Mad-Assembler (MADS)
it seems there is a missing entry in config file for 64bit platform
Quote
/etc/fpc.cfg
add entry in the correct line
Quote
#ifdef cpux86_64
-Fl/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/lib/darwin18.2.0
-XR/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib/
#endif
  • 10 months later...
1 hour ago, ascrnet said:
Hi all,
I am passing a program from MAC65 to MADS, but I did not understand what the equivalent of the following lines is :
BASE = $5000
; MAC65
SETVEC = *-BASE
BUFFLEN = *+1
ERRNUM * = *+24
 * = *+49
  .SB +$80," START "
regards
I would try with something like:
BASE = $5000
SETVEC = *-BASE
BUFFLEN = *+1
ERRNUM
   org *+24
   org *+49
   .sb +128, " START "
(untested!)
This is missing the initial assigment to the orgin.
Something like
* =$8000 in MAC which is ORG $8000 in MADS.
SETVEC = *-BASE ;OK
BUFFLEN = *+1 ;OK
ERRNUM .ds 24
 .ds 49
  .SB +$80," START " ;Not sure, please check the MADS docs , probably something lke .byte +$80 ' START '
BASE = $5000
SETVEC = *-BASE
BUFFLEN = *+1
ERRNUM
   org *+24
   org *+49
   .sb +128, " START "
(untested!)
Thanks for the help.
Something like
SETVEC = *-BASE ;OK
BUFFLEN = *+1 ;OK
ERRNUM .ds 24
 .ds 49
Thanks for the indications I will try them, I just put the lines that I had doubts about how they were.
The program is MICRODOS XL always caught my attention as they did. I already assembled it but it has some strange behaviors.?
  • 2 weeks later...
  • 5 months later...
  • 1 month later...
  • 3 months later...
hello,
one issue I came across...
I got used to anonymous labels lately... but found unwanted behavior when used in macros.
When anonymous label is used within macro, then the label is counted however not accessible (because all macro labels are local).
I would expect the anon.label in macro should not be counted from outside.
Example:
this one works ok (but one needs to know that test macro contains anon.label @, so +1 has to be added) => I think this is bug:
...maybe it is not very cool to use anon.labels in macros... what it your opinion?
  • 2 weeks later...
Having some problems with MADS on Linux.
i'm getting an error from MADS when trying to assemble the 1nvader game.
Compiler 'MADS' output:
Runtime error 216 at $0000000000417845
  $0000000000417845
This happens from command line or from eclipse/WUDSN.
i thought maybe the mads which I had downloaded long ago was out of sync with current  linux libraries, so did some updates, got the current source, built a new executable without issues (remarkably), and still get the same error.   (At least I have a nice shiny 2.1.3 now).
Then I tried the last large game I wrote (Pet Frogger V03) and it assembled just fine from eclipse/WUDSN
So, it seems that there's something about the 1nvader source code that's breaking mads.   ANY IDEAS?   What I get out of google is that this is a memory access error.
Most recently, I had been adding some strings for options menus, and commenting out declarations of unused variable.   Is there any limit in Mads that I may be hitting --  like file size limit or total number of source lines?
8 hours ago, tebe said:
try yesterday's version, https://github.com/tebe6502/Mad-Assembler
Nope.
2.1.3:
  $0000000000417845
2.1.4 just downloaded and rebuilt.
Runtime error 216 at $0000000000417965
  $0000000000417965
I made a bunch  of new declarations in  https://github.com/kenjennings/Atari-1nvader/blob/master/ata_1nv_gfx.asm
A lot of it was similarly named labels for a list of options/menus and I'm wondering if its the similarity or the lengths of similar names that is breaking this.
I'll try later commenting out the newer stuff and then try a reassemble, then put back the declarations in stages and see where this finally breaks.
13 minutes ago, tebe said:
yes, commas
debug FPC:
fpc -Mdelphi -g mads.pas
gdb mads.exe
run filename.asm -i:path
Ooo.  Yeah.   Those commas shouldn't be there.  That's not right.   (shouldn't it be a syntax error?)
Yup.  That's what did it.  Assembly completes now.    THANKS!!!
Edited by kenjennings
update. it builds now.
Think I've found a little bug in the listing produced by MADS.
I've been moving some MAC/65 projects into MADS as an exercise getting used to it as an assembler and
noticed this in the listing file in bold, it doesn't put the full JSR address ?.
    12                          org  $A000
    13 FFFF> A000-A7DA> 20 B0 +          JSR CLEAR   ;CLEAR PIC AREA
    14 A003 20 16 A3                 JSR AGAIN1  ;GET IST SET OF PICTURES
    15 A006 A0 FC                 LDY #$FC
    16 A008 B9 01 06        XX1      LDA $0601,Y
So I created a small test file to see if it did it with a JSR as the first statement and it does:-
                    org $600
     2 FFFF> 0600-060B> 20 2F +         jsr program
     3 0603 20 30 06                jsr program1
     4 0606 85 CB                sta $cb
     5 0608 4C 2A 06                jmp next
     6 060B 00                    .byte 0
     7 060C                    org *+30
     8 062A-0630> A9 02        next lda #2
     9 062C 85 CC                sta $cc
    10 062E 60                    rts
    11 062F 60            program rts
    12 0630 60            program1 rts
and same with JMP
 D:\WUDSN-IDE\Projects\TestStuff\test1.asm
     1                     org $600
     2 FFFF> 0600-060B> 4C 2F +         jmp program
     6 060B 00                    .byte 0
    12                          org  $A000
                    org $600
     6 060B 00                    .byte 0
     7 060C                    org *+30
    10 062E 60                    rts
and same with JMP
     1                     org $600
     6 060B 00                    .byte 0
this is a margin constraint
mads.pas (line = 288, 'margin    : byte = 32;')
hi @tebe,
I would like to put screen data before the font data that is aligned to $400. is it possible to do it dynamically without using the SCR file size constant?
something like this:
org $2000-lengthOfFile("my.scr")
ins my.scr
ins my.fnt
I tried to load my.scr using .get, however combination .len .get is not allowed.
Honestly I have not used .get ever before, how can I check the length of the .get array?
Edited by matosimi
one more issue, I'm not sure if it is MADS issue of G2F code generator issue (since I am not used to work with enums).
Usually if I have to include (one or more) G2F(s) to my SW I put it into .local (maybe there is more elegant way I do not know about) like this:
.local	title_g2f
	icl "title_new\logo\logo_adjusted.asm"
.endl
logo.asm is the source generated by G2F asm output, I simply make a copy with _adjusted to not overwrite my adjustment by another asm export, I remove the init part and simply call
jsr title_g2f.main
...in the latest version of g2f I'm getting following error:
mva #@dmactl(standard|dma|lineX1|players|missiles) dmactl	;set new screen width
logo_adjusted.asm (329) ERROR: Undeclared label STANDARD (BANK=0)
the issue is in the NMI procedure... which I can fix quickly by changing faulty line with:
mva #scr40 dmactl
Of course if I simply compile the logo.asm (without adjustments) it compiles/runs ok.
It just somehow gets broken when it is within the .local .
Am I doing something wrong?
Edited by matosimi
typo
