+remowilliams Posted January 6, 2009 Share Posted January 6, 2009 Run - don't walk! http://www.atari-forum.com/viewtopic.php?f=28&t=15679 Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted January 6, 2009 Share Posted January 6, 2009 Put mine in for 1 Quote Link to comment Share on other sites More sharing options...
mimo Posted January 6, 2009 Share Posted January 6, 2009 Thanks for the Heads Up Are these things easy to set up? can you run disc images from it like the 8bit s-drive or sio2usb etc? Quote Link to comment Share on other sites More sharing options...
Goochman Posted January 6, 2009 Share Posted January 6, 2009 Ditto Curious since this works like a normal HD, can I format a 'Spectre 128' partition for my Mac stuff? Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted January 6, 2009 Author Share Posted January 6, 2009 Are these things easy to set up?can you run disc images from it like the 8bit s-drive or sio2usb etc? The original Satandisk was extremely easy to setup and use, and the new guy should be no different. No they don't work like those devices. The UltraSatan will appear and work as one or two ACSI connected SCSI hard drives to the ST. Curious since this works like a normal HD, can I format a 'Spectre 128' partition for my Mac stuff? Most certainly should. I have one SD card for my Satandisk that is setup as a GEMDOS boot and has a secondary Spectre HD parition. The Satandisk was the best thing since sliced bread for the STs, and the UltraSatan is several times more amazing. Quote Link to comment Share on other sites More sharing options...
anzac Posted January 6, 2009 Share Posted January 6, 2009 (edited) not the best of times to spend around 100€, but this will probably be too good to let it pass... at least i´ll have some months to save... one thing that got me confused... does it come with the power supply or we have to "supply" that? pardon the pun... Edited January 6, 2009 by anzac Quote Link to comment Share on other sites More sharing options...
Christos Posted January 7, 2009 Share Posted January 7, 2009 not the best of times to spend around 100€, but this will probably be too good to let it pass... at least i´ll have some months to save... one thing that got me confused... does it come with the power supply or we have to "supply" that? pardon the pun... If the satandisk original is any indication you'll have to supply that yourself. Quote Link to comment Share on other sites More sharing options...
Albert Posted January 11, 2009 Share Posted January 11, 2009 UltraSatan is a hard disk replacement for the Atari ST (and other Atari computers with an ACSI port) that uses SD and/or MMC cards for storage. The UltraSatan includes several improvements over the original SatanDisk project. This new device will be much faster than the original (almost to the limit of ACSI) and is 100% compatible with other ACSI devices. The UltraSatan has two slots for use with SD/SDHC/MMC disks (up to 8GB, acting as two distinct hard drives. As with the original, the UltraSatan will be open source, so if you don't want to buy a ready made device you can always build your own. You can learn more by visiting Jookie's UltraSatan development page and you can pre-order one here. Quote Link to comment Share on other sites More sharing options...
Mr.Bacardi Posted January 12, 2009 Share Posted January 12, 2009 Will it be possible to boot ST disk-images from this device? Quote Link to comment Share on other sites More sharing options...
mimo Posted January 12, 2009 Share Posted January 12, 2009 Will it be possible to boot ST disk-images from this device? If I have understood correctly this thing works like a Hard Drive, so if you have an image that can be loaded from HDD then it should work with UltraSatan. Thats what I hope anyway Quote Link to comment Share on other sites More sharing options...
ppera Posted January 12, 2009 Share Posted January 12, 2009 Will it be possible to boot ST disk-images from this device? Such thing is possible with HW floppy emulators, which are still not available yet by my knowledge. However, with my tool, Floppy Image Runner, you may run a lot of floppy images (read: many games) from hard disk, so from ULTRA Satan too. http://ppera.07x.net/atari/imgrun.php Quote Link to comment Share on other sites More sharing options...
