highendsystems Posted October 10, 2007 Share Posted October 10, 2007 The Modified 800XL was purchased from an Antic or Analog advertisement in 1985?. It’s a 256K upgrade with Snitch Switch, which could either be a 130XE with 128K, or an 800XL with 2 single density Ramdisk It “sorta’” worked that you could dump a single sided single density disk into Ramdisk and run it! This only worked with High-Tec Expressions software, despite trying most available commercial games. Right now the unit doesn’t display (Antic problem?). From the pics, I can’t help but wonder why the tech ran out of regular electrical tape.... It comes with a special Translator, Snitchy Switch, and Utility diskettes. 1 working XEGS console both w/ No Power Supply. The XEGS has a price tag = $99.89 reduced to $89.89. Tons of Misc. Software - I will assure the rarest and most treasured! @ least 20 double sided enhanced density disks packed with goodies! 1050 drive not included though recommended. Working XEGS could be used as spare parts for the 800XL. Two misc type working joysticks. Your choice of @ least one of the following commercial titles –> Aliants Alternate Reality Dungeon Auto Dual Bismarck Eidolen Forbidden Forest Ultima III Warship *more to be listed later* Anyway, I would like at least a Benjamin Franklin. Think it’s worth a shot on ebay? Here are some inside pics of the 800XL. Thanks for looking! Quote Link to comment Share on other sites More sharing options...
Marius Posted October 10, 2007 Share Posted October 10, 2007 (edited) What a strange memory upgrade. I looks like pins are connected at the wrong side of the PIA. At least on not so common pins... I guess... Marius EDIT: Ah I see it now... it is due to the sticker on it... on the last picture I saw the pins go further to the normal side of the pia. Edited October 10, 2007 by Marius1976 Quote Link to comment Share on other sites More sharing options...
