RevEng Posted February 26, 2022 Share Posted February 26, 2022 5 hours ago, Pat Brady said: Questions: Currently I don't set the controller flag in the a78 header. Should I? Can you see anything wrong with my code? Does the second write to INPTCTRL even do anything, since the first write locked it? 1. actually, a7800 isn't yet supporting auto-switch for controllers via the header, so it doesn't matter for it. 2. Nothing jumps out at me. It would be instructive to know if disabletwobutton actually ran or not. TBH I'm not really sure if INPT4 can actually be read reliably in two button mode, despite the caution and suggested action in the guide and forums. 3. Yes, even though the register is used with the INPTCTRL name, it's actually writing to the TIA vblank register. The two button controllers require the paddle lines to not be grounded out, for obvious reasons. 1 Quote Link to comment Share on other sites More sharing options...
+Pat Brady Posted February 26, 2022 Share Posted February 26, 2022 30 minutes ago, RevEng said: 1. actually, a7800 isn't yet supporting auto-switch for controllers via the header, so it doesn't matter for it. 2. Nothing jumps out at me. It would be instructive to know if disabletwobutton actually ran or not. TBH I'm not really sure if INPT4 can actually be read reliably in two button mode, despite the caution and suggested action in the guide and forums. 3. Yes, even though the register is used with the INPTCTRL name, it's actually writing to the TIA vblank register. The two button controllers require the paddle lines to not be grounded out, for obvious reasons. 1. Okay, that works for me. 2. It turned out my reset-switch debounce loop covered almost all of my initialization code. (I certainly don't remember why I ever thought that was a good idea.) Not sure why that matters, I wasn't holding down the reset switch, but after I reduced that loop to the minimum (lda SWCHB, lsr, bcc), the 2600 one-button controller works fine. So now just gotta make Genesis work. I think I have the polarity wrong on button C, not sure that completely explains what's happening, but hopefully I can figure it out from here. 3. I think I understand. INPTCTRL is a MARIA register, VBLANK is a TIA register, both are mapped to $01, and the idea is to enable and lock INPTCTRL, then write the desired VBLANK values. 2 Quote Link to comment Share on other sites More sharing options...
+Pat Brady Posted February 26, 2022 Share Posted February 26, 2022 Got all 3 controller types working. Thanks to @Trebor and @RevEng for your help. Here is my startup code: start sei ; disable maskable interrupts cld ; clear decimal mode lda #$07 sta INPTCTRL ; lock into 7800 mode (7800 Stds&Procs) ldy #$00 ; use Y: it will persist while A does other stuff sty VBLANK ; aka INPTCTRL; also enables HALT per enhanced 7800 SG sty OFFSET ; "for future expansion" (7800 SG, 7800 Stds&Procs) sty CTLSWA ; controllers are input-only ; do any other startup code here lda INPT1 bmi initgenesis ; b if pin 9 (7800 L or Genesis C) is 1 ; if Genesis not detected, assume 7800 2-button controller, can change ; to 2600 1-button later lda #$04 sta CTLSWB ; enable 2-button 7800 controller 1: set pin 6 to output sty SWCHB ; enable 2-button 7800 controller 2: pull pin 6 (INPT4) high sty ctrltype ; 0: 2-button 7800 controller bne reset ; based on lda #$04; always b initgenesis sty CTLSWB ; set all pins to input iny sty ctrltype ; any non-0 +ve: Genesis controller reset lda #$63 sta CTRL ; disable DMA (for now) (7800 Stds&Procs) ldy #$00 ; use Y: it will persist while A does other stuff ; turn off audio sty AUDV0 sty AUDV1 ldx #$FF txs ; initialize stack pointer And here is my button-read routine: subroutine ; jsr readbuttons ; read controller buttons ; return value: $00: no button, $80: left/B button, $40: right/A button ; preserves X,Y lda ctrltype bne .readgssor2600 bit INPT4 ; 2600 button (or Genesis B) bmi .read7800 ; disable 2-button 7800 controller lda #$04 sta SWCHB ; don't pull pin 6 (INPT4) high lda #$00 sta CTLSWB ; set pin 6 to input lda #$FF sta ctrltype ; any -ve number: send next read to .read2600 .lbuttonpressed lda #$80 ; bit 7 rts .readgssor2600 ; Genesis or 2600 controller bmi .read2600 bit INPT4 ; Genesis B bpl .lbuttonpressed bit INPT1 ; Genesis C bmi .nobutton .rbuttonpressed lda #$40 ; bit 6 rts .read7800 bit INPT4L ; L button bmi .lbuttonpressed bit INPT4R ; R button bmi .rbuttonpressed .nobutton lda #$00 ; no button rts .read2600 ; 2600 (1-button) controller ; separate from Genesis handler to prevent spurious Genesis C reads bit INPT4 bpl .lbuttonpressed bmi .nobutton ; always b Everyone feel free to use this in your project, with or without modifications. (Depending on your project, you might want to swap the button prioritization, or detect both buttons pressed…) EDIT: my game is one-player. For a two-player game (or a one-player game using two controllers), initialize CTLSWB to #$14 instead of #$04. You may also want to add code for mixed controllers. 