palette demo thing.
doppel
So I wrote an old palette demo for the 2600, tested it out on the real thing, and it worked...then I updated it to work on both NTSC and PAL systems, and it works, at least on NTSC systems. I have no way of testing this on PAL, unfortunately, but perhaps one of you can...
Anyway, the demo reads the color/b&w switch, if it's on "color", it will render in NTSC...if it's on "b&w", it will render in PAL. Those of you with SECAM systems, ignore this.
paldemo2.bin
I like the way you alternate between background and playfield to get eight evenly-spaced columns that completely fill up the width of the screen! :thumbsup: :thumbsup:
Michael
hello doppel,
i tried your file on pal system.
if i switch between pal and ntsc (color/bw switch) it shows me the same colors on the tv screen. between switching you heve a short flickering screen.
i used a starpath supercharger to test it on my pal 2600er.
some day´s ago i also thougt about a code to test colors,.. it´s helpfull if you want to test contrast between to sprites/pf´s ...
my idear was, you can change the color of a sprite/pf by pressing left or right or up and down with the joystick.
the first 3 scores gives you the color number1 the second 3 scores the color number2.
i postet my cheap code,. but you will see, it´s pretty spartanic :)
might be a helpfull tool to do a combination of your chart and the selection by joystick.
best
Tom
color_test_pal.bas
color_test_pal.bas.bin
