Nukey Shay Posted December 24, 2010 Share Posted December 24, 2010 It easily could be 256 if another method was used for "room diffs" instead of using the high bit of the room number variable (or if that part of the program was removed altogether). There's a fine line between making the game bigger and making the game more boring, tho Added rooms don't "cost" anything in terms of system resources - beyond an extra line in the room data table...and a seperate gfx definition if you want. ROM is cheap...and you could alter the program to use multiple banks if everything doesn't fit in one (for example, branch to different banks if the room # is high or low). I've had that happen. The interior walls of the castles are connected somehow.IIRC that is part of the game's secrets. There's a quick shortcut to move objects around if you use one of them...and you can make the game unfinishable if you trap a needed item in another (it's sent to the game selection room). Use caution when moving things into side walls. Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted December 25, 2010 Author Share Posted December 25, 2010 There's a fine line between making the game bigger and making the game more boring, tho Agreed. MissAdventure Revised has 112 rooms, and that's plenty. Sometimes it's too many rooms, like when I've played the game for 10 minutes or so, I'm heading to the Emerald Palace with the princess and the bat comes along and steals her away. Then I have to go search the entire kingdom to find her again. Stupid bat! IIRC that is part of the game's secrets. There's a quick shortcut to move objects around if you use one of them...and you can make the game unfinishable if you trap a needed item in another (it's sent to the game selection room). Use caution when moving things into side walls. Could there be some secrets to this game I have not discovered yet? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 6, 2015 Share Posted September 6, 2015 Did this see completion as a finished product? Quote Link to comment Share on other sites More sharing options...
bradhig Posted December 27, 2015 Share Posted December 27, 2015 How do you dump the game into assembly ? Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted July 21, 2018 Author Share Posted July 21, 2018 A special version of MissAdventure with enhanced graphics is now for sale at Good Deal Games. http://www.gooddealgames.com/inventory/Atari%202600.html 4 Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted July 22, 2018 Share Posted July 22, 2018 Do you have any screenshots of the new version? 1 Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted July 23, 2018 Author Share Posted July 23, 2018 Do you have any screenshots of the new version? 2 Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted July 30, 2018 Author Share Posted July 30, 2018 MissAdventure has been reviewed by the Video Game Critic. He gave it the Arthur award for extreme difficulty. http://videogamecritic.com/2600mm.htm?e=91005#rev5015 Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted August 11, 2018 Share Posted August 11, 2018 Is this the one the castles get destroyed after you enter them for the first time? Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted August 12, 2018 Share Posted August 12, 2018 Can these dragons and the bat be hacked into the original Adventure? Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted August 12, 2018 Author Share Posted August 12, 2018 Is this the one the castles get destroyed after you enter them for the first time? No, that sounds like one of Nukey Shay's hacks. Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted August 12, 2018 Author Share Posted August 12, 2018 Can these dragons and the bat be hacked into the original Adventure? I'm not sure what you mean but I'm sure they could be hacked. Quote Link to comment Share on other sites More sharing options...
Arenafoot Posted August 12, 2018 Share Posted August 12, 2018 Can these dragons and the bat be hacked into the original Adventure? I'm not sure what you mean but I'm sure they could be hacked. Maybe he's asking for the sprites you used in this version to be added to the original Adventure.... Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted August 13, 2018 Share Posted August 13, 2018 That Maybe he's asking for the sprites you used in this version to be added to the original Adventure.... That's it! 1 Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted August 13, 2018 Share Posted August 13, 2018 No, that sounds like one of Nukey Shay's hacks. 8K Advent. That and the X-Ray specs ideas (used to traverse the "blind" maze) proved to be pretty cumbersome additions. 1 Quote Link to comment Share on other sites More sharing options...
accousticguitar Posted August 15, 2018 Author Share Posted August 15, 2018 Maybe he's asking for the sprites you used in this version to be added to the original Adventure.... That probably wouldn't be too hard. The hardest part would be cranking up the P2 and remembering the dasm commands. 1 Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted August 16, 2018 Share Posted August 16, 2018 Can these dragons and the bat be hacked into the original Adventure? Might be what you're looking for (more or less): Adventure Enhanced Quote Link to comment Share on other sites More sharing options...
