Its 1993, you're in charge of the Jag, what do you do?
A_Gorilla
I think the free SDKs would have benefited Atari tremendously.
The other thing Atari should have done is given, beyond that, developers some type of incentive to code for the Jaguar, instead of tossing money after the development of the Jaguar CD. Even by that time, it was pretty apparent that add ons didn't pan out well for any company. So, it's amazing, to me, that the management of a shrinking share company would have thought a CD resurrection was possible, especially considering the ill fated attempts made by Saga, who, too, destroyed their company, while having a much larger market share.
Making the CD an add-on was the biggest mistake, everything else about it was a 'win' , CD gave much more memory than carts for a far far lower price, and the logistics were way better.
A free SDK wouldn't have helped much - developers tend to want working tools in the first place , it's not their job to rewrite things from scratch. ( The Sega CD was a lot more popular than the Jaguar - the 32x seemed to be the big mistake )
The initial point still remains, the Sega CD was a failure for Sega. Like I said, Atari should have keyed off of that and known a CD add on was a huge mistake. They should have taken the money they wasted on that development and attempted to lure developers to their console. I'd say they should have went as far as buying out an upcoming development team, in order to secure a future franchise that would have differentiated themselves from the flock.
"The problem is the stupid idea to use a 16 bit host like the 68k. Lay off
the host and the system will perfrom worthy of 64 bits. "
I guess that is what I was reffering to, to squeeze down the 64 bit data through the 68k was essentially to have a 16 bit machine, sure the chips could process at 64, but to send it down the datapath to the 68k so much stuff has to be truncated that it's almost a waste...
At any rate, still think some true 3D hardware accel would've been the tipping edge there, didn't have to be the the voodoo chipset, which was the more expensive one, by 93 PowerVR had a one chip solution so did Rendition, which both were finished in 91 actually, even with those "subpar" 3D hardware, combined with the existing JAG hardware, it would've trully been revolutionary and would set the bar so high that Sony would have to play catch up!!
Of course, all the other issues already discussed would have had to be dealt with as well :)
Edited by marvio
I took the MIPs figures from wikipedia
Wikipedia? :lolblue: I could just assuredly ignore the rest of this post based
on that alone...not to mention everything else you have posted in the past....it's
all making sense now. :lolblue: ...but seriously folks....
and extrapolated the gpu figures , 0.5Mips/Mhz is kind of what I'd expect, with the stalls and redundant move instructions that are often needed.
You extrapolated horribly wrong then and I can do much better than 0.7 MIPS/MHZ by hand.
If you are using a ton of movei's you should probably stick to 68k. There are other ways
to obtain immediate data with the GPU.
I definitely picked a lower figure though, you're right that a tight hand tuned loop could be better - but that's not likely to occur with C compiled code.
This entire statement is ridiculous simply based on the fact that there is no C compiler
for the GPU/DSP ( one that is worth bothering with that is) since assembly is the only
route to go with the two RISC's.
Hand tuned assembly should be the only way you bother coding the Jaguar RISC's until
someone actually writes a real optimized compiler.
How much would a 27MHz 68020 have cost in 1983? Even a 13MHz 68ec020 would be a lot more than the 68000?
In bulk, I doubt very much more at all. I belive a 25 mhz EC020 would have been more but
in a half million units, very reasonable. My Jaguar would cost $349, admited but be worth
every last penny in comparison. Still a much better deal over the 3DO and still much cheaper
than a CD ROM drive built in.
Even still, an EC020 under the 13 mhz clock would still be a grave improvment over the
already obsolete, bus choking 68k . So no matter how you slice it the 020 in any for is
a mjor leap over the out of place 68k.
The reason why I dont favour a 68020 is that fixing gpu/dsp would give 32 bit risc code running from main
memory for no cost ( as in a perfect world the bug would not have occurred in the first place )
Agreed if the tools were there to deal with it.
With that a no stall write back register file....true 26.59 mips.
Bigger Local on the GPU and no MMU bug causing the main hiccups.
Also a dual buffer blitter reg file. No more GPU wating on the
Blitter and in reverse.
Fix the DSP UART issues, the OPL and interrupt system bugs and we can agree.
Edited by Gorf
the carts yes...the system however would have cost you $400.
Agreed on the tools except for an SDK with the sources.
32-X was Sega's 'operation spoiled sport" until the got
the Saturn out the door.
The machine would only be choked by using the 68k in a game's loop. The entire bus structure is 64 bits
wide. The 68k did not squeeze the bus down, it choked it.
An 020 instead of a 68k would have given Sony problems. sure the Sony would still be a bit
more robust in terms of poly count but the game logic and AI as well as many other features
on the Jag would be superior. REAL 3D hardware back then would make the Jaguar cost $500 or
more dollars. Still better than the 3DO but hardly a power without the price offering.
