Strange
Primordial Ooze
For some reason this line is causing my collision to fail
		rem if the missile is past the asteroid hide
rem the missile off screen and set missileFired
rem to flase, otherwise skip to skipmissilepasttarget
if missile1x < player1x then skipmissilepasttarget
rem hide the missle off screen
missile1x = 0
missile1y = 0
rem and set missileFired to false
missileFired = 0
rem if the missile isn't past the the asteroid
rem the instructions are skipped to here
Here is the full source:
   rem Planetary Defense
  rem a Rail Shootem up
  rem Updated: October 11, 2008
  rem Website: http://planetarydefense.freepgs.com
  rem includes
  rem none
  rem setup all the game variables
  rem varaible to hold if a missle has been fired
  dim missileFired = a
  rem variable to hold the number of hits the planet has taken
  dim hitpoints = b
  rem set the rom size
  set romsize 4k
  rem set the tv format to NTSC
  set tv ntsc
  rem turn on smartbranching
  set smartbranching on
  rem kernel options
  rem enable no blank lines
  set kernel_options no_blank_lines
  rem set the color of the background to black
  COLUBK = 0
  rem set the score field color
  scorecolor = 128
  rem define the playfield
  playfield:
  X...............................
  XX..............................
  XXX.............................
end
rem enable the "High Definition" playfield hack
pfscroll upup : pfscroll upup
  rem define player 1's sprite
  player0:
  %11100000
  %11110000
  %00001000
  %11111111
  %11111111
  %00001000
  %11110000
  %11100000
end
  rem define the enemy sprite
  player1:
  %00000000
  %00000000
  %00011000
  %00111100
  %01111110
  %00111100
  %00011000
  %00000000
end
rem define player 1's missle height
missile1height=1
rem start a new game
startNewGame
rem reset player's score to 0
score = 0
rem reset the number of hitpoints to 3
hitpoints = 3
rem set player'1 inital x position
player0x = 20
rem set player'1 inital y position
player0y = 44
rem set the enemie's initial x position off screen
player1x = 150
rem set the enemie's initial y position off screen
player1y = 40
rem set the missle off screen
missile1x=0
missile1y=0
rem set missle fired to false
missileFired = 0
gameLoop
rem if the reset switch is pressed, start a new game
if switchreset then startNewGame
rem set player 1's color to white
COLUP0 = 14
rem set the enimie's color to grey
COLUP1 = 10
rem if the left joystick is pushed up, move player 1 up
if joy0up then player0y = player0y - 1
rem make sure the player doesn't go off the top of the screen
if player0y < 9 then player0y = 9
rem if the left joystick is pushed down, move player 1 down
if joy0down then player0y = player0y + 1
rem make sure the player doesn't go off the bottom of the screen
if player0y > 87 then player0y = 87
rem if the fire button is pressed jump to
rem skipjoy0fireormissilenotfired
if !joy0fire then skipjoy0fireormissilenotfired
rem if a missile has been fired jump to
if missileFired = 1 then skipjoy0fireormissilenotfired
rem set the missle in the same x position as the player
missile1x = player0x + 5
rem set the missile in front of the player
missile1y = player0y - 3
rem set missileFired to true
missileFired = 1
rem if the fire button isn't pressed the instructions
rem are skipped to here
rem if the missle was fired "annimate" the missle
if missileFired = 1 then missile1x = missile1x + 1
rem if the missle goes off screen
if missile1x < 159 then skipmissileoffscreen
missile1x = 0
missile1y = 0
missileFired = 0
rem if the missile isn't off screen
missile1x = 0
missile1y = 0
missileFired = 0
rem animate the enimie
player1x = player1x - 1
rem if the asteroid hits the planet the player loses a life and the asteroid
rem is destroyed as well otherwise skip the instructions
if !collision(player1,playfield) then skipplayer1playfieldcollision
rem dercease the planets hitoints by 1
hitpoints = hitpoints - 1
rem place the enimie at the starting location right of the screen
player1x = 154
rem set the enimes new y position randomly
tryagain01
rem generate a random number
r=rand
rem if the number is too small or too big regenerate the number
if r < 8 || r > 84 then tryagain01
rem set the players y position based on the new random number
player1y = r
rem if the player doesn't collide with the playfield the instructions
rem if the player's missle hit the enemie asteroid destroy
rem move the missile off screen and give the player 5 points
rem otherwise skip these instructions
if !collision(missile1,player1) then skipmissile1player1collision
rem move the missile offscreen
missile1x = 0
missile1y = 0
rem reset the missile filed variable
missileFired = 0
player1x = 154
tryagain02
r=rand
if r < 8 || r > 84 then tryagain02
player1y = r
rem and increment the score by 5 points
score = score + 5
rem if the planet has taken too many hits hide the planet
rem and go to the game over screen
if hitpoints = 0 then COLUPF = 0 : goto gameOver
rem set the color of the playfield to light grey
rem if the planet hasn't been hit yet
if hitpoints = 3 then COLUPF = 6
rem set the color of the playfield to medium grey
rem if the planet has been hit once
if hitpoints = 2 then COLUPF = 4
rem if the planet has been hit twice
if hitpoints = 1 then COLUPF = 2
rem draw the screen
drawscreen
goto gameLoop
rem Game Over Screen
gameOver
rem hide the missiles
missile1x = 0
missile1y = 0
gameOverLoop
rem if the joystick is moved start a new game
if joy0up then startNewGame
if joy0down then startNewGame
if joy0left then startNewGame
if joy0rightt then startNewGame
COLUP0 = 14
COLUP1 = 10
rem draw the screen
drawscreen
goto gameOverLoop
Any idea on how i can fix it? i tried
f missile1x < player1x + 5 then skipmissilepasttarget
but that produced assembly errors.
Thanks,
Open Source Pong
You can't do math like that in an if-then. You need to do it in something like a temporary variable.
Instead of this:
   if missile1x < player1x + 5 then skipmissilepasttarget
You'd use this:
   temp5 = player1x + 5
  if missile1x < temp5 then skipmissilepasttarget
