DeV0 Posted August 11, 2002 Share Posted August 11, 2002 Hello all I have gotten my hands on an atari, the rainbow one that i think is a JR in NTSC countries? This machine looks brand new, everthing still bagged and tied. Anyway, ive tried tuning this in with the original RF cable and will only get B&W (games do appear) when using the B&W switch it does respond, However only with a different brightness. I only have one cart (32 in 1) which is PAL as it was never released in NTSC, Could it be the cart? or are we looking at a bigger problem? Ive tried on several TV's, all of which are multisystem. I have opened it up and messed with the "pot", this has yielded nothing. If anyone can help i would be exremely grateful. Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/ Share on other sites More sharing options...
Thomas Jentzsch Posted August 11, 2002 Share Posted August 11, 2002 Anyway, ive tried tuning this in with the original RF cable and will only get B&W (games do appear) when using the B&W switch it does respond, However only with a different brightness. I only have one cart (32 in 1) which is PAL as it was never released in NTSC, Could it be the cart? or are we looking at a bigger problem? Ive tried on several TV's, all of which are multisystem. I have opened it up and messed with the "pot", this has yielded nothing. If anyone can help i would be exremely grateful. It's either a software (cart) or a hardware (console) problem. Color loss normally happens on PAL TVs when the game produces an odd number of lines. Are you 100% sure the cart is PAL and have you checked all games? If yes, I'd guess the console is the problem. Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-120129 Share on other sites More sharing options...
Eckhard Stolberg Posted August 11, 2002 Share Posted August 11, 2002 Most of the games on the 32-in-1 cartridge were badly hacked from NTSC. The colour-loss problem is quite common for some of them. Try turning the console off and on until you get Combat or Air Sea Battle. Those should give normal colours. If these games don't work, it's most likely a hardware problem. Ciao, Eckhard Stolberg Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-120221 Share on other sites More sharing options...
DeV0 Posted August 11, 2002 Author Share Posted August 11, 2002 Hi, thanks for your help Im hoping its the cart, I have tried all 32 games and all are b&w. The console came in a box in mint condition, the controller still in bubble wrap, the RF cable tied in it's bag and the power supply still boxed. So its wishful thinking thats its software? when i opened it the screws where untouched and the warrantee sticker was still there. Both tv's are not just pal, they do both ntsc's, seacam & pal. I have a jap DC running on both and a U.S Ps2. I think i might break the cart open and try cleaning it, The 32 in 1 is pretty common here. Thanks again guys, and long live the 2600 ( or maybe not in my case ) Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-120278 Share on other sites More sharing options...
liveinabin Posted August 12, 2002 Share Posted August 12, 2002 try a different aerial lead as well, and fine tune the TV. Other than that, open up the 2600 and look for any bad connections. if its just the colour, its probably something pretty simple. Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-120451 Share on other sites More sharing options...
eggplant_casserole Posted August 30, 2002 Share Posted August 30, 2002 Is the console PAL? Is it Australian PAL or UK PAL? There's a difference! The TVs do multi-standard IN RGB, maybe composite. Virtually none do multi-standard WITH colour through RF. The system MUST be OZ PAL!!! Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-130053 Share on other sites More sharing options...
DeV0 Posted September 16, 2002 Author Share Posted September 16, 2002 Thanx 4 everyones help on this, Since the problems i was having i have managed to get a 7800, a 6 switch woody and a vader. These all work just fine. Bad thing is that i hacked the 32 in 1 apart which wasnt the problem, I also tried the av mod on the junior to no avail, Ah well, Its an x-file Quote Link to comment https://forums.atariage.com/topic/12296-pal-2600-no-colour-please-help/#findComment-139133 Share on other sites More sharing options...
