Where to get replacement Atari joystick contact domes
acharris
Hi all, I need to know where I can get hold of some Atari Joystick contact domes to fix the controllers in the UK, as I have over the last few years picked up controllers really cheap, but some need the domes replaced on them. I bought some a few years ago on Ebay, but I seemed to have run out as I didn't buy that many at the time due to thinking I could get them when I needed them, and now I got some time on my hands to actually restore some, I got none left.
Any help is appreciated. Thanks.
Anthony
You really should contact them. They do not list everything they sell on their website and have a massive catalog of items for sale not listed on the site. I would be surprised if Best couldn't get you those dome contacts as they manufacture a brand new designed dome for their replacement boards as well.
Farnell have low profile dome keys which might work, enter Part Number 877-4455 (4mm) or 877-4471 (5mm) into the search box, price is £6.66 for a sheet of 25 + VAT + about £4 P&P for non account card purchases.
Although not what you want but 16/32 Systems had some replacement PCB's for the old VCS joystick (square shape IIRC) which you could perhapse get some from if you don't want to replace the entire board.
Best Electronics sells replacement 2600 joystick PCB's that of course are brand new, and guaranteed. And to replace the PCB no soldering is required. :) If your going to order the little domes it's probably not much more to get the whole new PCB after shipping.
I just fixed an Atari 2600 joystick I got off ebay, it was dirty, very sluggish, wouldn't go down or right, & required a lot a pressure to go up or left. I fixed it, without buying any parts at all; I opened it, and on the PCB I lifted up the clear tape at all four directions and the fire button (one at a time) just enough to get to them. The domes will stick to this clear tape, by the tops when you pull it up. I took a small knife and scraped up the entire area (center & edges) that the little domes contact, on the PCB copper circuit paths, till it looked like new fresh copper, then I scraped up the underside center area (PCB contact area)of each dome also with my little knife and after I did all five domes one at a time, I pressed the plastic tape back to the PCB, ensuring each dome was in it's place. Re-assemble joystick. I now have a totally fixed and very responsive joystick, that requires minimal pressure to use while playing games. :) Took about 15 minutes.
Now to do all my other 2600 joysticks like that. :ponder:
  • 14 years later...
Used to do the exact same thing with the contact domes on my VCS joysticks in the late 80s, I may have had an ST, Amiga and Megadrive by 1990 but I still looked after my VCS as it was a gift from the gods in my childhood!
I have taken the top clear tape layer and contacts off the joystick board and soldered some thin tact switches onto the board.  The switches were less than a mm tall so I did not even end up trimming the prongs on the white joystick insert.  That stick is one of my favorites so you may want to consider eliminating the discs and going that route.
@Osgeld used to sell premade drop in replacement PCBs with micro switches on them already for the standard CX-40 controllers. I think he posted recently that he might have some on hand still? That would be the best way long term.
I have maybe 5 or 6 as I tend to keep some back just incase someone gets a dud. I did post that I am doing a huge batch but that's not until June at least as I have to secure funding and start prepping for long lead times
and they use just stupid flat tactile switches not microswitches, which I used to use by soldering them on the OG board ... I just made the drop in's (to fund a computer build cough) so that the average joe doesnt need to fiddle with soldering switches on a board that was made for snap domes (as it can be fidgety)
Edited by Osgeld
