EricDeLee Posted December 27, 2007 Share Posted December 27, 2007 What is a better wireless setup? The current one I have is a WRT54GS (Wireless-G) Lynksys I'm not sure why. but I seem to be dropping connection quite a bit. I just upgraded the cable dsl service to 100 mbs (<-- or something similar) Yet when I connect my PS3, my chick's laptop seems to always disconnect. We seem to kick each other off four or five times. It seems to dropp when I set everything to 'wired' connection as well. Which is strange. I've been streaming video/music from my main PC... and that seems to work just fine. Any suggestion? SHould I grab a different wireless router? Quote Link to comment Share on other sites More sharing options...
Bucket Posted December 27, 2007 Share Posted December 27, 2007 It could be anything from the two machines attempting to use the same MAC address to a frayed cable. Is there anything else you can tell us? Quote Link to comment Share on other sites More sharing options...
liveinabin Posted December 29, 2007 Share Posted December 29, 2007 I have the same router. It's generally pretty solid. Gets the occasional drop off, but that's just wireless internet for you. Weird problem. Give your router a good reset and make sure it has the latest firmware. Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted December 29, 2007 Author Share Posted December 29, 2007 I have the same router. It's generally pretty solid. Gets the occasional drop off, but that's just wireless internet for you. Weird problem. Give your router a good reset and make sure it has the latest firmware. I'll give that a try. Now... if something is UPLOADING from my other computer (say a torrent or something) could that be an issue? I suspect this could be some of my problems. The cables are all new... so I know I'm good to go on the cables. For some reason I can't seem to get my wired connection to work as well as the wireless. Half of the time I go to the wireless settings because it seems to work better. Strange stuff. I will check into the firmware of the router though. I didn't think about that Thanks guys... I've got some troubleshooting to do now. Quote Link to comment Share on other sites More sharing options...
liveinabin Posted December 30, 2007 Share Posted December 30, 2007 Well, it'll make your internet SO slow as to drop off, sure. Stop the torrents. Quote Link to comment Share on other sites More sharing options...
Shannon Posted January 1, 2008 Share Posted January 1, 2008 Torrents can be a problem if they are clogging up your bandwidth cause packets will get dropped. What you need to do is set your limiters so they are slightly below your max ul speed provided by yer internet provider. I set mine about 2kbps lower. Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted January 3, 2008 Share Posted January 3, 2008 1. If you can, you should look into putting the DD-WRT firmware on that router, it makes a world of difference if you're into networking and can tweak it. 2. If you prefer to keep things simple, try going into the wireless configuration section of your Linksys web interface and choosing a different wireless channel. There is probably something on the same frequency (wireless phone, microwave oven) causing interference. Try channel 1 or 11 for a while to see if that makes any difference. 3. And yes, throttle your torrents or schedule them to run while you sleep. Whatever your cable speed is (I doubt it's 100MBit), you will probably have a much slower upload bandwidth than download. Overdriving your upload will soak your connection. DD-WRT can be used to put QoS (quality of service) on certain types of traffic if you want to have it handled automatically for you. Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted January 4, 2008 Author Share Posted January 4, 2008 I'll look into all of this soon. I just got digital cable/dvr yesterday. I'll fool around with the settings later. The upload rates I have are 512kb... something or another. I think the download rate is 100mb I think... lol Quote Link to comment Share on other sites More sharing options...
