Help with modifying a power supply for use with the 2600
This is the technical info for this power supply I want to modify for a "homemade" 2600 PSU.
9VDC 1A POWER ADP
MFG: ATARI
Input: 120VAC 60Hz
Output: 9VDC @ 1A
Specifications/Features:
2 Prong input, 8’ cord with 3.5mm (O.D.) and 1mm (I.D.) coaxial connector for output, Center positive. UL/CSA Listed
L: 3" W: 2-3/8" H: 2" WT: .9
I will post a picture of it at the bottom of this post.
I believe the connector needs to be switched to a 1/8" type, right?
So my question is: If I cut off this wrong connector to solder on a new 1/8" connector, how will I know which of the 2 wires is positive? I need to know this so that I can solder it on the center of the new connector? Sorry, if I sound like an "electronics moron" but I am! :D
If I accidentially reverse the polarity when I solder the two wires into the new connector and plug the power supply into the 2600, will it ruin it?
This power supply is new and really cheap. That is why I am considering the attempt at modifying it.
You need to get yourself a Voltimeter tester, some models are as cheap as under $10, don't be scared by those pricey pro models, look for an amateur taiwanese version, it always come in handy to test Batteries voltages, light bulbs etc.
When you get the Voltimeter set the dial to test in the range of 0-10 DC volts, now tie everything and put the (+) red lead on the center of the power jack and the (-) black lead on the outter part. If the needle runs backwards then untie everything and swap those wires. Now you can safely plug it into your VCS.
If you don't want to buy a Voltimeter, if you accidentaly plug the power jack with the reverse polarity at best your VCS won't work, but I don't recommend you to do this trial and error test, just get a Voltimeter will ya? :D
"or at ACO Hardware stores, if you have one of those stores near you "
I have never heard of this store, so, I don't think I have one near me. Although, sometimes I can be incredibly unobservant. :)
I sure hope I can find a cheap one somewhere. I would hate to guess the polarity wrong and ruin a 2600!
I bought a medium sized lot of "junker" 2600's, a couple other systems, and some accessories on eBay. My hope is to gather up a couple of working sets and make a reasonable profit. With the profit I want to get the new PSX to 5200 adapter that Clay Cowgill is producing.
Sorry for the back story, I guess I am feeling chatty today. :)
Please make sure the PSU is REGULATED first! It should be, but if not you risk putting up to 18V into your system!
Yes, get a 3.5mm mono connector. As everyone said, use a multimeter or voltmeter to test. You may find your local radio shack guy would let you use his, or tv repair man, if you ask nicely. Mind you, most PSUs have a stripe on one lead.
Radio Shack is good, or www.mcmelectronics.com - to name just two of many ;)
Good luck with the project - you're gonna need it! e-mail if you have any questions
BTW, 1A is quite a lot more than 500mA, but should be OK.
If you have problems, the afforementioned will have dedicated 9V 500mA DC PSUs with the right connector :) - or try eBay or myatari for one