Someone other than the Tramiels at the helm might have seen the REAL beauty of the T&J chipset
and designed a much more efficient system around them....even with a 68k...one with a seperate
bus with it's own 64k of RAM to keep it off the main bus most of the time while the REAL work
horses(J-RISCS, BLitter and OPL) could have the bus most of the time.)
Shit...Let the 68k stay with a seprate bus where only the blitter need to write to it and the
Jag would have been a much better system. The 68k then could run in parallel doing AI and game
logic, writing to a specific area that the blitter could grab for the J-RISC to operate off of.
As it stands, everything comes to a screaching halt while that blasted host CPU is running.
Sorry indeed.
Edited by Gorf
I love the Jag, I am on my seventh and hope to keep this one! I think Atari actually pioneered video game marketing by placing in-game graphics on the front of thier packages! The black and red logo are also a great combo!!!! Kudos and thanks for the fun!
I'm almost certain you're confusing Atari boxes with Activision. Activision had the little window on the front of boxes (and cartridges) sisplaying an in-game screenshot. Atari boxes had artwark usually (sometimes artwork that was superimposed over graphics I think), and either plain text on the carts (early on) or a similar immage to the box art on the cartridge label.
I was not aware! Thanks for the clarification, I wish all game companies placed in game screen shots on front! :)
I haven't even seen MIPS ratings for the 020/030 at all... Anyway, I seem to recall that the 020 was more like .4 MIPS/MHz with the 030 being similar. (with the added advantage of the data cache of course)
That price is gettting a bit steep though, the 16.7 MHz rated EC020 would be OK though.
Exactly, it still adds the cache and 32-bit bus, the most important features (keeping it off the bus and widening Jerry to 32-bits)
I disagree, it wasn't a major success, but also wan't a failure for Sega, at least not until combined with various unfortunate decisions made from ~1993 onward and the genneral problems between the American and Japanese management. Nothing like the PE Engine CD in Japan, which outstripped the card based unit and gaave serious competition to the SNES.
I think it's a good deal more complex than that. The 32x started as an in-between system proposed by Nakayma (CEO of SoJ), originally as a standalone unit, enhancing the Genesis hardware (apparently in a similar manner as NEC's supergrafx) long story short, Japan handed to project to the American branch who though an add-on would be much more parctical and went from there. Any possbilityof reasonable success was killed by the Saturn's early release in Japan and then US the following year. This is all tied in with confusing problems between the Japanese and western branches of Sega, alternate Saturn hardware getting scrapped in 1993 to compete against Sony's hardware specs, among other things. (I personally think the rushed development of the Saturn, expensive, non-developer-freindly hardware, and especially the horrible early/pre-release in sprin og 1995 in the US were Sega's biggest mistakes overall)
This is all well beyond th escope of this discussion though.
Edited by kool kitty89
I'd suggest that quite a lot of Jag RISC code runs at about 16-18MIPS
Would that also include code running from main memory? - My point ( before Gorf became totally emotional about it ) was more that the GPU/DSP running general purpose code from main memory in a fixed system ( rather than the bugged one we have ) would be better than a 68020 ( at 13MHz - I don't think a 26MHz 68020 would have been practical for the jaguar price - even the falcon and Amiga1200 only had slower speed cpu's )
( Losing the CPU gives the 32 bit path to Jerry for free as well :) )
Well I could have quoted an architecture reference manual, or even some benchmark figures - but I thought I'd give you a reference you could read. ( Maybe I should have taken the PR numbers from motorola for the chips )
Please read my post - movei wasn't mentioned, ( maybe you should also read up on 2 operand vs 3 operand architectures as well )
I'm glad you can do better that 0.7MIPS/MHZ by hand - it's not really relevant to the original point though. ( And would that be >0.7MIPS across your entire codebase, or just a small optimised loop )
There was a C compiler for the GPU's - and if the bug was fixed allowing main code execution then it would be a lot more practical.
With C the entire codebase for a game would run on GPU/DSP ( I'd guess DSP - with sound running as an interrupt ) and development would be a lot quicker.
Then the real bottleneck routines could be rewritten in ASM to get the final speed up.
If the GPU ISA was the only target Atari could spend resources on improving the C compiler ( or if Jaguar were more successful then other tools companies could )
Rubbish... You've got no proof for that.
The Mega CD was $300 a year earlier - and in some ways that had more components than the Jaguar :)
I'd expect Atari to reach $299 for launch - helped mainly by the removal of the pack in game cart and 68000 offsetting the cost of the CD mechanism. ( Also I'd expect there to be no 'butch' chip as the CD control would be part of Jerry )
Improved profits from game sales ( more of the royalty would be profit rather than the cost of manufacturing cartridges ) would also help Atari keep the initial cost down.
