zombiecraig Posted February 2, 2009 Share Posted February 2, 2009 (edited) I've been out of the MAME loop for about 4-5 years. I used to use MAME32, but I guess that is now defunct. I used to be able to check ROM status with MAME32, but how do I now check whether or not ROMs are current for MAME .129, if I were to update to that? And what else do I need? I still need samples for certain games, I assume. Anything else? I saw something about CHDs? But, I assume those are only required for certain games (probably more current games), as well. Also, is there a list of all of the current games supported by MAME? These used to be a text file called gamelist.txt or something like like, but I couldn't locate that anymore. Edited February 2, 2009 by BerzerkZombieBentley Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 2, 2009 Share Posted February 2, 2009 Current Mame32 is version .119, I think. CHD's (hard drive images required for certian games) have been around for quite some time. If you are using Mame proper, best bet is to use a tool like Cmpro to check your rom directory for outdated sets. http://lazarus.org.uk/index.php?burners is still the best way to aquire a current (.129) set. Quote Link to comment Share on other sites More sharing options...
zombiecraig Posted February 5, 2009 Author Share Posted February 5, 2009 Current Mame32 is version .119, I think. CHD's (hard drive images required for certian games) have been around for quite some time. If you are using Mame proper, best bet is to use a tool like Cmpro to check your rom directory for outdated sets. http://lazarus.org.uk/index.php?burners is still the best way to aquire a current (.129) set. Thank you! I appreciate the information. Quote Link to comment Share on other sites More sharing options...
