Original ICD The Link and 1 GB > drives
exoshell
I recently purchased an ICD The Link off ebay for use with my 1040 STF. This version of the is simply labeled "The Link" not a Link2 or a Link 97. I've searched the web for information specific to this adapter, but haven't been able to find anything. Most of what I've found refers either to the Link2 or Link97. The only bit of information I've found about this adapter is that it lacks support for parity. Hopefully, someone has the following answers:
1. Can I use SCSI drives larger than 1 GB with this adapter along with the HD Driver software?
2. Can I use SCSI-2 or SCSI-3 drives with an appropriate cable adapter?
3. Do SCSI-to-IDE adapters work?
Thanks
Edited by exoshell
Thanks
Hi there
The answer to your Questions is Yes, Yes, and Yes
1 You are only limited to your Partitions and Drive letters.
Quote From (Uwe Seimet)
There is not limit imposed by HDDRIVER, but only the operating system
limits. TOS limits the number of drives to 14 (with HDDRIVER you can also
use the IDs A: and B: for hard disk drives, if you do need two floppy
IDs).
The maximum partition size for TOS 4.x is 1 GB.
Note that with MiNT or MagiC as operating system there is no limit for the
partition size and you can use at least 23 partitions.
I currently use a SCSI 3 unit conneted to a SCSI 1 adapter and it works fine
BUT you MUST diasble parity on the Drive or it will not work.
From what I have seen on the web I have no reason to beleive it will not work,
I cant put my hands on the doc at the moment, but someone did a step by step
setup with the same hardware.
Hope this helps
Chance227
  • 3 weeks later...
I have used a SCSI-to-IDE bridge adapter with both a Link2 & AdSCSI Micro ST and it worked fine.
Once while messing around I hooked the AdSCSI Micro ST to a SCSI-to-IDE adapter, then an IDE to Compact Flash adapter, then a Compact Flash to SD card adapter, and I was able to format and install the ICD SCSI Pro Utilities on an SD card and boot my system.
The SCSI-to-IDE adapter I used was an old Acard Tech AEC-7720U. The IDE to CF adapter was some generic one off of ebay, and the CF to SD adapter was the type-2 from Mittoni. I currenty have an old 2GB Quantum IDE drive in my Mega with the AdSCSI Micro ST & SCSI-to-IDE adapter.
  • 2 months later...
I am posting this becuse i feel it could be of some interest...
It was copied from ATARI-forum and is not my post...
It talks about SD cards and adapters. As we are now finding it very hard to buy the correct size SCSI devices this seems to now be a more viable option...
drives C-P 535MB physical size,TYPE BGM {see partition notes},
on ACSI>>SCSI >IDE {lun0 id0 drive in master ide mode}
samsung 8.4GB drive SVO844-D IDE
STE 1MB / adscsi plus also confirmed using a sh205 drive shell with scsi mod so older cards will work fine}
hd driver v8.16
the method i used
using hd driver from floppy adjust all the peramiters of the floppy copy and let it save
youll need to load the HDDRIVER.prg from the floppies auto folder
go to settings
in general driver choices enable restart after reset and unlock after reset
and leave the rest unchecked unless you use two scsi hosts lun 0 and lun 1
if this is the case you can enable to logical luns {so you can boot from either or or just one
in scsi driver adjuster menu for adscsi plus pro or link etc enable icd compatable interface and also asci speed enhancement fast acsi
enable scsi rest on error and reset when booting
then reboot before formating
in format dont enable the error table format it using an interleave of 2
and when it sector checks press esc
escape the sector check or youll be there all day
then reboot
and restart hddrutil.exe
then in partition auto split to 14 partitions { you can have 16 i think not sure there maybe limits}
and recorrect the sizes to 511MB and dont set a type leave it at '---'
in the compatability menu choice enable tos 1.04 compatable
and byte swapping enabled
then partition the drive
any slack space will be ignored
you now WITHOUT QUITING OR REBOOTING FIRST need to use change partition type
youll see the type is most prob BGM and all ticked
now press ok and let it take the action and quit the hddrutil gem
it seem's the type isnt set till you do this and is only set if you do it straight after partition
{took me a while to twig here to this bug }
at this point the machine will be a bit strange and sluggish
so when you quit the app it warns you to reboot
so power down ! both the machine and the drive /interfaces
repower drive and puter 20 sec later
and proceed to initalise {same menu 'harddisk' as partition} each drive starting at C
when you do the intitialise the drive will make its grinding sound and the bee will still be onscreen
youll also see the menus for sector size etc leave these alone
i connected an led to the ide interface jp4 it does go out when this step completes so its handy to have one
basicaly wait a few second and press reset {bug in something do do with hddriver v8.16 havent tried a later one}
it will still initialise
so once reset for 10 seconds or so
restart and repeat this with hddrutil FROM FLOPPY till you make all the drives C- P initalised
when you have made about 1/2 of them the machine will respond much better
and once they are all done
use hddrutil to install the driver to the drive C from the install menu in hddrutil
and take the disk out
power down at this point wait the usual 1/2 a min
and power up then the drive will start as a 14X535MB IDE fast drive
then click the drive c choose the usual install disk drive from the ataris options menu
name each drive as C,D,E etc and a name if you like
and then once all the icons are done and youve alligned them on the screen
save the desktop
reboot and there is your 14 drives ready
open drive p
i found i had to save the desktop with all the icons
and at first drive F-P were not avalible
i simply rebooted from the hddriver floppy and reinstalled the driver from the menu in hddrutil.prg
seems the driver wont install correctly till all the icons are there and saved to a desktop.inf
on drive c
and again reboot
so...
gives around ~1300Mb/Sec and an access time latency time of 14ms or so.....
this is better than most scsi drives
small 8-10GB ide drives are best suited most makers i tried allow the interface to project the right size to hddriver
see above for how to use several ide drives on one cable and switch them off when you want to change them
just from the power
this scsi->ide interface is only for one ide drive on one scsi id you can have a few of them thou
but you still have the choice of master or slave
as hd driver likes it ....like id->0 master id->1 slave id2->master id3-> slave as physical ide drives
however i didnt prove this as the ide is alive in scsi
and for all purpose will appear as scsi to the driver maybe???
Some notes:
There is a 1GB limit by some ICD adapters (and inernal one in Mega STE). It is hardware limitation and has not much with driver used. As I know, only latest ICD Pro adapters can access above 1GB on SCSI drives. On their WEBsite it is not clear what adapters can access what.
Then, it has nothing with partition size limits of TOS. As said, it is HW limitation.
SCSI-IDE adapters should work. However, I have bad expereiences with CF cards. With Yamaha adapter it worked not with most CF cards. Only Sandisk 2GB was partitally usable - reading was OK, but writing not. With regular hard disks it worked flawless and very fast - as DMA chip in Ataris can (1280KB/sec) . There are other adapters which maybe work better with CF...
Exoshell:
what capacity is attached SCSI drive ?
  • 1 month later...
The only ICD host adapter that can't do more than 1GB is the very first model. "Link" models are the latest ones, and they can all use high capacity drives.
There is no such a thing as "ICD Pro adapter", or you mean driver/software?