No that would not include code running from main memory - thats more in the region of 5-15MIPS depending on the kind of code running. Which is why the important frequently called loops still need to be run from local.
/me wonders out loud how hard it would be to retrofit a jag with a '020....
It would be better to just take a T&J and redesign the system around it. But if you were going to bother
just get an 030/040 or even better an 060 instead and then kick the clock of the T&J to 32 mhz.
PS1 would get a serious ass whooping. It's would still do more polies but the Jag would then kick
its tail in special effects...which the Jag already does .Sure the poly counts are lower but the quality
is much more able due to the flexibility of the Bliter and not being hardwired to do a few things
well...like the PS1's GPU....it is what it is and to escape that it then needs to use the MIPS to
cover for the lack of the abilities of the GPU.
what about lifting the existing 68k and adding some local cache (like the 16 MHz ST accelerators did)?
I was just thinking that the only part of the system that really efficiently uses the 64 bit bus is the OP. Sure the blitter is ok for clears and copies to/from internal memories. But for general memory copies the page breaks end up limiting the process.
It might have been quicker to actually only use 32 bit memory, but have 2 banks - so that blit's wouldn't page break all the time.
That would also free up pins on tom to allow a seperate data bus for 68k/jerry and the dram.
Interestingly OP heavy games could have the 68k( or GPU/DSP ) running on a seperate bank to the OP.
Yes there was a c compiler and running from main was the very least of it's problems. Clearly you never bothered to use it or you'd know just how absolutely horrible it was.
As far as using the 68k at all versus movei's....I'l take the movei's anyday even out in main.
Yeah but the 020 which would run off the bus already had tools therefore not costing Atari any
money in dev time.
Edited by Gorf
Then you obviously do not understand the blitter very well either. Even with a DRAM page breaks
its a much more efficient means of moving data even externally.
Hardly. The blitter's is a much more able chip than you obviously know.
No rubbish is you forgetting me showing you the price of a 2x CD rom back then was at best
a $99 dollar cost to Atari (and that is being very consevative) since they went for $199.
And single speed and garbage to boot. I dont care how many more components it had it would
not come close to performing as well as the Cd add-on did.
Yes making the DSP cost that much more to produce so either was you still are looking at $400.
No because eiher way you are dealing with DRAM. So one way would not be any much beter than the other
way running from main.
And like I said a 13 mhz EC020 woudl still be better than a GPU doing both rendering
and game logic and AI. At least with the 020 you will be off the bus most of the time
and would have no need for a seperate bus on the 020 thanks to the 020's cache which
for some strange reason you think is useless.
Three processors running in parallel OFF THE BUS is always better than two trying to
handle everything...even in paralelle off the bus.
( Losing the CPU gives the 32 bit path to Jerry for free as well :) )incorrectly I might add.
And puts the burden on two risc's where an 020 with two risc's all capable of staying off the bus
most of the time would be far better. Three heads are better than two.
Again...it's not that the 68k is a bad prcessor but because it MUST take over the bus when
operating, it completely chokes the system. A 68k with a 64k private RAM would have been
a great idea since the blitter would only need to pump in data to it rarely, keeping it off
the bus. It's not about which processor so much but which processor has the ability to stay
off the bus...the 68k dont, and 020 would and a dual risc only system would not be nearly as
efficient as three processors that could stay off the bus while running in parallel most of
the time...not matter how you slice it the 020 would have been the cheapest and best alternative
allowing a large jump in performance in both dev time and poly counts and no need to waste the
two RISC for AI and game logic. At best you could use the DSP for nice fast floats and still
maintain a rockin sound system, allowing the 020 to simply use the DSP here and ther for some
floating point results.
Edited by Gorf
Just had an idea...seeming as though you lot are talking in terms of 'souping up' the jaggie
Why don't some of you get friendly with a soldering iron and using OTS components only, start over souping the jaggies performance (esp. in the processor, video and sound dept)
And perhaps there should be a prize for the most over souped jaguar
Edited by carmel_andrews
What are you talking about? The blitter would still be there - it would just run 32 bits instead of 64 bits.
A fast page access is 2 cycles - a page break is 5 cycles - so blitting from memory to memory is 2 page breaks ( one read / one write ) - 10 cycles for 64 bits in phrase mode. With 2 pages it would be 2+2 read for 32 bits - 8 cycles per phrase.
For pixel writes ( texture mapping ) it would be better - 4 cycles compared to 10.
The OP would be way less efficient with a 32 bit bus though.