6 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted February 27, 2022 Share Posted February 27, 2022 18 hours ago, Pat Brady said: Got all 3 controller types working. Thanks to @Trebor and @RevEng for your help. Here is my startup code: start sei ; disable maskable interrupts cld ; clear decimal mode lda #$07 sta INPTCTRL ; lock into 7800 mode (7800 Stds&Procs) ldy #$00 ; use Y: it will persist while A does other stuff sty VBLANK ; aka INPTCTRL; also enables HALT per enhanced 7800 SG sty OFFSET ; "for future expansion" (7800 SG, 7800 Stds&Procs) sty CTLSWA ; controllers are input-only ; do any other startup code here lda INPT1 bmi initgenesis ; b if pin 9 (7800 L or Genesis C) is 1 ; if Genesis not detected, assume 7800 2-button controller, can change ; to 2600 1-button later lda #$04 sta CTLSWB ; enable 2-button 7800 controller 1: set pin 6 to output sty SWCHB ; enable 2-button 7800 controller 2: pull pin 6 (INPT4) high sty ctrltype ; 0: 2-button 7800 controller bne reset ; based on lda #$04; always b initgenesis sty CTLSWB ; set all pins to input iny sty ctrltype ; any non-0 +ve: Genesis controller reset lda #$63 sta CTRL ; disable DMA (for now) (7800 Stds&Procs) ldy #$00 ; use Y: it will persist while A does other stuff ; turn off audio sty AUDV0 sty AUDV1 ldx #$FF txs ; initialize stack pointer And here is my button-read routine: subroutine ; jsr readbuttons ; read controller buttons ; return value: $00: no button, $80: left/B button, $40: right/A button ; preserves X,Y lda ctrltype bne .readgssor2600 bit INPT4 ; 2600 button (or Genesis B) bmi .read7800 ; disable 2-button 7800 controller lda #$04 sta SWCHB ; don't pull pin 6 (INPT4) high lda #$00 sta CTLSWB ; set pin 6 to input lda #$FF sta ctrltype ; any -ve number: send next read to .read2600 .lbuttonpressed lda #$80 ; bit 7 rts .readgssor2600 ; Genesis or 2600 controller bmi .read2600 bit INPT4 ; Genesis B bpl .lbuttonpressed bit INPT1 ; Genesis C bmi .nobutton .rbuttonpressed lda #$40 ; bit 6 rts .read7800 bit INPT4L ; L button bmi .lbuttonpressed bit INPT4R ; R button bmi .rbuttonpressed .nobutton lda #$00 ; no button rts .read2600 ; 2600 (1-button) controller ; separate from Genesis handler to prevent spurious Genesis C reads bit INPT4 bpl .lbuttonpressed bmi .nobutton ; always b Everyone feel free to use this in your project, with or without modifications. (Depending on your project, you might want to swap the button prioritization, or detect both buttons pressed…) EDIT: my game is one-player. For a two-player game (or a one-player game using two controllers), initialize CTLSWB to #$14 instead of #$04. You may also want to add code for mixed controllers. Thanks! I was just creating the joystick driver in cc65 and this appears to be a pretty good base for an atari7800-stdjoy driver. In the cc65 you need to query separately for joystick 1 and joystick 2 so my code would return a byte with RLDU..21 meaning: Right Left Down Up X X Button 2 Button1 The returned byte would look identical for both joysticks. 2 Quote Link to comment Share on other sites More sharing options...
+karri Posted March 30, 2022 Share Posted March 30, 2022 Is there a conflict in 2 joystick mode with the Genesis joystick and the 2-button 7800 joystick? In the Genesis case CTLSWB has all pins as inputs while 2-button 7800 has CTLSWB $14 (two pins as outputs). I am trying to figure out a good stdjoy driver for cc65 that would allow people to use the hardware they have. The best option right now is to have this driver for a single joystick. But I wonder if it is safe to use the Genesis stick with CTLSWB pins required by 2-button 7800 joystick set as outputs? Edit: I found a wonderful description about these issues! "Universal" Joystick schematic for 2600, 7800, SMS, Untested - Hardware - AtariAge Forums Quote Link to comment Share on other sites More sharing options...
+Karl G Posted March 30, 2022 Share Posted March 30, 2022 6 hours ago, karri said: But I wonder if it is safe to use the Genesis stick with CTLSWB pins required by 2-button 7800 joystick set as outputs? Not without a wiring change or an adapter, e.g. a Seagull 78 adapter. 1 Quote Link to comment Share on other sites More sharing options...
