things I started to code back in 1993 - now they have finally become possible. Seems I'm getting wiser with age;-) - well, and the tools get better, especially the assemblers.
  • 3 weeks later...
I just need post again to send a very big public
Thanks TeBe for creating MADS
My contribution for the Sillyventure is now finished and sent.
Writing object file...
8965 lines of source assembled in 5 pass
39882 bytes written to the object file
This would not have been possible without MADS! It is the biggest demo I've every created in terms of code. And because of ".PROC" and ".LOCAL" the code looks so good, I'd like to print it and put it up the wall in frame. And with the ."IF/.ERROR" during compilation time, I even have automated boundary checks at compile time (DL crossing 1k boundary, branch crossing page boundary). I never imagined that would be possible. So just thanks again!
  • 1 year later...
Hi TeBe, just found a bug in 1.9.4 which is not there in 1.9.3.
Forward references are sometimes counted as zero page addressing (1 bytes), though they need absolute addressing (2 bytes).
org $4000
.proc main
lda text_block
.endp
.local text_block
.endl
yields this corrupted file. End address should be $4002 instead. This is just the smallest example I could find. The other were more complex.
COM block 1
0000 : 0000 : FF FF 00 40 01 40
0006 : 4000 : AD 02
COM file structure error
0008 : 0000 : 40 | @
Edited by JAC!
  • 4 years later...
hi there,
is it possible to have full generated list after compilation? i'd like to see all 6502 codes and not a shortened list.
see an example below:
16 FFFF> 0600-0689> A9 00 +   mva #0 sdmctl
17                            copy #osrom,#osram,#0
17                           MWA #OSROM SOURCE\ MWA #OSRAM DEST\ MVA #0 COPY.ROUND\ JSR COPY
17 0605 85 CB A9 C0 85 CC    MWA #OSROM SOURCE
17 060B A9 00 85 CD A9 40 +  MWA #OSRAM DEST
17 0613 A9 00 8D 89 06       MVA #0 COPY.ROUND
17 0618 20 5E 06             JSR COPY
there is a plus "+" :-(
  • 1 month later...
MadAssembler source code, line = 789
margin = 32;
add 'x * 8'
x tab counter
8 size of TAB
default 'margin = 32'
   6 2001 A9 80 8D 00 A0 A9 +  mwa #$80 $a000
'margin = 32 + 8'
  6 2001 A9 80 8D 00 A0 A9 00 8D +    mwa #$80 $a000
'margin = 32 + 8 + 1'
   6 2001 A9 80 8D 00 A0 A9 00 8D 01 +  mwa #$80 $a000
  • 2 weeks later...
Hi tebe,
I am currently automating my build processes, so I can provide updates for different platforms more easily.
When I compile the mads.pas (2.0.6) with fp-compiler-3.0.0 on Ubuntu 16.04LTS I get the following warnings:
Compiling mads.pas
mads.pas(20,2) Note: APPTYPE is not supported by the target OS
mads.pas(1781,17) Hint: Variable "a" of a managed type does not seem to be initialized
mads.pas(2561,35) Hint: Variable "i" does not seem to be initialized
mads.pas(3213,3) Hint: Variable "a" of a managed type does not seem to be initialized
mads.pas(3539,21) Hint: Variable "war" of a managed type does not seem to be initialized
mads.pas(3632,29) Hint: Local variable "par" of a managed type does not seem to be initialized
mads.pas(3673,58) Hint: Parameter "old" not used
mads.pas(3962,24) Hint: Converting the operands to "Int64" before doing the add could prevent overflow errors.
mads.pas(3963,24) Hint: Converting the operands to "Int64" before doing the add could prevent overflow errors.
mads.pas(3964,24) Hint: Converting the operands to "Int64" before doing the add could prevent overflow errors.
mads.pas(3993,22) Hint: The left operand of the IN operator should be byte sized
mads.pas(4537,28) Warning: Local variable "tmp" of a managed type does not seem to be initialized
mads.pas(6103,10) Warning: Local variable "par" of a managed type does not seem to be initialized
mads.pas(8068,49) Warning: Local variable "str" of a managed type does not seem to be initialized
mads.pas(8669,46) Warning: Local variable "all" does not seem to be initialized
mads.pas(8822,16) Hint: Variable "k" does not seem to be initialized
mads.pas(9056,54) Warning: Local variable "txt" of a managed type does not seem to be initialized
mads.pas(9579,26) Hint: Local variable "par" of a managed type does not seem to be initialized
mads.pas(11054,33) Hint: Local variable "txt" of a managed type does not seem to be initialized
mads.pas(11054,9) Hint: Local variable "txt" of a managed type does not seem to be initialized
mads.pas(10057,27) Hint: Local variable "par" of a managed type does not seem to be initialized
mads.pas(12392,51) Hint: Local variable "tmp" of a managed type does not seem to be initialized
mads.pas(11497,51) Warning: Local variable "idx" does not seem to be initialized
mads.pas(11497,52) Warning: Local variable "idx" does not seem to be initialized
mads.pas(12392,53) Hint: Local variable "v" does not seem to be initialized
mads.pas(12512,54) Hint: Local variable "r" does not seem to be initialized
mads.pas(12871,29) Hint: Local variable "tmpZM" of a managed type does not seem to be initialized
mads.pas(13838,40) Warning: Local variable "vtmp" does not seem to be initialized
mads.pas(14967,21) Hint: Variable "nam" of a managed type does not seem to be initialized
mads.pas(15370,15) Warning: Variable "status" does not seem to be initialized
mads.pas(15367,15) Hint: Variable "plik_asm" of a managed type does not seem to be initialized
mads.pas(15348,5) Warning: Variable "binary_file" does not seem to be initialized
Best regards, Peter.
  • 2 weeks later...
  • 3 weeks later...
Thanks tebe.
I found I had compiled with "-vh" and most of the hints are actually nonsense, like uninitialized input parameters of type string.
When I compile 2.0.7 with -vw I get only a few warnings. They really look like missing initialization so maybe they are worth while checking.
Which verbosity to you use when you compile?
Ok, with standard "-v" I also get no warnings.
I have one request from this thread:
http://atariage.com/forums/topic/254826-mac-osx-how-to-use-altirrawine-and-eclipsewudsnmads-for-development/?do=findComment&comment=3881577
There is a problem, under Linux and OS X, that the "Source: <path>" line is missing in the .lst file. See here: Left windows, right Ubuntu.
  • 6 months later...
Hi tebe, a minor nit. I noticed that .BYTE doesn't implement additive modifiers like in MAC/65.
     1         ORG $600
     2 FFFF> 0600-0607> EA     NOP
     3 0601 C1 C2 C3      .BY +$80,'ABC'
     4 0604 80 41 42 43      .BYTE +$80,'ABC'
Fortunately .BY does, but perhaps .BYTE and .SBYTE should pick up this feature as well.
There's a way to specify "org" on the mads command line. Is there a way to do that with with "opt"? Sometimes would be handy to assemble data without Atari headers.
OPT h- ;No header
ORG ORIGIN
mads.exe -d:ORIGIN=$2000
