retrogeek Posted March 29, 2008 Share Posted March 29, 2008 (edited) I was wondering if someone could help me with this playfield editor. I've been creating sample 2600 graphics with this program, but when I try to save the file (or export as code) I keep getting some strange error that reads 'Disk Failure' . Any idea what is causing this? I select my desired path (which is my hard drive) for the file, etc., and it refuses to work regardless of what I do. Edited March 29, 2008 by retrogeek Quote Link to comment Share on other sites More sharing options...
retrogeek Posted March 29, 2008 Author Share Posted March 29, 2008 There must be someone out there who has the answer. Quote Link to comment Share on other sites More sharing options...
Wickeycolumbus Posted March 29, 2008 Share Posted March 29, 2008 Im sorry, but I cant help you. Hopefully this post brings some attention to this topic tho... Quote Link to comment Share on other sites More sharing options...
retrogeek Posted March 29, 2008 Author Share Posted March 29, 2008 Im sorry, but I cant help you. Hopefully this post brings some attention to this topic tho... Thank you for the bump. I've followed the instructions included with TiPaint so I have no idea on what's causing the problem. Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 29, 2008 Share Posted March 29, 2008 when I try to save the file (or export as code) I keep getting some strange error that reads 'Disk Failure' . (1) Make sure you specify a valid file path, and make sure the directory already exists. (2) Make sure you use the old "8.3" naming convention. If your directory name is longer than an 8-character name plus 1 period plus a 3-character extension, or if it contains any spaces or other "bad" characters, then you'll need to convert it to the "8.3" format. For example, "C:\TIA Painter\My Playfield Data\" would most likely become "C:\TIAPAI~1\MYPLAY~1\". (3) Likewise, make sure your file name adheres to the old "8.3" naming convention. For example, "TEST 1.ASM" (with a space between "TEST" and "1") would be invalid, but "TEST1.ASM" would be okay. (4) Make sure the target directory isn't read-only, and that you have user permissions to create files in it and write to it. I have a question of my own. How the heck do you quit and exit out of the program? Michael Quote Link to comment Share on other sites More sharing options...
retrogeek Posted March 29, 2008 Author Share Posted March 29, 2008 (edited) when I try to save the file (or export as code) I keep getting some strange error that reads 'Disk Failure' . (1) Make sure you specify a valid file path, and make sure the directory already exists. (2) Make sure you use the old "8.3" naming convention. If your directory name is longer than an 8-character name plus 1 period plus a 3-character extension, or if it contains any spaces or other "bad" characters, then you'll need to convert it to the "8.3" format. For example, "C:\TIA Painter\My Playfield Data\" would most likely become "C:\TIAPAI~1\MYPLAY~1\". (3) Likewise, make sure your file name adheres to the old "8.3" naming convention. For example, "TEST 1.ASM" (with a space between "TEST" and "1") would be invalid, but "TEST1.ASM" would be okay. (4) Make sure the target directory isn't read-only, and that you have user permissions to create files in it and write to it. I have a question of my own. How the heck do you quit and exit out of the program? Michael Thank you Thank you Thank you! You can tell I don't use DOS for most applications (it's been a long time!) Press the ESC key; a requestor appears asking if you want to exit the program. Edited March 29, 2008 by retrogeek Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 30, 2008 Share Posted March 30, 2008 Thank you Thank you Thank you! You can tell I don't use DOS for most applications (it's been a long time!) Press the ESC key; a requestor appears asking if you want to exit the program. Oh, okay. I looked in the readme, and checked the onscreen help, but didn't see anything that mentioned how to get out of the program. I did try Q and X and E (quit, exit, end, whatever), but I guess I didn't try ESC. Thanks! Michael Quote Link to comment Share on other sites More sharing options...
