Devin Posted December 22, 2007 Share Posted December 22, 2007 Is there a table that I can download which contains the RGB color values for the Atari 2600? Quote Link to comment Share on other sites More sharing options...
+grafixbmp Posted December 22, 2007 Share Posted December 22, 2007 (edited) Is there a table that I can download which contains the RGB color values for the Atari 2600? I know this isn't quite what you had in mind but this workshop chapter link does have a color chart for the 2600. maybe you can somehow check the RGB colors of the chart here http://www.atariage.com/forums/index.php?showtopic=27338 edit: I was right. If you go to the chart and highlight a color, it shows the RGB values. Edited December 22, 2007 by grafixbmp Quote Link to comment Share on other sites More sharing options...
Devin Posted December 23, 2007 Author Share Posted December 23, 2007 Is there a table that I can download which contains the RGB color values for the Atari 2600? I know this isn't quite what you had in mind but this workshop chapter link does have a color chart for the 2600. maybe you can somehow check the RGB colors of the chart here http://www.atariage.com/forums/index.php?showtopic=27338 edit: I was right. If you go to the chart and highlight a color, it shows the RGB values. I found that chart before - I even made a new version of it. However, I noticed that Stella displays the colors a tad different than the chart. For instance, the chart displays that $02 has a value of #404040. However, Stella shows #4a4a4a - a bit brighter. In any case, not a huge issue - though a tad confusing. Quote Link to comment Share on other sites More sharing options...
