Wrathchild Posted October 8, 2007 Share Posted October 8, 2007 Hi, I'm importing a Bitmap file using version 3.8.5.5 (20/Sep/2007). but want to set the palette manually. If I alter the colour->register mappings first and then 'Preview' the picture reloads and I can then adjust the (display) colour palette to the correct colours. If I do this the other way around, that is set the Palette colours first, then when I then press the 'Preview' button (which above it has "Append at > 0") then I'm asked if I want to save changes, after which the image is re-imported at line 192 (original height of the bitmap). Is that by design? If so, can you add something like "if holding down control-key when 'Preview' is press the (re)import will default to row zero? Otherwise, how can you manually set the "Append at" value? Regards, Mark Quote Link to comment Share on other sites More sharing options...