Mr.Bacardi Posted January 12, 2009 Share Posted January 12, 2009 Will it be possible to boot ST disk-images from this device? Such thing is possible with HW floppy emulators, which are still not available yet by my knowledge. However, with my tool, Floppy Image Runner, you may run a lot of floppy images (read: many games) from hard disk, so from ULTRA Satan too. http://ppera.07x.net/atari/imgrun.php Fantastic, this is exactly what I need - thank you! Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted January 12, 2009 Author Share Posted January 12, 2009 Fantastic, this is exactly what I need - thank you! Additionally, check out the HD install/game fixes from the fine folks at D-Bug/Automation. Between the cool new devices and the great work everyone has been doing lately, it's a good time to be an ST user. Quote Link to comment Share on other sites More sharing options...
STGuy1040 Posted January 14, 2009 Share Posted January 14, 2009 I just placed my pre-order for this device; I can't wait! -Mike Quote Link to comment Share on other sites More sharing options...
Karlfm Posted January 15, 2009 Share Posted January 15, 2009 Will UltraSatan work together with ICD Pro hostadapter ? I have it on STE, mit IBM SCSI drive von 2GB. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 2, 2009 Share Posted February 2, 2009 Will UltraSatan work together with ICD Pro hostadapter ? I have it on STE, mit IBM SCSI drive von 2GB. My understanding is, the UltraSatan, like the SatanDisk, is set to ID0. The creator has a small utility on his website that will let you change the ID, but only if the device is setup on an ST that doesn't have something else already setup as ID0. So once you've changed the UltraSatan's ID to something that doesn't conflict with anything else in your chain, it *should* work fine. I just recently went through this with my STacy, which has an internal SCSI card that is set to 0. Just unplugging the HD allowed the SatanDisk to work with my setup (hard drive is dead anyways). PS Thanks to RemoWilliams for the help on this! Quote Link to comment Share on other sites More sharing options...
javiero Posted February 7, 2009 Share Posted February 7, 2009 I put my preorder for one, it is hard living in a country with such devaluation slide but it is worh it Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 11, 2009 Share Posted February 11, 2009 I signed up and put in a preorder, but I cannot log into the site now, and my password does not get sent to me. I have nothing going to my spam folder - if it's being blocked it's by my ISP. Is anyone else having this issue? Stephen Anderson Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted February 11, 2009 Share Posted February 11, 2009 I signed up and put in a preorder, but I cannot log into the site now, and my password does not get sent to me. I have nothing going to my spam folder - if it's being blocked it's by my ISP. Is anyone else having this issue? Stephen Anderson Hey Stephen - I had no trouble going to the site just now. Maybe a temporary thing and you can/should try again? http://mikro.umpc.sk/us_order/ Hope it works for ya. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 11, 2009 Share Posted February 11, 2009 I signed up and put in a preorder, but I cannot log into the site now, and my password does not get sent to me. I have nothing going to my spam folder - if it's being blocked it's by my ISP. Is anyone else having this issue? Stephen Anderson Hey Stephen - I had no trouble going to the site just now. Maybe a temporary thing and you can/should try again? http://mikro.umpc.sk/us_order/ Hope it works for ya. Oops - what I meant to say was I cannot log into the forum (bottom of the page where you enter your username and password). It will not accept my password. When I hit the button to have them email it to me, I never get an email (nothing hits my spam filter either). Stephen Anderson Quote Link to comment Share on other sites More sharing options...
Fletch Posted February 14, 2009 Share Posted February 14, 2009 I just ordered one. Its been a long time since I sold off my LINK and LINK2 so I have been without a hard drive for years. I've been waiting for an opportunity like this to come along. Quote Link to comment Share on other sites More sharing options...
Awol Posted February 27, 2009 Share Posted February 27, 2009 Tomorrow (February 28th) is the last day to place an order! So make up your mind now. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 1, 2009 Share Posted March 1, 2009 Tomorrow (February 28th) is the last day to place an order!So make up your mind now. I still cannot get a reply from the preorder website to verify my 2 went through. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
Mark Wolfe Posted March 4, 2009 Share Posted March 4, 2009 when in March will payments be accepted? @stephen anderson: you don't get a reply from the website, you just log in to verify your account and order. I just logged in myself and everything is fine, it lists your name, address and how many units your want, I'm just waiting for the payments to be opened up, which is supposed to start this month Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 5, 2009 Share Posted March 5, 2009 I take it orders have closed for this run? I've just heard about this device, having taken delivery of a 520STFM today. Quote Link to comment Share on other sites More sharing options...
