Paddle isn't affected by mouse in Stella
Primordial Ooze
I'm trying to test the paddle movement in Stella and for some reason the paddle doesn't move to key presses or mouse movements reguardless of what i press or move. I have code to the move paddle, so i have eliminated that possibility. I know the paddle is being moved by the paddle controller in Stella because the paddle is being positioned at the top of my screen by code paddle movement and boundry checking code. If i remove the line:
player0y = paddle * 2 + 1
That paddle stays centered like it should when the game is first started. I tried pressing Ctrl 0 and the message "Mouse controls Paddle 0" appears on screen, but nothing happens no visible changes.
Heres my full code:
 rem Open Source Pong
rem an Open Source Pong Remake
rem Updated: Feburary 10, 2008
rem Website: http://opensourcepong.freepgs.com
rem set the rom size
set romsize 4k
rem set kernel options
rem readpaddle - set it so the paddle controlers are read
set kernel_options no_blank_lines readpaddle
rem set an alias for the ball's x velocity
dim ballxvelocity = a
rem set an alias for the ball's y velocity
dim ballyvelocity = b
rem set an alias for the player1's score
dim player1score = c
rem set an alias for the player2's x score
dim player2score = d
rem set player1's inital x positon
player0x = 15
rem set player1's inital y positon
player0y = 45
rem set player2's inital x positon
player1x = 140
rem set player2's inital y positon
player1y = 45
rem set ball's inital x positon
ballx = 80
rem set ball's inital y positon
bally = 45
rem start of the game loop
gameLoop
rem color the background black'
COLUBK = 0
rem set the color of the playfield to white
COLUPF = 14
rem define the playfield
playfield:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
end
rem color player 1's paddle
COLUP0 = 14
rem define player 1's sprite
player0:
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
end
rem color player 2's paddle
COLUP1 = 14
rem define player 2's sprite
player1:
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
%00011000
end
rem read paddle 0, use it to position player0x across the screen
currentpaddle = 0
rem draw the game screen
drawscreen
rem set player1's y position to the paddle control's axis
rem multiplied by 2 plus 1
rem player0y = paddle * 2 + 1
rem make sure the player doesn't go off the top screen
if player0y > 153 then player0y = 153
rem make sure the player doesn't go off the bottom screen
if player0y < 8 then player0y = 8
rem redraw the screen
drawscreen
goto gameLoop
Any ideas?
Sincerely,
Open Source Pong
Okay, I think I see the problem. After you compile and run it in Stella, you need to press TAB to bring up the menu, then select GAME PROPERTIES and select PADDLES for the left controller. Then exit the menu, press "\" and restart the ROM.
Also, you have some coordinate problems with the paddle. In batari Basic, paddle will return a value between 0 and 80, and you want the paddle to control the y position, which ranges from about 1 to 88, so you don't need "paddle * 2 + 1." (That would be used if you want the paddle to control the x coordinate, which ranges from 1 to 160.) Also, you don't need two drawscreens in the loop. I've updated your code so it works better, just don't forget to select PADDLES for the left controller, because it defaults to JOYSTICK.
Michael
PS-- I also moved some of the code to be above the loop, since you don't need to keep repeating those statements each time you loop, once is enough.
open_source_pong.bas
You have to tell Stella that a paddle is plugged into the left port. Check the first post in the Medieval Mayhem thread if you don't know how to do that.
Also, the paddle movement in Stella (wrt emulation using the mouse or keyboard) is not entirely accurate right now. You can notice it in Night Driver, where the paddle almost doesn't work at all. I've fixed the problem, and it will be included in the next release.
