Is it possible to change the look of the playfield pixels?
Random Terrain
Is it possible to have all playfield pixels look like an image that you can draw? So, you'd draw an image that is the correct width and height and point to the image data in some way so that every playfield pixel will look like what you drew instead of being a plain blank rectangle.
I'm not sure I understand your question. Are you talking about doing this in the Visual bB editor, or something else?
Michael
Once the ability was added to bB, I'm sure jwierer could make an editor similar to the Score Editor for creating the image, but I'm talking about bB, not VbB.
In bB right now, the playfield pixel blocks are solid. It would be nice if, instead of solid, they could look like an image. With all of the limitations that bB has, I'm sure it would have to be one shared image.
Here's an example of what the playfield with solid pixels looks like:
And below is an example of what it would look like if bB could point to shared graphics data:
I placed a little image to the left of the maze to show what the shared data in this case would look like all by itself. You could create anything you want and tell bB to use it as shared data for all playfield pixels.
Edited by Random Terrain
That would be awesome, but the 2600 can not do that. You need to step up to the 5200 or 7800 to get graphics abilities like that.
So is the following tiled game idea a different kind of thing from what I'm talking about:
http://www.atariage.com/forums/index.php?showtopic=120849
Your mockup showed PF graphics with the resolution of sprites (160 pixels across the whole screen). The linked demo is making multi color tiles at PF resolution (40 pixels across). There is a lot of flicker and fast swapping of colors to make that demo. If you or someone else package that multi-color tile display kernel into a file so it can be linked into a bBasic program, then yes you could write a bBasic game using that kernel. The default kernels bBasic do not have that ability.
Cheers!
Your mockup looks like a game.. what game I can't place the name? Rockbuster? I forget the name.. was made for C64 and older systems and someone was working on it for the 5200 here.
Thanks. I hope someone figures out a way to do a little more with the playfield using bB. I'd like to be able to make things like bushes.
I don't know. Don't think I've seen it.
Would it be possible to map repetitive sprites over the playfield?
See post 9 in this thread for some interesting examples of repetitive sprites. I don't know if it would work with an asymetrical playfield, but it's a start.
Thanks for the link.
Boulderdash.
Oh, yeah. I know that game. I used to play it on the Commodore 64 and Andrew Davie was working on an Atari 2600 version:
http://www.youtube.com/profile_videos?user=atari2600guru
http://www.atariage.com/forums/index.php?showtopic=118287
I don't know about bushes, but you can draw trees! ;) And bushes are kind of like miniature trees, so... Here's an example of a forest scene with little boy Red walking through the woods. It uses flickering to get four playfield colors-- or else three playfield colors and one background color, depending on how you want to look at it. I used the pfcolors option because you could even change the pfcolor from row to row if you want, which would let you get three different playfield colors on each row of the playfield (the background color would always be the same). The trick is to use different colors on the alternating frames, to get a blending of colors when the frames are flickered together:
Frame 1 -- backgroundcolor 1, playfieldcolor 1, player0color 1, player1color 1
Frame 2 -- backgroundcolor 2, playfieldcolor 2, player0color 2, player1color 2
Possible blendings:
backgroundcolor 1 and backgroundcolor2
backgroundcolor 1 and playfieldcolor 2
backgroundcolor 1 and player0color 2
backgroundcolor 1 and player1color 2
playfieldcolor 1 and backgroundcolor 2
playfieldcolor 1 and playfieldcolor 2
playfieldcolor 1 and player0color 2
playfieldcolor 1 and player1color 2
player0color 1 and backgroundcolor 2
player0color 1 and playfieldcolor 2
player0color 1 and player0color 2
player0color 1 and player1color 2
player1color 1 and backgroundcolor 2
player1color 1 and playfieldcolor 2
player1color 1 and player0color 2
player1color 1 and player1color 2
Aside from the flickering-- which is better or worse depending primarily on the amount of contrast between the luminances of the two colors being flickered together-- there are two things that can make this method a royal pain to use: (1) it can be rather tricky to pick the colors for the two frames so you end up with the blended colors you're looking for, and some of the color combinations you're shooting for may be impossible to achieve; and (2) you have to pay strict attention to the on/off state of the bits in your playfield, players, missiles, and ball, to make sure you get the blendings you're looking for. Also, you must redefine the playfield during each frame, so that uses up a lot of cycles in batari Basic, since the playfield must be loaded into RAM on each frame. My example uses the Superchip for the playfield to get a higher resolution-- I used pfres 31, and kept the first and last columns of the playfield blank, to get a displayed playfield resolution of 30x30 (the 31st row is hidden behind the score)-- and that uses even more cycles than if the playfield were in zero-page RAM and/or had a lower resolution. I could have just defined the player outside of the loop (but not the player colors), but I put it inside the loop because you could get more player colors by changing the bits from one frame to the next.
If you run the .bin in Stella, it looks best if you turn the phosphor mode on and use a blending of 50.
   rem * Multicolored Playfield in batari Basic
  set romsize 8kSC
  set kernel_options no_blank_lines pfcolors player1colors
  const pfres = 31
  player1x = 0
  player1y = 49
loop
  playfield:
  .XXXXXXXXXXXXX....XXXXXXXXXXXXX.
  .X,XXXXXXX,XXX...,XXXXXXX.XXXXX.
  .XXXXX,XXXXXXX,...XXX,XXXXXXX.X.
  .XXXXXXXXXXXXX...,XXXXXXXXXXXXX.
end
  COLUBK = $44
  pfcolors:
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
  $A6
end
  player1:
  %01100110
  %00100100
  %00100100
  %00111100
  %10111101
  %10111101
  %11111111
  %00011000
  %00111100
  %00111100
  %00111100
end
  player1color:
  $20
  $84
  $84
  $84
  $9A
  $9A
  $9A
  $3E
  $3E
  $3E
  $44
end
  player1x = player1x + 1
  if player1x = 161 then player1x = 1
  drawscreen
  playfield:
  .....XXX.....XXXXXXXXXX.....XXX.
  ....XXXXX...XXXXXXXXXXXX...XXXX.
  .X.XX...XX.XXXXXXXXX...XX.XX....
  .X.X.....X.XXXXXXXX.....X.X.....
  .XXX.....XXXXXXXXXX.....XXX.....
  .XXXX...XXXXXXXXXXXX...XXXXX....
  ....XX.XX...XXXXXXXXX.XX...XX.X.
  .....X.X.....XXXXXXXX.X.....X.X.
  .X.XXXXXXX.XXXXXXXXXXXXXX.XXXXX.
  .XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.
end
  COLUBK = $C4
  pfcolors:
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
  $1A
end
  player1:
  %01100110
  %00100100
  %00100100
  %00111100
  %10111101
  %10111101
  %11111111
  %00011000
  %00111100
  %00111100
  %00111100
end
  player1color:
  $20
  $84
  $84
  $84
  $9A
  $9A
  $9A
  $3E
  $3E
  $3E
  $44
end
  drawscreen
  goto loop
Michael
Multicolored_Playfield_in_batari_Basic_3.bas
Multicolored_Playfield_in_batari_Basic_3.bas.bin
